Question about Cell Phones
Opening the Samsung G89
I can't remove the cover to install my battery and SIM card.
Does this cell phone have a Sim card? If so, how o you access it?
yes it does have a space reserved for the sim card, typically accessed after removing the cover & battery.
samsung brightside sim card Google Search
Jan 25, 2015 | Samsung Brightside Mobile Phone
Install sim card
typically the SIM card slot is located under the battery. you would remove the back cover, then remove the battery. you should see place to insert the SIM card. it is usually identified by looking for a metal square about 3/4" H x 1/2" W and the plastic where the SIM card is inserted has an 'engraved' image of a SIM card and the correct orientation. without knowing the exact model, it is difficult to give exact information. another resource is to do a google or youtube search asking the question you posted along with the phone model number. hope this helps!
Mar 29, 2014 | Samsung Galaxy Cell Phones
How to install sim card
For most of the phone,sim card will be install at the back of your mobile phone. These are the steps on how to: 1. Turn off your mobile phone. 2. Remove the back case gently. 3. Remove the battery as well. 4. Theres instruction at the back of your phone on where to place the simcard and on how to insert it. 5. Make sure you properly inserted the sim card so you wont recieve offline mode error. 6. Plug back the battery. 7. Return the back cover. 8. Turn on your phone,then your good to go. remember that there are some phones wherein the simcard slot is on the side part of the phone. for this kind of phones,all you have to do is just lift the cover of the simcard slot then slowly insert the sim properly then turn on the phone and your good to go.
Dec 05, 2011 | Samsung Cell Phones
Can you please advise me on removing the back to fit my new sim card Regards
To remove the battery and/or cover from the phone, follow the steps and diagrams below:
To remove the cover, lift up (1) press and slide the section of the phone upward.
Installing the SIM card, make sure the gold contacts of the SIM card are facing down before attempting the insertion. Slide the SIM card into the SIM card socket.
Note: The data stored on the SIM card can be damaged if the card is sctrached or bent during installation, so be very careful when installing the SIM card.
Slide the battery into the compartment so that the tabs on the end align with the slots at the bottom of the device and the metal contacts line up with the those on the device. Lightly press down on the battery until it slips into place
Lastly, Place the battery cover onto the back of the phone (the tabs at the top of the battery cover should interlock in the body chassis). Lower the battery cover down until it is flush with the phone.
Thanks.
Jun 15, 2011 | Samsung Galaxy S GTI9000 Smartphone
Cannot find sim card. I need to remove i from an old phone. It is a Samsung a40
First you should switch off the mobile. Press down the bottom end of the battery cover and pull it out. Remove the battery by lift it at each end. Remove the SIM gently form the SIM card holder, pinch the card gently on each side and slowly slide it out to prevent damage.
Apr 21, 2011 | Samsung Cell Phones
Samsung Star GT-S5230 Unlocked Phone with Full Touch Screen Quad-Band GSM Bluetooth, 3.2 MP Camera, have a card slot to put a sim card?
The sim card is inserted above the battery which is located on the back of the phone. The attached photo shows what you will see under the battery cover. First, turn the phone off. To remove the battery, start by removing the battery cover which is the back cover of the phone. Press on the back cover in the center next to the camera and pull the cover down towards the bottom of the phone. The cover should slide off. Slide the sim card, face down with the "notch" on the top right side of the sim up underneath the small metal receptacle designed for the sim card. If you do not see the receptacle, look for an etching of the sim card on the phone that is above and to the right of the sim card receptacle. wickerjk.jpg
Mar 02, 2011 | Samsung Star GT-S5233 Cell Phone
I can't open my samsung G89 to put my sim card
TURN THE PHONE OVER WITH CAMERA LENS UPWARDS, PUSH THE TOP PART OF THE BOTTOM AND THE BACK COVER SLIDES UP. DO REVERSE TO CLOSE,
Sep 06, 2009 | Cell Phones
How to unlock samsung SGH-A411
If it's the phone lock (not the SIM) you can try this:
Switch off phone, remove cover, battery and SIM card.
Replace the battery and switch on phone.
When phone ask for SIM card enter the following code -
*2767*3855#
Note this will clear the phone memory so you may lose a few things.
Next switch off and replace the SIM card, battery and cover.
Hope fully this will work.
Jul 08, 2008 | Samsung SGH-R225m Phone
Sim card installastion
1) Remove the back cover
2) Remove the battery
3) Look to the bottom of the battery compartment and find SIM card slot. The slot will be located between the silver metal and black plastic edge. Slide SIM card into this slot with the notch on the SIM to your bottom left. Slide in until it is flush with the edge of the black plastic.
4) Install battery
Replace rear cover.
May 31, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
Cell Phones Logo
268 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
