Question about Linksys Wireless-G Broadband Router
Password for linksys
How do i create a password for my wireless linksys? i cant seem to even find it on my computer. i think others are using my wireless connection with out permission. thanks!
  • 556 Answers
There is an administrative password to keep people from changing the router configuration.
And then there is wireless security (encryption with a passphrase or key -- like a password both your router and your wireless adapters know and others do not) to keep others from using your router----
First you must choose a common encryption strategy for your home networkpassword for linksys - 1.gif. (Yes I am assuming Home Network)
In most consumer routers you activate encryption on the wireless1.gif services of the router. After doing so you must also actiate encryption services on the wireless adapters1.gif that communicate with the wireless router. The names of the encryption services in the wireless router and wireless adapter are WPA and WEP. It is important to assure all wireless adapters to connect to the wireless router can handle the encryption chosen because the router will only perform one. There are options within each technique such as the number of bits of the keys -- the longer the better but only as long as the shortest device can support. WPA is preferable to WEP because it was designed to correct weaknesses in the WEP standard and implementation. However if there is even a single device to be connected that cannot do WPA you must do WEP or replace the device WPA in home systems often have a couple of other attribute being WPA-PSK and algorithm of TKIP -- which again every wireless adapter and the wireless router/access point must support.
To procede further in a sane manner you need to identify all wirpassword for linksys - 1.gif devices1.gif that will participate password for linksys - 1.gifur wireless network1.gif and determine their capablities for encryption. This is generally done searching manufacturer websites under support looking for user guides and firmware updates. Sometimes a devices capabilities in the manual require firmware updates to be true for the device. Once that is figured out the standards for your network can be set and the actual implementation can proceed. You will probably want a working wired computer to maintain access to the outside world for assistance if anything goes wrong. You also want to track your changes and know how to back things out incase things become too difficult.
If you have any additional questions or would like to a review of your plan or assistance determining a plan gather up the appropriate manufacturer's names and models and I will assist as time permits.
I hope this helps.
Posted on Dec 16, 2007
How do you set up privacy so no outside source can use it with out my permission?
open a webpage and type in 192.168.16.1 in the address bar......user name is either left blank or admin.....password is admin .....and set up a security code is thats not the correct address.......try 192.168.1.1
Aug 03, 2011 | Linksys Wireless-G WRT54G Router
How do i set up password to keep anyone from using my wireless connection
Turn the unit on and open a browser window on your computer. Be sure that you've selected the Name of the router, default is linksys, as the network that your computer is connected to. Browse to the Admin page of the router by typing in its IP address, default is 192.168.1.1. You should see a logon screen. The unit should ship with a default password, which is admin. That is, you leave the username field blank and type the word 'admin' (no quotes) into the password field. (Once you are logged in, you can change the password for logging into the router thru Administration --> Management. You should see a two boxes to verify the new password that you would like to create.) For creating a password for the secure Wireless connection, go to Wireless --> Wireless Security. To set up the Wireless security, tho, I think you'll have to connect with an ethernet cable. You can then walk thru the setup. Use WPA2 as the security, if possible.
Jun 17, 2011 | Linksys Wireless-G WRT54G Router
Forgot my password on my linksys wireless G broadband and i cant sign in from my laptop
yippers, that happens, use your cell phone number next time. So you need to log into the router and create new wireless security password, and change channel to 11 or so and free up interference with wireless land line phones.
Oct 10, 2010 | Linksys Wireless-G Broadband Router
I put a password on my linksys router and cant seem to get internet access to my other computer laptops and ipods even if we put password what am i doing wrong
You will need to check the wireless settings of the router.
If your network is secured then make sure that you are typing the correct network key.
also make sure that the DHCP server is enabled on the router.
is there any computer connected to the router ?
what is the operating system on the computer ?
WPA2 security type will not work with windows XP.
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
Click here for step by step instructions
Mar 14, 2010 | Linksys Wireless-G WRT54G Router
How do I reset the password on a linksys 200
Hold the reset key down with power on for 15 seconds.
In addition, there's an error in some copies of the user manual, the correct login is:
username: admin
password: admin
hope this helps if can help further let me know
Oct 29, 2009 | Linksys WRT54GX2 Wireless-G Broadband...
