Question about Kenmore Dryers
Door switch broke, how do I get access to the switch? Model 11072602100
  • 51 Answers
Remove lint screen/ remove 2 screws/ pull top of dry to you and up at the same time/ the switch is held in with 2 scews on the door side
Posted on Sep 27, 2009
Whirlpool stylemaster 4213964 washer will not drain because door sensor broke. Can this piece be repaired/replaced easily?
This is probably mid range difficulty. I could not find specifics on your model (most Whirlpool stylemaster washer model numbers .. at least in the USA ..start with "LA")
Regardless....here is a link that will give you an idea of what is involved for a top loading machine. The challenge is getting access to under the top deck of the washer to access the switch. There is usually a combination of unbolting/unscrewing/prying to get access
How to Replace the Lid Switch Lock Assembly on Top Load Washer Repair...
Helpful?
Good luck on your troubleshooting
Feb 17, 2018 | Whirlpool Washing Machines
Fridge light not working
door light switch Need full model # for better idea .
but normal switch should be at bottom of door or at hing side of ref
some model have at top it may be broke off and thats why you don't see it send us a full model number we will find for you
Feb 28, 2015 | Hotpoint Refrigerators
Dryer light stays on when door is shut nd wont run
check the door switch,i don't work on lg but on any other dryer if the wsitch is broke the dryer won't start and if the light is on the switch shuts off the light and dryer will start.if you send the model number i can look up the switch for you.open the door and look around the frame where the door closes into,there should be a push button switch or a little paddle that the door hits,when you push in on the switch it should make a clicking sound or i've seen the paddle broke off.hope this helps or if you removed any wires to the door switch you might of wired it wrong
Mar 30, 2013 | LG Dryers
I have a Kenmore 500 series dryer. The dryer just stopped working but the light stays on when the door is closed.
the door switch is broke.when you push on the paddle of the door switch the lite should go out,if you don't see the paddle it most likely broke off,you need to send the full model number next time,it will start with 110.or similar.the door switch is a safety so the machine won't run until the door is closed,if the switch is broke no power will go to start the dryer
May 10, 2011 | Kenmore 500 6953 Dryer
My dryer light will not shut off even when door closed and it will not start up when in push start button it does a rapid beep
is the door switch broke?first what kind of dryer and send the model number,when the door closes it hits the door switch and shuts the light off,the dryer will not run if the switch is broke,it's like trying to start the dryer with the door open if the switch broke.
Apr 25, 2011 | Dryers
Front drivers door does not lock or open through central locking however all others work fine
possible bad actuator ,wiring/connection problem,switch,actuator rod disconnected[clip popped off or broke-u can test power to switch but for the others need to remove door panel to access the lock system
Feb 02, 2010 | 2006 Volkswagen Golf
How do I replace the door switch button?
unscew & raise the top panel to gain access to the switch
easy fix!
Jul 21, 2009 | Washing Machines
The door handle on the dryer broke,
yes you will need to open the door and remove the screws around the inside of the door and then the outer skin will pull off and you can access the door handle screws
Jan 31, 2009 | Kenmore 82822 Electric Dryer
Dishwaher will not start a cycle
if your having to wiggle or move the door to get it started then its your door latch/switch.you can take apart and inspect or just get new ang install.God bless ,tom
Jan 04, 2009 | Kenmore 15129 Built-in Dishwasher
Kenmore elite quiet pac 9
unplug dryer, then take the top off and check your connections to door switch.i believe this model has a broke belt switch.open the bottom with the machine unplugged and reach inside and see if the belt is broke.if it is then replace the belt.
Nov 03, 2008 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
29 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
