Question about Dryers
Dryer keeps tripping the fuse. I replaced the Moisture Sensor control last year, but now it's doing it again. Could soemthing else be damaging the control
    President:
  • 1,922 Answers
Check the neutral connection from input power all the way thru the unit, if theres a bad connection the 120 volts will use the other 120 volt connection to make ground and you get what they call a voltage-divider circuit and say the motor is on one leg and the moisture sensor control is on the other leg,the motor will draw only about 80 volts and the sensor will get the imbalance of the 240 volts or about 160 volts and will not last.
Posted on Sep 26, 2009
Dryer works fine on timed cycle does not work on auto
In some dryer's the control panel relies on a thermistor rather than a CYCLING thermostat to regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when the thermistor indicates that more heat is needed to keep the air temperature constant inside the drum
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.html
Apr 15, 2015 | Kenmore Dryers
Why does bosch condensor sensor dryer not heat
GOD IS STILL GOOD !!!!
ELECTRIC Dryer no heat or little heat, or shuts down to fast:
Check your venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it)
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective or has a short if its grounding out? Which in turns causes blown fuses or thermostats or overheating.
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220,
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
Sep 09, 2014 | Bosch 422202 Clothes Dryer Moisture Sensor...
Will broken moisture sensor cause dryer not to heat
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.htmlGOD IS So GOOD !!!! AND THAT'S WHY MY ADVICE IS FREE
Aug 18, 2014 | Maytag Dryers
My dryer works fine...heats tumbles the timer just doesnt advance once it starts therefore the dryer wont turn off on its own
Jul 11, 2014 | Whirlpool LEB6200 Electric Dryer
Hi. my BEKO condensor sensor dryer cuts out the electric mains flip switch when i turn it on. Have checked the fuse and lead no damage, checked socket and it works other appliances. What would cause t
The same happened to our Beko DCU8230 last week still under 1 year warranty, loud bang, burning smell and trip switch flipped. Beko Engineer who called said mains suppressor capacitor had blown.
Aug 27, 2012 | Dryers
How do you install a new moisture sensor? I have the part, but no instructions.
Un-plug the dryer
The moisture sensor snaps in place, by looking at the new one you should see witch end has the release arm that you pry back to remove the old one. Insert a small screw diver or paper clip in the opening to release the clip. When removing the sensor be carefull not to let the two wires connected to it to fall back into the machine.
That being said, the moisture sensor is merely two strips of metal and can't realy go bad. Clean the strips with white vinegar or steel wool then test the dyer.
Too few clothes in the dryer or light items dryed with heavy items (T-shirts with bath towels for ex.) can cause the dryer to misread the dryness of the laundry.
What is the dryer doing to make you suspect the sensor? I have repaired these Bosh dryers for 9 years and only replaced one sensor becase it was physicaly damaged
Sep 20, 2011 | Bosch Nexxt 500 Dryer
Dryer runs but will not heat. Replaced fuse and
your cycling thermostat needs changed too. the thermal fuse is your last safety measure that goes, which means your cycling thermostat is not shutting down the heat element once it detects the right temp hot air in the blower housing so it let the heat element glow until either the high-limit sensor shuts the heat down or the thermal fuse blows. Change the cycling thermostat and good luck
Mar 06, 2009 | Whirlpool LER4634J Electric Dryer
Dryer just quit.. no buttons lit
Front Panel lights not working? Dryer inside light does work? I fixed this twice already on my dryer. Please read this whole explanation I live in New Orleans where the humidity is very high. I have a laundry room where my Washer and Dryer reside. Kenmore HE4T. I noticed that when I shut the laundry room door, my central A/C pulls hot air from outside the house via the dryer exhaust duct. This causes moisture to build on the inside of the dryer and especially the front control panel. Did you ever see moisture on your dryer?s door even when there were no clothes in it? The moisture collects on the Silicon board that controls the dyers function and basically causes a short. This is what I do to fix it. You will need a ¼ nut driver or socket. 1. Confirm that you have power to the dryer <- is the inside dryer light on when you open the door. YES- keep reading.. NO ? find the circuit breaker and reset it. 2. UNPUG THE DRYER! ! ! ! ! ! ! ! 3. Find the 3 screws in the back of the dryer that hold the dryer lid on. Unscrew them and slid the lid back and lift off. Is there moisture on the inside of the lid? 4. Find the 2 screws that hold down the front control panel. They should be silver and will be on top. Do not remove the inside gold screws. 5. Find the 3 screws that hold down the power control panel on the top left side of the dryer. Probably has a high voltage warning sticker on it. 6. Lift the power control panel (sheet metal) part and move it to the right so it lays on the dyers drum. There are some wires attached to it and unless you are a very handy person, I wouldn?t remove them. 7. Lift the front control panel straight up until it comes out of the dryer. There should be some wires that attach this piece to the power control panel. If you are handy, you can remove these 2 clip-on wires from the power control panel by squeezing the black connector locking clip and releasing it from the panel. 8. If you flip the control panel around you may notice moisture on the green silicon chips. Get a hairdryer and take your time to dry them. 9. Dry all components of the dryer with a hairdryer. 10. Put everything back together except for the lid and all the screws. Remember that the front control panel slides down first and then the power control panel sits on top second. Plug the dryer in and see if you get lights, but don?t start the dryer. Unplug the dryer and replace all the screws and the lid. The problem is that once the dryer gets wet from the moisture, it never dries enough for it to start working again. This is a bad design from Sears/Whirlpool. I learn my lesson that just because its more expensive doesn?t make it more better. I now keep my dryer and washer door open all the time even when there are no clothes in it. This lets the moisture escape into the house rather than collect in the dryer. I hope this helps at least one person. Thanks Jason Kennedy from New Orleans
May 28, 2007 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
85 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
