Question about Toshiba Satellite A105 Notebook
My computer only shows the background screen and nothing else. I can not even access the task manager. How can I get to my files?
  • delosreyesna Sep 25, 2009
    I tried to start the computer in safe mode but there are no icons and no start button at the bottom. The recovery will work thank you
  • Jaye Ellen Burke
    Jaye Ellen Burke May 11, 2010
    What means the "background screen"? Can you see any icons at all? I assume not. Can you see the screen contents if you use a flash light, aimed at the screen? If so then your screen has gone south. Can you start the computer in Safe Mode, by holding the F8 key down during startup. The result should be a black n white listing of options; If you can't see anything then you might try to get to the Boot Options screen. Put your recovery disk in the DVD drive and boot fron your DVD and run recovery option.
    Scholar:
  • 131 Answers
Try loading the windows disk that came with your computer & select Repair and not install.
Hope this helps
Posted on Sep 25, 2009
My dell inspiron m5030 laptop goes to my background screen with nothing to choose.wat happened?
They are hiding behind background screen and discussing between services in background for conspiracy against you. Not really as it was, windows is processing a start up item, if it really doesn't load anything perhaps your explorer is stop working or taking a longer time to load, try pressing Ctrl+alt+del, open task manager, click on "Processes" tab and try look for "explorer.exe", if it doesn't show there you go to "File" menu and click "new task (run)" and type explorer, if you can find explorer.exe in task manager, right click to it and select "end task" then after it gone repeat step before.
Aug 07, 2014 | Computers & Internet
Blank screen
A white blank screen? That sounds like the virus changed your display settings. Click Ctrl+Alt+Del to get to the task manager. Press and hold the Ctrl key plus the Alt Key then hit the Del key. When the task manager opens up Click File at the upper left corner of the window then select New Task RUN. When the create New Task Window opens type: explorer.exe and hit OK. See if it starts populating your desktop icons and shows the start menu and task bar. If so, the virus changed your settings.
To change your display background click Start/Control Panel and look for Display or Appearance and Personalization. When it opens select the Desktop tab and change the desktop background. Hopefully the white will go away.
You may have to get into Safe Mode to do the above if the virus disabled the Task Manager.
Apr 09, 2012 | Computers & Internet
Had a virus got rid off it but now screen is white and cannot do anything with it
Yahoo messenger wouldn't appear on screen. It comes up in task bar as a blake. Also icon wouldn't let it come up.
1. Reboot your computer.
2. Press Ctrl+Alt+Del on your keyboard. This will bring up the Windows Security window. Click the "Task Manager" button and then click the "Task Manager" tab.
3. You will see a list of files/applications. These are the applications running in the background on your system, whether they show on your taskbar or not. Any one of these applications could be causing a conflict with the Yahoo! Messenger installation.
4. Click the top item on the list to highlight it. Then hold the "Shift" key down and click the last item on the list. This should highlight the whole list.
5. Click the "End Task" button. This will temporarily close all background applications on your system.
6. Click the "X" in the upper right corner to close the Task Manager window.
7. Install Yahoo! Messenger. You should not experience the same issue that you had before.
8. After Yahoo! Messenger is installed,run registry cleaner reginout also reboot your system. All other background applications will return to their original configurations.
Jan 30, 2011 | Yahoo Messenger
I cant open yahoo messenger..so i uninstall it and then tried to download it again, but why i cant still open it..there is a error message....its says "Windows cannot access the specified device,path,...
Jan 21, 2011 | Yahoo Messenger
What can must i do to my yahoo messenger in everytime i open it it said an error ocurred while trying to access social view plug in.
Reboot your computer. 2. Press Ctrl+Alt+Del on your keyboard. This will bring up the Windows Security window. Click the "Task Manager" button and then click the "Task Manager" tab. 3. You will see a list of files/applications. These are the applications running in the background on your system, whether they show on your taskbar or not. Any one of these applications could be causing a conflict with the Yahoo! Messenger installation. 4. Click the top item on the list to highlight it. Then hold the "Shift" key down and click the last item on the list. This should highlight the whole list. 5. Click the "End Task" button. This will temporarily close all background applications on your system. 6. Click the "X" in the upper right corner to close the Task Manager window. 7. Install Yahoo! Messenger. You should not experience the same issue that you had before. 8. After Yahoo! Messenger is installed,run registry cleaner reginout also reboot your system. All other background applications will return to their original configurations.
Nov 22, 2010 | Yahoo Messenger
Yahoo messenger will not open worked earlier today unable to open or access chat rooms
uninstall ym Reboot your computer. 2. Press Ctrl+Alt+Del on your keyboard. This will bring up the Windows Security window. Click the "Task Manager" button and then click the "Task Manager" tab. 3. You will see a list of files/applications. These are the applications running in the background on your system, whether they show on your taskbar or not. Any one of these applications could be causing a conflict with the Yahoo! Messenger installation. 4. Click the top item on the list to highlight it. Then hold the "Shift" key down and click the last item on the list. This should highlight the whole list. 5. Click the "End Task" button. This will temporarily close all background applications on your system. 6. Click the "X" in the upper right corner to close the Task Manager window. 7. Install Yahoo! Messenger. You should not experience the same issue that you had before. 8. After Yahoo! Messenger is installed,run registry cleaner reg in out also reboot your system. All other background applications will return to their original configurations.
Oct 08, 2010 | Yahoo Messenger
I HAVE A WINDOW XP HOME EDITION AND WHEN I START MY COMPUTER THE ONLY THING THAT COMES UP IS THE BACKGROUND. THERE ARE NO ICONS OR A BAR AT BOTTOM OF SCREEN.
the icons and the bar(task bar) at the bottom of the screen are enabled by the explorer.exe file
it starts automatically but in your case it is not starting
to start it when your computer starts and comes at the desktop, press alt+ctrl+delete button at the same time to bring up the task manager
when you do this a task manager shows up in a window
in task manager window click on file, it will be located on the top left portion on task manager
now click on "new task(run)"
this opens another window, in that window type
"explorer"
without the quotes "" and press enter
this will bring you icons and task bar at the bottom of the screen
Sep 29, 2009 | Computers & Internet
Cannot access anything on computer!!
Maybe the explorer is not loading automatically. As you start Task Manager from Ctrl+Alt+Del, go to new task and run explorer.exe.
OR If it still doesn't solve the problem try and repair the XP installation if you have the XP CD
Apr 19, 2009 | Microsoft Windows XP Professional SP3 Full...
Toshiba Satellite A105 Notebook Logo
272 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
