Question about HP Designjet Z6100 InkJet Printer
HP Z6100 error code 01.2:10
HP Z6100 error code 01.2:10when start the printer this code appear
how to solve this problem
thanks
aamar
    Scholar:
  • 96 Answers
01.2:10
Problem
Description:
ISS PCA problem.
Corrective Action: Try the following:
�� Switch the Power OFF from the back of the Printer and disconnect the
Power cord. Reconnect the power cord and power On the Printer.
�� If the System Error continues, replace the Ink Supply Tubes and Trailing Cable.
Posted on Sep 28, 2009
HP DESIGNJET Z6100 ERROR CODE 21:13
Posted on Jul 27, 2010
Error code 43:10 on HP Z6100. What do I do to fix it?
This error indicates that the vacuum fan is stopped. 97412466-7fff-4e2d-bb4c-526bd4f30ed9.jpg
Oct 07, 2014 | HP Designjet Z6100 InkJet Printer
HP DesignJet Z6100 Error 43:10
Hello. The error message indicates a vacuum fan failure. The problem can be solved by replacing the Vacuum Fan Assembly.
Q6651 60286 HP Designjet Z6100 Vacuum Fan Assembly
The service manual with instructions can be downloaded from: http://www.lpscomputer.com/collections/designjet-z6100-parts
Jul 22, 2014 | HP Designjet Z6100 InkJet Printer
Code error 24:10
ISSUE: The printer front panel displays System Error 24:10. The printer may not print, and in rare cases, ink may leak from the printer. SOLUTION: HP is investigating a recent issue with some HP 91 Ink Cartridges in HP Designjet Z6100 series printers. A combination of factors related to handling during shipping have resulted in a very small incidence of HP 91 Ink Cartridges with the System Error 24:10 error. When the problem occurs, the printer front panel displays System Error 24:10 and the printer may not print.
HP regrets any inconvenience this may cause. Please contact HP Customer Support for assistance. Click here for information on how to contact HP support at http://welcome.hp.com/country/us/en/wwcontact_us.html.
Feb 15, 2014 | HP Designjet Z6100 InkJet Printer
Hp designjet z6100 42:10
error code 42:10
Electrical fault in Carriage Motor or starting the Scan Axis or Homing Scan Axis.:
it is not uncommon to find that the encoder is the fault behind the error code,
in the User manual there is a procedure for Cleaning The Encoder Strip. you should follow these steps carefully
.A Z6100 User manaul is available to download at HP.com link as follows:-
http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?cc=us&contentType=SupportManual&prodSeriesId=3338748
the user manual is located near the bottom of the page
Sep 25, 2013 | HP Designjet Z6100 InkJet Printer
Hp z6100 plotter error code 46:03
System Error:
46:03
Problem Description:
Primer servo shutdown.
Corrective Action:
Try the following:
1. Switch the Power OFF from the back of the Printer and disconnect the Power cord. Reconnect the power cord and power On the Printer.
2. Replace the Primer Assembly .
3. Replace the PrintMech PCA .
4. Replace the Interconnect PCA .
Feb 06, 2013 | HP Designjet Z6100 InkJet Printer
Error code: 41:10
The "paper axis" motor needs to be replaced.
Contact HP if the designjet is still on warranty.
Otherwise contact a technician to do the work.
Mar 22, 2012 | HP Designjet Z6100 InkJet Printer
Hp z6100 turns itself off! no error code just switches off! Makes loads of beeps and sounds like a fax machine! Help
it contains m/b like desktop with cpu,ram,hdd etc check ram cpu fan & power supply refix them after cleaning ...............may b ur problem will be resolved.
Jul 30, 2010 | HP Designjet Z6100 InkJet Printer
Hp designjet z6100 error code 21 : 13
Service Station error. Switch the power OFF from the back of the Printer and disconnect the power cord. Check the Primer Tubes. Reconnect the power cord and power On the Printer. Make sure that the Service Station path is clear. Remove any visible obstacles (e.g. screws, plastic parts, etc...) restricting the movement of the Service Station. If the System Error continues, replace the Service Station. If the System Error continues, replace the PrintMech PCA
Jul 27, 2010 | HP DesignJet Z2100 InkJet Photo Printer
Error code 03:10
see it this site problem solved simple way
http://cluetechnologies.com/index.php?topic=689.0
Jul 01, 2010 | HP Designjet Z6100 InkJet Printer
Error Code 08:11 HP z6100
The 08 portion of the code indicates FRONT PANEL. the :11 is an action code requesting RESEAT, CLEAN meaning you should reseat the connectors at the display and on the other end at the electronics. Cover removal is explained in the service manual which can be downloaded here: www.lpscomputer.com/ec/manuals.htm
Oct 28, 2009 | HP Hewlett Packard Designjet Z6100 InkJet...
HP Designjet Z6100 InkJet Printer Logo
2,073 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
