Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
How do I fix uneven cutting? - Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
    Scholar:
  • 138 Answers
1. level the deck
2. make sure the blade[s] are not bent
3. make sure the mandrel housings are not broken
4. if the deck is bent, find a shop that has a deck straightening tool and have them straighten the deck
5. make sure the blades are attached properly
Posted on Sep 26, 2009
Why does a riding lawnmower cut unevenly
Sounds like your cutting blade is crooked, loose, or bent. Take it to your nearest small engine repair shop.
Sep 05, 2014 | Garden
How do i level the cutting deck on a murray select 13.5 hp 40
thge mower has 2 drop arms with a searies of holes and the mower deck has 2 arms with a searies of studs you move the studs up or down the same amount of holes and fix in place with cotter pins
Jul 25, 2012 | Murray Garden
I have a problem leveling my mower deck. I level it at the sides and front .I use the mower and it cuts uneven. mower is deck is out of alignment. less than 1 hour on it.
The deck could be bent, or you will probably have to level the back of the deck as well. Another thing to check is the air in the tires, this can cause an uneven cut. Although the tire may look pumped up, with the weight of a person on the tractor can cause an uneven cut.
Aug 10, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Craftsman LT1000 mower deck cutting uneven. How
try biger wheels on the low side???? ha ha?
no you hit and bent the bed hight ajusters you may need to take the mower bed off to fix this part,,,,,
look as were the morer hight ajuster is,,, is it in the same place on both sides,,, my gess is its not
the bed has a tilt on it,,,they dont cut down trees very well do they?
Jun 11, 2010 | Garden
Cuts uneven, lawn looks terrible. Missing half
Are your blades upside down? Mower deck level?Proper air pressure all 4 tires?Correct blades for the diameter of cut? Deck bent? Deck hangers bent?
May 28, 2010 | Garden
I have a Craftsman 42" rider cuts uneven
Check your tire pressure first, uneven tore pressure will cause this problem.On the rear of cutting deck on both sides there are height adjustments, if your deck has a rear roller this also can be adjusted to compensate,If your a stout person sitting on tractor can cause unevenes.
Jun 25, 2017 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Uneven cutting
Make sure the wheel adjustment is the same at each wheel. Also checl that blade is secure.
Apr 07, 2010 | Toro Lawn Mower With Toro Power Tools
My deck cuts shoter on the rt,ie uneven
Check your tire pressures:
10 psi. for rear tires.
14 psi. for the front.
Note that according to MTD:
Making sharp right hand turns. Twin-blade mower decks are designed with the discharge on the right side and two side-by-side blades. The side-by-side twin blade decks have the left hand blade positioned slightly forward and in front of the right blade. This provides cutting overlap when traveling in a straight line. As a result, the tractor should mainly operated making primarily left hand turns when cutting. During left turns this cutting overlap is maintained. If turning right when, it is possible to negate this overlap and leave an uncut strip.
May 31, 2009 | Mtd LAWN MOWER PART # 683-0439A DECK...
Cuts lawn uneven, one side shorter than other
Was it cutting uneven before you changed blades? If so, you may not have gotten the blade on the shaft correctly. There is an adjustment in the center of the deck hanger on each side. You can turn the 9/16 nut up or down on each side to level it out.
May 28, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman 42 inch riding lawn mower is not cutting evenly
The first thing to check is your blades. If one is bent, it will never cut even. It happens a lot hitting roots, antbeds, etc. Mulching blades will bend easier than a straight blade. It's best to take them off and lay one on top of the other to see if they're bent.
May 25, 2009 | Craftsman 42 in. Precision Cut Plus 24hp...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
179 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dean Gruber
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
