Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Garage door wont close all the way
My garage door stops abot ten inches before it hits the floor
    President:
  • 3,197 Answers
On the side of the motor unit you will find the 'down limit' adjustment. Turn this in the direction of the arrow printed on the cover. Some tweaking will be necessary.
Posted on Sep 25, 2009
  • 5,603 Answers
The over-force limit is probably being activated. YOu may have a spot on the track that is putting load on the closer. Try MANUALLY moving the door to verify easy motion through complete range.
ALSO verify you don't have a cord that hangs down and triggers the electric eye safety devices. A pull cord can do this but usually the door is reversed when that happens.
You may also need to INCREASE the tension limit on the head if you find the tracks and counter balance springs have no problem.
Why is my garage door suddenly reversing when going down?
Deb, that reversal is a child safety device - if the bottom edge of the door detects contact with any object, it'll immediately reverse so it doesn't kill a child. Or a cat, dog, whatever.
The opener mechanism should have a stop switch that prevents the door from closing hard against the floor - that stop switch needs to be adjusted so that the door will stop JUST before hard contact. That'll take care of it "bouncing" off the floor & reversing. As to it reversing before it touches the floor... examine both guide rails closely to see if there's any obstruction that the door's bottom edge may be contacting to trigger the child protection reversal switch.
Aug 04, 2014 | Sears Craftsman LiftMaster Chamberlain...
Erratic garage door opener
It is an adjustment problem. Any obstruction and the door goes up again. So try adjusting again but don't leave space to invite rodents that will cause damage to car wiring. I am just going thru that.
Dec 04, 2013 | Craftsman Sears Liftmaster Garage Door...
Garage door will not stay down when closed
Sounds like the down limit is out of adjustment. Turn the Down limit switch opposite the direction of the arrow a quarter turn and try again. Repeat until the door stops before hitting the floor then fine tune to shut off at the floor.
Aug 14, 2011 | liftmaster Garage Door 1/2 Hp
Remote will open door when remote is hit to close door the light flashes and will not close. The wall unit will close door but the button must be held and released when the door hits the floor.
Make sure there is nothing tripping the IR beam at the bottom of the door. The beam is bounced back and forth between its source and a mirror about six inches off the ground. If something breaks the beam the door will go back up as a safety precaution. Also check to make sure there is nothing directly under the door that stops the doors from completely closing. Even a small rock can send the door back up.
Good luck
Dec 09, 2010 | liftmaster Chamberlain Garage Door Opener...
The garage door closes and then opens up again, I have to close it several times before it secures. There are no obstructions. Is this a sensitivity problem?
More than one thing can cause this type problem.
If the main light flashes 10 times when the door reverses it is a door sensor problem. Make sure they are pointed at one another and the small light on each one is not flickering ever so slightly.
If the door reverses when it hits the floor it is a sign that the door is traveling a bit to far. The adjustment for this is on the side of the motor unit. Turn the 'down limit' in the opposite direction of the arrow printed on the cover. Some tweaking will probably be necessary.
Jul 06, 2010 | Sears Craftsman LiftMaster Chamberlain...
Garage door only raises about two inches then stops.
Check the door springs and also remove the cover from the motor unit and check the drive gear. The door spring could be broken or the drive gear may be stripped.
The sensors only work when the door is closing.
Jun 15, 2010 | Sears Craftsman LiftMaster Chamberlain...
Garage door not closing completely
lubricate track and drive chain or screw if it resists moving too hard it thinks it hit something and will back up
Jul 09, 2009 | liftmaster Chamberlain Garage Door Opener...
Craftsman garage door does not open all the way stops @12 inches
You most likely have a broken door spring. Release the door from the opener and try lifting it by hand. Look above the door for the springs.
Mar 21, 2009 | Sears Craftsman LiftMaster Chamberlain...
After opening, my automatic garage door creeps back down a bit
There is a sensitivity switch for both directions, open and close. If you access the garage door opener in the ceiling, you will see two adjustment screws for calibrating these. I would highly recommend following the instructions in your manual, as these are life safety adjustments! Your sensitivity for closing the door is adjusted to the positive. You just need to back it off a little. Place a 2x4 on the floor of the garage where the door comes down. and when the door hits the 2x4, it should automatically come back up. If not, you adjusted it too far. Hope this helps. and remember, check the manual for your specific adjustment procedures.
Mar 13, 2009 | Sears Craftsman LiftMaster Chamberlain...
Door wont close all the way
Try adjusting the down force, Turn screw an eight of an inch.
Dec 15, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
169 people viewed this question
Top Sears Building Materials Experts
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
