Question about Sony KDF-E42A10 42 in. LCD Television
Tryng to set up close caption on my sony kdf-e42a10. No matter how I change the "custom" option, the display does not change from white on solid black. Suggestion please.
circuitcity
  • 137 Answers
SOURCE: closed captions will not disappear
Some TV will not display close caption in HD mode. This is why its Grey out in HD mode. If you switch to regular input, i can bet you your close caption will not be Grey out. The problem you are having is your cable box has close caption enable. You must go into the cable box menu and turn caption off. In some box you may have to call your cable provide for assistant.
Best regards
Circuitcity
Posted on Dec 09, 2007
SOURCE: close caption
You need to turn on closed captions through the menu of your PVR. To have it on all the time, turn the box off, press menu on the front of the box, and scroll down to captions.
This should fix the problem
Posted on Mar 10, 2008
SOURCE: Sony 46" XBR2 Cannot turn off closed caption
With TV on, turn off DVR and hit menu on DVR remote - you can disable CC from there.  Worked for us - got the idea from another fixya post.
Posted on Aug 28, 2008
SOURCE: LG LCD TV Model 42LB5D. The closed caption option is greyed out. Help please.
redrover 11-13-2007, 01:03 PM Well I stumbled onto the solution to my problem, finally, but no thanks to any of the tech at my cable
Posted on Feb 21, 2009
SOURCE: how do i reset the lamp life for sony KDF-E42A10 ?
1) In standby mode, press the buttons on the Remote Commander sequentially, in rapid succession:
[Display] , Channel [5] , Sound Volume [+] , Power [ON]
2)To enter BE-micro service mode menu, press JUMP 2 times.
3) To display the lamp time, press Channel[4]
The screen displays:
“ Total lamp time is 14 hours”
4) To display the lamp time clear, press Channel[5]
7 times and Channel[1].
To reset the lamp time press Channel[3] > [MUTE] > [ENTER].
WRITE (Character color is red) is momentarily displayed and the lamp time is reset to “0”.
This worsk for other Somy retroprojection TVs as well, eg. KDF-E50A10 , KDF-E50A11 etc.
If you goto eserviceinfo.com you'll get the whole service manual
HTH!
zioanza
Posted on Dec 17, 2009
Sony KDF-E42A10 KDF-E50A10 LCD TV Service Manual
If you wish to get more details about these, check this link. http://electronicshelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Oct 02, 2013 | Sony KDF-E42A10 42 in. LCD Television
Sony KDF-E42A10 6 red flashes and i replaced the thermostat, no change
I have never seen the thermal fuse replacement not fix this problem. What is the part number that you put in the set? Do you know how to use a meter? After you replaced the thermal sensor did the set try to come on at all? or was it the same exact problem as before?
Let me know
Tim
Sep 15, 2008 | Sony KDF-E42A10 42 in. LCD Television
Solid green light but no picture
I think this is a projection set. Sonys are called SXRD type lcd projection . Little diff from DLP types. But they do have a lamp. Unplug set plug back in then turn on . Count blink code. Check lamp also. blink code is 2 digit code. Code will give clue to failure.
Oct 01, 2013 | Sony KDF-E42A10 42 in. LCD Television
Sony kdf-e42a10 green light blinking, followed by solid red lamp light - tv will not respond to power button
Follow instructions in owner manual and remove and inspect lamp to see if shattered inside.
Most of these sets have a 2,000 hour life span on the lamp which is customer replaceable.
Mar 12, 2012 | Sony Televison & Video
Sony kdf-E42A10 red light blinking
see other solution and remove and inspect lamp.
The set will shut down if lamp fails to come on.
Mar 12, 2012 | Sony KDF-42WE655 Television
I have a Sony KDF-E42A10. No matter what setting I choose for wide screen I can't get the picture to fill the entire screen. Any suggestions on how to adjust the picture to fit the screen?
Download the manual if you do not have one from the following url.
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000073092.pdf
The manual on page 53 have demonstrated the different modes. Have you tried these modes?
sonsunny
Jul 02, 2011 | Sony KDF-E42A10 42 in. LCD Television
Black square in middle of screen
You have selected a text option and there is no text available. Also pressing the display button on remote could turn cc and text on or off. the black box is a text option not closed caption. page 70-72 in owners manual might explain better.
Apr 15, 2009 | Sony KDF-E55A20 55 in. LCD Television
Our Sony KDF-E42A10 42 inch LCD TV has yellow hue
Contact Sony. You need optical block replaced. Class action .Sony may cover this.
Apr 07, 2009 | Sony KDF-E42A10 42 in. LCD Television
Crack in the screen 42" sony kdf-e42a10
You can find a new Sony replacement lenticular screen and fresnal screen for a model # KDF-E42A10 from a major Sony distributor at the following links:
Sony KDF-E42A10 Replacement Part Lenticular Screen
Sony KDF-E42A10 Replacement Part Fresnal Screen
Feb 16, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Closed caption text is pale white now instead of bright green
Theres no color option on this set as far as the manual says. It sounds like the Video driver comming out of the microprocessor is bad, so the micro will need to be replace. This is not a user replaceable part so please seek a pro to repair this for you. Sorry i couldnt assist you more with this. Good Luck
Jul 01, 2006 | Quasar VV-1319W 13 in. Combo
Sony KDF-E42A10 42 in. LCD Television Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
