Icannot get the drain screen open to clean it at the bottom right hand corner of the machine
    Sergeant:
    Champion:
  • 205 Answers
Hello mam
it is very easy to open it just screw it in anti clockwise it will come out.
Posted on Sep 25, 2009
Front loader washer has water in it when i go to use it again
There is a drain plug in the bottom right hand corner of the machine in the front. Get ready to catch any exsisting water when you remove it . Remove the plug clean out this area anything in the clothes can end up here. The washer should work right after you do this
Jun 05, 2014 | Whirlpool Duet GHW9150P Front Load Washer
My bosch washing machine model WFVC6450Uc/19 FD 9002/901476 has E:13 flashing. i was able to drain the water manually but now the door locked there is beeping sound when i try to start it. how to fix it
Hello & Welcome to FixYa
E13 error in your Bosch WFVC washer is a drain error and is displayed when the drain time exceeds & the washer is unable to drain so the door won't open sometimes when this error is displayed. You will have to clean the drain trap in the bottom right hand corner. You can stick a straighten paper clip in the access panel located inside the front bottom panel through the whole and then turn the access panel counter clockwise to unscrew the plastic drain cap behind it. After everything is cleaned and the error returns then replacing the drain pump is recommended repair. Please get back to me if you have any other questions.
Kevin
Oct 08, 2011 | Washing Machines
E:13 Error on our Bosch 500. I threw a load of wet towels (from swimming) and turned it on. About a 1/2 hour later I heard it beeping, so I went to check on it. The soap was still in it, which tells me the...
E13 error in your Bosch washer is a drain error and is displayed when the drain time exceeds & the washer is unable to drain so the door won't open sometimes when this error is displayed. You will have to clean the drain trap in the bottom right hand corner. You can stick a straighten paper clip in the access panel located inside the front bottom panel through the whole and then turn the access panel counter clockwise to unscrew the plastic drain cap behind it. After everything is cleaned and the error returns then replacing the drain pump is recommended repair. Please get back to me if you have any other questions.
Kevin
Jul 31, 2011 | Washing Machines
Bosch E13 error on washer - shows e-13 and door will not open.
E13 error in your Bosch WFMC washer is a drain error and is displayed when the drain time exceeds & the washer is unable to drain so the door won't open sometimes when this error is displayed. You will have to clean the drain trap in the bottom right hand corner. You can stick a straighten paper clip in the access panel located inside the front bottom panel through the whole and then turn the access panel counter clockwise to unscrew the plastic drain cap behind it. After everything is cleaned and the error returns then replacing the drain pump is recommended repair. Please get back to me if you have any other questions.
Kevin
Jul 30, 2011 | Bosch Nexxt 300 Series WFMC2201UC
How do you open front panel on miele w864 to clean out drain pipe to uper right hand side of drum i belive this has a sensor that detects when blocked and once clear machine will work ok , drain pump is...
Hi - in most cases there are three screws behind the door, 2 screws for the door lock, some models will require the removal of soap dish and screws.
Should not be the case here, 2 screws on the lower part of the front panel, open the small trap door bottom RH corner unscrew cap to remove the rubbish from the drain pump as this shuts off the machine too.
Be careful to have a contaner to catch H2O as the cap unscrews.
May 28, 2011 | Miele W864 Front Load Washer
How do you clean the filter?
There is a fluff filter on the front of the unit in the bottom left or right hand corner behind the service flap. Have a small tray, like a baking tray underneath it and open the flap with some sort of flat lever,coin or screw driver. Turn the tap about 1/4 of a turn and collect about a litre of water from the unit. When it has stopped draining unscrew the tap all the way out and clean the fluff filter which is the tap in your hand. Also have a look in the hole and you will see the drain pump at the back. Make sure this is free of any foreign particles and can turn. Then re-screw the tap back making sure it is tight. This should be done regularly every 2-3 months to avoid the unit from not draining.
Aug 20, 2010 | Whirlpool Washing Machines
Bosch exxcel 1200 express fault code f04 what is it
i had this problem,no drain or spin,opened the flap at bottom right hand corner and pulled out small hose to drain machine opened circular filter cover (some water may come out) and found a 5p and 1p blocking filter after removing ,machine worked fine.
hope this helps
Apr 02, 2010 | Bosch Exxcel WFX 2467 Front Load Washer
Ld error code on kenmore oasis
ld stands for long drain. If you can remove the bottom panel you will see the pump in the middle front which has a clean out you can unscrew. There is usually obstructions in the clean out such as a sock causing the long drain. When u remove the clean out cover alot of water will come out so a wet vac comes in handy.
Apr 15, 2008 | Kenmore Oasis 27042 Top Load Washer
Front door will not open
On the bottom right-hand side of the washer, there should be a door that contains the drain cleanout. Open the door and in the upper right-hand corner of the opening, there should be the end of a plastic handle. It may barely be showing, so look closely. Pull it down with your fingers or a plyers and your door should release.
Feb 22, 2008 | Bosch Axxis+ WFR 2460 Front Load Washer
Washing Machines Logo
23 people viewed this question
Top Washing Machines Experts
