Question about Euro-Pro 7500XH Mechanical Sewing Machine
How to oil machine
How to oil sewing machine Model 7132 L
  • 980 Answers
You can only oil the moving parts that you can see, very lightly.
Posted on Sep 27, 2009
  • 496 Answers
Here is a link to your users manual if you lost yours. On page 96 is instructions on oiling your machine:
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0606672.pdf
Hope this helps...
Posted on Sep 25, 2009
Where do you oil a jw5622 sewing machine
every moving joint and everything that slides or spins especially the parts you can't see underneath. Only a small amount.
Google
make model service manual
And also 'oiling make model sewing machine'. There is listing from Singer and Janome, and others.
sewing machine service manual pdf Google Search
Look at this link on oiling and also see the Video tab.
oiling sewing machine Google Search
Sep 23, 2017 | Sewing Machines
Do i need to oil my necchi sewing machine? if so how? i have a model 4825.
The following web site indicates the machine should be "lubricated as needed." So, you should probably consult the owner's manual. Your machine is computerized which means there is usually limited oiling required, perhaps the hook.
Necchi 4825 Review Sewing Insight
Be sure to use good quality sewing machine oil recommended for your machine (NOT 3-in-1, WD-40, cooking oil, etc.)
Instruction Manual Necchi 4825
Jul 25, 2016 | Necchi Sewing Machines
What about Oiling?
If you look at the Oiling Instructions in the owner's manual, it has a picture of where the oil should be applied. Only one or two drops!! It should probably be oiled frequently--about every 8 hours of sewing time. Pfaff probably sells a sewing machine oil for your machine. Just tell them your machine model and they should know what you need. Do NOT use 3-in-1, WD-40, cooking oil, or the old stinky brown stuff from grandma's sewing basket!
Feb 24, 2016 | Sewing Machines
Model UHTJ1277. Where do I put the oil and how much oil?
If it is mechanical machine (NOT computerized or industrial), you can apply 1-2 drops of fresh, good quality sewing machine oil every place that metal rubs on metal. Avoid using 3-in-1, WD-40, cooking oil, or the oil can from grandma's sewing basket!!! Do NOT oil plastic, rubber, leather, or belts! Be sure to place a drop of oil on the bobbin race every 8 hours of use. Clean and oil the machine thoroughly every 40 hours of sewing use.
You should try to find a manual for your machine that will most likely have oiling instructions. Search the internet for: Manufacturer + Model + the word "Manual"
Nov 30, 2015 | Montgomery Ward Sewing Machines
My sewing machine electricity is on but it only growls when i step on the foot peddle. Is the motor froze or what can I do to make it work
Depends on your sewing machine brand and model. If it is an older mechanical (NOT computerized) model. It could very well need cleaning and oiling, as the old oil has solidified and the motor is unable to turn the mechanical parts. Do not continue to force the motor to run as it may burn out.. Consult your owner's manual under the maintenance section for instructions. Use ONLY good quality sewing machine oil, NOT 3-in-1, WD-40, cooking oil, or the oil can from your grandmother's sewing basket.
Aug 30, 2015 | Sewing Machines
How do you oil a model 8077 Janome sewing machine?
Consult manual if you don't have one search the internet with your sewing machine model number...Example...name Model number and free download.
Jul 04, 2014 | Janome Sewing Machines
Required needle for 4oz bonded nylon thread "high-Spec"
a ball point needle size 14 or 16 should suffice
Mar 29, 2014 | Euro-Pro Sewing Machines
I have an EURO-PRO sewing machine model # 6130. I am wondering where you oil this machine, I don't see anything in the instruction manual on this. Should I oil it and if so where?
You can oil all moving pieces that you can see, use a stainless oil for sewing machines. If you want to take your bottom off you can oil and grease the gears under there.
But I caution you to have a sewing machine repair shop do it for you, problems can be created if you oil and lube the wrong things.
Please rate my solution
Apr 01, 2011 | Euro-Pro 801B Sewing Machine
Euro-Pro 7500XH Mechanical Sewing Machine Logo
235 people viewed this question
Top Euro-Pro Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you an Euro-Pro Sewing Machine Expert? Answer questions, earn points and help others
