Question about Copystar CS-1650 All-In-One Laser Printer
There is a paper jam inside our CS-1650 copier in the by-pass tray. Can't see the paper with tray door open. How do I get inside to get the paper out?
4 Suggested Answers
SOURCE: Kyocera CS 2030 fax jams
If you have the internal fax tray, check where the paper is getting jammed. It may jam right @ the exit gate, which can be wiggled to proper position, or the white paper turn guide on the fuser may have notches worn it it from paper exiting from the copier. These notches can be sanded down with emery cloth or very fine sand paper to smooth.
Posted on Mar 30, 2008
goodgold
  • 389 Answers
SOURCE: Copystar CS-C2525E. Paper Jam error 91. No paper
Under included device open and close the lid. Unless throw, see the condition a sensor entry and leaving the paper - can be the sensors conk. Good luck
Posted on Oct 08, 2009
  • 11 Answers
SOURCE: We have a copystar cs1500 that is giving a J11
check all the paper switch it might be out of position or broken
Posted on May 12, 2010
Problem of paper jam even when no paper is present
There is paper somewhere, or the sensor has been broken by tearing paper out when clearing a jam.
Feb 23, 2011 | Kyocera CS-1650 Black and White Copier
Papers keeps jamming in the bottom tray
pull the tray out ull see a big gray tyre inside the copier clean it with wd40,and at the back of the tray ull see a green paper stopper make sure its right up against back of the paper.
Apr 22, 2010 | Kyocera Copystar CS-1820 Black and White...
13.20 but no paper jammed in path hp9500n ( col laser jet not mfp 9500..).. c8546a.printer boots and immediately gives 13.20 remove paper jam. cleaning page passes through ok when doors are closed...
Open tray 4 and the right
side door to check for
jammed media. Check the paper path
between tray 4 and the
printer. Check the tray-size
guides. Replace the pickup,
separation, or feed
rollers. ur problem 100% resolved
Feb 09, 2010 | HP LaserJet 9500n Printer
Paper jam message does not clear after paper jam has been removed
Paper jams can be tricky to solve. The paper is usually stuck inside the printer mechanism so even if there is no visible paper jam, you will still get the paper jam error. Try this:
1. Turn off your copier
2. Open all trays and remove any paper stuck there
3. Locate the button to open the printer, open it and remove any paper stuck there also.
4. Repeate the above step for all buttons that you can find to access the inside of the copier
5. Close all doors and put back all trays
6. Turn on your copier
NOTE: Please rate our help to keep this free service online.
Jan 08, 2010 | Canon imageCLASS D480 Black and White...
Paper jam
1. Turn off your printer
4. Repeate the above step for all buttons that you can find to access the inside of the printer
6. Turn on your printer
Dec 22, 2009 | Epson Stylus Multifunction Inkjet Printer/...
PAPER JAM PRINTER SAYS PAPER JAM IN INPUT TRAYS BUT PAPER DOES NOT SEEM TO BE JAMMING
Dec 11, 2009 | HP LaserJet 4050 Printer
HP 6540 Lights flashing can't print
This indicates a paper jam or the printer is out of paper. Do not clear a paper jam from the front of the printer.
The printer might be out of paper
1. Place paper in the In tray.
2. Press the Resume button on the front of the printer.
There might be a paper jam
1. Press the Resume button. If the paper jam does not clear, then go to the next step.
2. Push the two latch handles on the rear access door toward each other, and then remove the door.
3. Remove any paper that is inside the printer by pulling it out from the back of the printer. If you are printing labels, verify that a label did not become detached from the label sheet while passing through the printer.
4. Replace the rear access door.
5. Press the Resume button.
If the Two-Sided Printing Accessory is attached to the printer, follow these steps to clear a paper jam from the Two-Sided Printing Accessory.
1. Turn off the printer.
2. Press the buttons on the left and right sides of the duplexer, and then remove it from the printer.
3. Remove any paper inside the printer.
4. Open the duplexer.
5. Remove any paper from inside the duplexer.
6. Close the duplexer, and then re-attach the duplexer to the printer.
If the Auto Two-Sided Print Accessory with Small Paper Tray is attached to the printer, follow these steps to clear a paper jam
2. Press the buttons on the left and right sides of the accessory, and then remove it from the printer.
3. Remove any paper that is inside the printer.
4. Lift the back lever on the accessory, and then unhook the Small Paper Tray
5. Tilt the Small Paper Tray forward and open the lower door of the accessory.
1. Tilt the Small Paper Tray
2. Open the lower door
6. Remove any paper that is inside the accessory.
7. Close the accessory, and then secure the back lever to close the accessory.
8. Re-attach the accessory to the printer.
Oct 03, 2009 | HP DeskJet 6540 InkJet Printer
PAPER TRAY JAM
Hello sir;Pull out the tray look inside the machineif you found any paper chip emove it otherwise clean out paper pickup roller with rubbing alcohol.
Jun 01, 2009 | Kyocera Copystar CS-1820 Black and White...
Copier jams after making one copy
Is the jam Physical? (Damaged lead edge where it may have caught some thing)
Is the jam Timing (paper if perfect, it just stopped.)
If it is Physical then you need to look for the obstruction, paper clip, staple, or small piece of paper. Check very carefully, remove any foreign matter and retry.
If it is a timing jam, the start by removing the paper, check inside the the paper feed area for foreign material, fan the paper and carefully reinstall it, making sure it is the right size paper for the paper cassette. if it has movable guides in the tray, be sure they are firmly against the paper on all sides.
Close up the machine and try again.
Hope this helps.
ed
Apr 28, 2009 | Kyocera Copystar CS-1820 Black and White...
Copystar CS-1650 All-In-One Laser Printer Logo
Top Copystar Office Equipment & Supplies Experts
Kyocera HP Expert
CheckitRight
CheckitRight
Tammie Duggan
Tammie Duggan
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