Linksys Rangeplus wireless adapter not connecting
hmmm....
you are getting an incorrect ip address so what we need to do is to reconfigure the wireless profile,
open up the linksys utility and go to the tab that says profile,you will see the profile that you have configured earlier,
click on the profile and click on remove once the profile is removed ****,go to the tab that says site survery...
click on your network and then click on connect it will take you through a setup screen,then choose the security whether it is wep/wpa and down below choose the bit type if the security key has 10 characters then it is 64bit and if it is more than 10 characters then 128bit....donot put the passphare to generate a key,directly punch in the number..
****1 more step you can perform before creating a new profile is go to start,run in the box type in cmd and then open the black box then type in netsh winsock reset catalog and then hit enter it will tell you to restart the computer,restart the computer and then try creating a new profile...make sure the internal wireless card is disabled when you create a profile..
hope this works for you...
vedhick
Feb 06, 2009 | Linksys Rangeplus Wireless Pc Adapter
Limited connectivity
You have to turned on DHCP in your router settings. i think its under the General TAB if its a linksys router
Feb 03, 2009 | Linksys Wireless-G Broadband Router
Linksys Wireless-G Broadband and Router 2.4 GHz
First, you will need to select a Security Mode. Think of these modes as different languages, I can't tell you which one to choose, because depending on how new your computer(s) wireless card(s) are will determine how many languages they can "speak" with the wireless router. WPA2 is stronger than WPA, which is stronger than WEP. The easiest way to determine is to create a new wireless connection on your computer and see in the drop down list which modes your computer(s) cards can speak. You are looking for choices like WPA2, WPA, WEP (note which ones). Cancel out of there once you have determined the modes your computer(s) card(s) are capable of speaking.
In order to make the changes to your wireless router you will temporarily need to connect to it directly through an ethernet cable. Once you have run the cable from your computer to your wireless router...
In your web browser go to the URL http://192.168.1.1/. This will take you to a popup box which asks you to enter a username and password to login to your router.
On older LinkSys routers, the default username is blank and the default password is "admin". On newer Linksys routers, both the default username and the default password are set to "admin".
Once you are past the login screen, you are able to reconfigure the LinkSys router. You want to go to the Administration tab and change the Router password to something else (write this down) to keep others from accessing your router. Click "Save Settings".
Next goto Wireless Tab -> Basic Wireless Settings and change the Wireless Network Name (SSID) to whatever name you would like (ex.- "keepout"), be sure to write this down on note as your SSID, and set Wireless SSID Broadcast to "Disable", then click "Save Settings".
Now goto Wireless Tab -> Wireless Security, select the highest security mode you determined your computer(s) are capable of speaking earlier and create a key (write down) and click Save Settings.
Disconnect the ethernet cable from you computer and router. Now back in your computer(s) you will need to either edit existing wireless connection or create a new wireless connection and enter the SSID, Mode, and Key you created earlier.
A knowledgeable hacker could still penetrate your network, but the hassle usually is almost always more trouble than it is worth and they will move on to plentiful easier targets (like you were).
Jan 27, 2009 | Linksys Wireless-G Broadband Router
Password protect my wifi
you have to use the webstyle interface to accress the settings on the router.. click start then cmd... in the new window type ipconfig..type the default gateway address in your internet explorer browser it will look like 198.162.1.254 once you do that you will be in the router and can set up wep encryption.. you will need to add that new key to every computer and device on your network.. wireless printer, laptops .. everything.. keep the number you create safe so you dont have to do it all over again if you cant find it someday.
Jan 19, 2009 | Linksys Wireless-G Broadband Router
Computer disconnects from Internet when my neighbor is using his computer
the Lock means that he has a secure network or he has the WAP enabled.. Can the two networks interfere? Yes. The two networks will "fight" over which one will your computer use to connect.. and sometimes you will connect to his network and therefore get no internet or limited connectivity.. You can make sure that your computer only connects to your network by permanently removing his SSID from your settings.
Mar 25, 2008 | Linksys Wireless-G WAP54G 802.11g/b...
Linksys Wireless-G Broadband Router Logo
97 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
