Question about Electrolux Frigidaire Professional Series 24 in. Built-In Dishwasher Dishwasher
The water spinning thing on the top of the inside came off. Can I re-attach it?
You can but mine falls off every time I wash. Unscrew the cog shaped thing. there is a plastic washer inside of it. Place the sprayer back in-it should click into place, then screw the entire thing back on. I got so sick of having to put it back on that I stopped. This dishwasher does not clean the dishes well and I have to rinse them completely before washing. Sometimes the soap doesn't disolve and there are soap chuncks on everything. As well, the top shelf comes apart in the back at one side that I have to put back together after each wash. Plastic is not all it's cracked up to be.
Posted on Oct 15, 2009
My frigidaire affinity will spin when washing but only spin the closes dry when on delegate cycle what could the problem be?
Hello Tony - Often when a unit does not spin it is because the unit cannot properly drain and dispose of the water and detergent solution. Does the drain pump make a humming noise? If so, there may be a restriction in the drain line or siphoning. Otherwise since it is such a complex unit I would recommend contacting a professional to have either the pump or timer diagnose. Also you might want to clean out the coin trap, filter trap, of the unit for extra security. This needs to be completed about every 6 months to prevent any issues.
1. Unplug the unit.
2. Tilt the unit up to where the front feet are in the air and the back feet are still on the ground. Please make sure the unit is propped up safely.
3. Now that the unit is propped up look inside on the bottom right hand side there is a black looking accordion thing. This is the coin trap.
4. Clean the drum out with as much water as possible and have towels ready. The next step you will have the remaining water come out.
5. At the top of the coin trap where it is attached to the drum is a silver spring with a silver screw. Loosen the screw and wiggle the coin trap down from the drum.
6
. Reach inside the coin trap and clean what is inside of it out.
7. Put the unit back together following the same steps backwards
Sep 26, 2012 | Frigidaire Affinity ATF7000E Front Load...
Frigidare FLXG52Rb won't final spin
Does the unit have a drainage problem? Do you notice the unit draining at all? Often when a unit does not spin it is because the unit cannot properly drain and dispose of the water and detergent solution.
Not over use detergent, this can result in oversudsing in the tub, and restricting the tub from turning properly.
That the drain hose is not too long.
That the drain hose is not restricted.
That the standpipe is not higher than 96" from the floor.
You may have defective timer or drain pump.
1. Unplug the unit.
5. Reach inside the coin trap and clean what is inside of it out.
6. Put the unit back together following the same steps backwards
Sep 18, 2012 | Frigidaire FWS833A Top Load Washer
Water leaking from vent hose outlet
Does your User Manual say anything about this being likely to happen?
Sounds as if there is a throw-up of water into this hosing in the spin cycle or some such thing?
Do check your water hoses are tightly screwed. I have seen cases where fine jets of water spray into odd places which cannot be seen when the machine is backed to the wall.
Poppa
http://www.cdbaby.com/cd/poppamadison
Mar 04, 2012 | LG WM2277H Front Load Washer
Machine wont agitate
Could be several things, is the machine filling up with water?
1st thing is the water level switch, inside at the rear of the machine, If water is not detected then the machine won't start.
This is probably the cheapest and easiest to replace first.
Isolate the machine from the mains, lift the whole top lid (insert a flat blade 4" from each side at the front top seam to release).
Lid will tilt all the way up and back.
Switch is rounded about 3" diameter at the back behind the drum, 3 wires with a small hose attached, replace keeping all the wires in the correct places and re-attach the hose.
Does the machine spin - motor OK
Nov 29, 2010 | Admiral AW22 Top Load Washer
Model 23832 Spin cycle doesn't spin
I believe this is the direct drive model. Your clutch is slipping. There is a quick easy fix available that I have used in the past. Remove cabinet from washer. Make sure you know the easy way to do this... 2 screws on top back of washer and 2 holding control panel. cabinet tips toward from of unit and off. Real easy... Remove wire harness from motor under basket. Remove 3 screws holding motor to basket. Remove agitator inside basket. 1 screw holds it in place. Remove entire motor and shaft from unit. Clutch is attached to shaft on top of motor. Pinch spring to remove clean everything with alcohol. Insert #10 washer between cup and spring to give a little more tension. Replace and viola.... all should work well.
Jul 10, 2009 | Kenmore 23822 Top Load Washer
During the final spin cycle, water is leaking inside the machine
You have a problem with the pressure switch cutting in too early before all of the water has drained away from the outer drum
There is either an obstruction in the outlet pipe or pump which is not allowing the water to discharge fast enough.
The machine is then spinning with too much water left in the outer drum added to the water which is being expelled from the clothes equals leaking
Take the hose off the back of the machine and put it in a sink , make sure it is secure and do a rinse cycle
Watch the outlet and make sure it is a strong flow if it is weak then you have probably got an item of clothing stuck in the pipe from the drum to the pump and a strip down is required
One more thing there is a small plastic bottle attached to the back of the outer drum this has tube which leads to the pressure switch
Make sure there is no congealed soap in the Air Bell as it is called
Jul 05, 2009 | Fisher and Paykel WA37T26G Top Load Washer
Water wont drain /wont spin out
  • assuming it is a top loader
  • it sounds like something is stuck in the water pump.
  •  if the water does not drain then it will never spin.
  •  take off the front panel (with a butter knife, push in the two metal clips in the front seam between the top panel and the front panel. this will release the front panel from the machine.
  • the water pump is located on the right side in the front.
  • before removing the hoses attached to the water pump get as much water out of the machine as possible so it does not spill on the floor.
  •  then take off the hoses and check inside the pump thoroughly; even a string might cause the pump to get stuck.
  • let me know if you need more help
Mike
Jul 02, 2008 | GE Washing Machines
Kenmore 90 Series, clothes wet after spin
First thing you need to check is the speed of the spin cycle. As long as you are not overloading the machine, it should spin the clothes pretty dry. the basket drive may need to be replaced. If it is spinning very fast, then check the drain hose, make sure the water is coming out nice and fast. If not you may have a water pump problem even lint clogged inside it.
Nov 29, 2007 | Kenmore 22422 Top Load Washer
Top Arm not spinning on Whirlpool DU1145
It looks like there is not enough water pressure to spin the spray arms. Loss of pressure may be due to various things, like damaged seal, cracked tubes, clogged filters, screens etc.
I suggest you take a look at the technician repair sheet that should be stored inside the front panel at the bottom of the door. Remove that panel under the door with screw driver. Inside, attached to the panel, you should find a troubleshooting guide and solution for technician. But it is easy to follow. Look at the section under "poor wash" and follow its recommendation. I had exact same problem - not enough water pressure. In my case, the chopper screen was clogged and the chopper assemply was broken. I followed the repair instruction above to remove the chopper assembly, cleaned the chopper screen and the washer now is as good as new. I will need to replace the chopper when the part arrives.
Good Luck
/Dara
Nov 14, 2007 | Whirlpool 24 in. Built-In Dishwasher w/...
Electrolux Frigidaire Professional Series 24 in. Built-In Dishwasher Dishwasher Logo
181 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Starnley Johnwells
Starnley Johnwells
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
