Question about HP DeskJet 3650 InkJet Printer
Is there any way to adjust the paper thickness feed on the HP deskjet 3650? It keeps jamming when using 66 lb. paper, 48 lb. paper works fine. Thanks!!
  • theglenns Sep 27, 2009
    You people are a real work of art. You say there is a posted solution and that solution is to pay $9.99 to get expert advice. Count me out!!
SOURCE: paper jam?
I had similar situation, my HP 3650 did not have a paper jam but kept popping up saying it did. After some time checking the paper paths, I eventually went to "Windows Task Manager" then the "Services" tab looked for "Spooler" right clicked it and then selected "Stop Service", wait a few seconds then restarted the "Spooler" tried a Test page print and all is Fine now.
My System is Vista 64 Ultimate.
This would work with any Win XP or NT or Vista OS.
Posted on Sep 27, 2008
  • 111 Answers
SOURCE: photo paper too thick causes jam
You said that the photo paper you used to use was 9 mil, which seems to be well within the product specifications. You don't say the actual size of the photo paper you are using now, just that it is too think. Have a look at the product's specification's page. Scroll down to the Paper Specifications section of the page and see if the paper you are currently using is supported. If not, you'll have to go with thinner paper. Here's the page:
HP's Product Specifications
Posted on Sep 30, 2008
ziraffa
  • 827 Answers
SOURCE: hp deskjet 3650
Hallo chattykatty4,
Here's the driver software you need to download and install for the your computer to recognise your printer:
http://drivers.softpedia.com/get/PRINTER/HP/Hp-deskjet-3650-color-inkjet-printer-9440.shtml
Season's greetings :)
Chris (ziraffa)
Posted on Dec 24, 2008
RPFinney
  • 385 Answers
SOURCE: HP 6200 all-in-one --paper jam problem
Check side ADF grips are correctly setup, paper tray is not mis-aligned, remove if poss, and replace to check.
check you printer's properties paper size is set correct for the paper used,
open the back door check for loose particles or paper,
remove slowly.
4 x Feed rollers in the back, revolve and clean with distilled water.
wait till dry, try printing again
Disconnect the power cord from the product.
Press and hold # and 3 while reconnecting the power cord.
When reset displays, release both buttons.
Try printing again.
Hope this helps
Regards.
Posted on Apr 16, 2009
  • 21 Answers
SOURCE: HP F4280 deskjet all in one printer paper feeding problem
See page 94 of the user manual which you can get here: http://h10032.www1.hp.com/ctg/Manual/c01374711.pdf
Posted on Jul 06, 2009
Hp9300 not feeding thick paper
Based on the Media weight for a HP Deskjet 9300
The Main Tray can support up to 36 lb bond.
The Manual Tray in the Back can support up to 70 lb bond via a single sheet.
You must check the weight of the thick paper you are using to make sure your using the correct weight.
Oct 15, 2010 | HP DeskJet 9300 InkJet Printer
Is there anyway to enable the 3650 printer to print on Kodak Premium Photo Paper. Paper weight 66 lb. thickness 8.5 mil. Printer jams each time I try to print
Hi Jerry
This is a budjet printer and ity's not really made for anything ohter than standard weight 'copier' typer paper.
66 lb. paper is equivalent to 240G paper here and that doesn't go though machines easily unless the paper feed is from the back. HP printers traditionally roll the paper around a roller and feed it back on itself. This paper (it's almost card) is too thick to go around the roller.
If you want to print a lot of this paper you are going to have to buy a new printer. I would recomment a Canon MP560.
Aug 09, 2010 | HP DeskJet 3650 InkJet Printer
Why won't a brand new hp 3650 printer pick up the paper?
The feed rollers might be slipping. Check to see if you can clean the feed roller. use just a little isopropyl alcohol on a soft cloth. also use regular 20lb. paper.
Jul 30, 2009 | HP DeskJet 3650 InkJet Printer
Information on how to use rear feed
1. Prepare your doc/file for printing.
2. Insert card stock with narrow side of stock in slot in back of printer until it hits rollers and stops. Don't force in any card stock thicker than max. rated.
3. Change printer setup to feed from rear.
4. Print.
Depending on what software you print from, you may need to change this each time you print if you intend to keep printing from that "tray."
Mar 09, 2009 | HP Deskjet 1120c InkJet Printer
Paper jam?
There is most likely some paper jammed inside the printer. You just have to carefully look everywhere you can see to see if there might be a little bit of paper stuck somewhere.
Often blowing gently (and dryly) into the printer will dislodge whatever is stuck.
Jan 13, 2008 | HP DeskJet 3650 InkJet Printer
Printing jammed on thicker paper
See the manual. It looks as if 120g/m2 is the heaviest paper it can use:
"Set Type to correspond to the paper loaded in the tray from
which you want to print. This will let you get the best quality
printout. If not, print quality may not be acheived as you want.
Thin: Less than 19 lb (70 g/m2) thin paper.
Thick: 24 lb to 32 lb (90~120 g/m2) thick paper.
Cotton: 20 lb to 24 lb (75~90 g/m2) cotton paper such as Gilbert
25 % and Gilbert 100 %.
Plain Paper: Normal plain paper. Select this type if your printer is
monochrome and printing on the 16 lb (60 g/m2) cotton paper.
Recycled: 20 lb to 24 lb (75~90 g/m2) recycled paper.
Color Paper: 20 lb to 24 lb (75~90 g/m2) color-backgrounded
paper."
Nov 22, 2007 | Samsung CLP 300 Laser Printer
Printer jams when using Kodak Picture Paper
Check the HP support pages, but as HP inkjets turn the paper over internally it means their weight limit is likely lower than others. Also check you have loaded paper face down so it is glossy side UP as it turns over for printing. Their site quotes a max weight of 200GSM for thick stock http://h10025.www1.hp.com/ewfrf/wc/docum... Source(s): http://h10025.www1.hp.com/ewfrf/wc/docum...
May 05, 2007 | HP DeskJet 3650 InkJet Printer
HP DeskJet 3650 InkJet Printer Logo
94 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
