Question about Scotts Lawn 73740 SPDY GREEN 3000 B/C S 3 EA 13610498
How do i calibrate my scotts speedy green 3000 broadcast spreader?
    New Friend:
  • 18 Answers
From the OEM Scotts SpeedyGreen 3000 Broadcast Spreader Owners Manual: Calibration Your SpeedyGreen 3000 spreader was calibrated at the factory. You may check the calibration as follows: 1.) Adjust the micrometer setting to 2. 2.) Squeeze the trigger against the handle. 3.) The Calibration line engraved in the Green casing above the top of the shut-off plate should be flush with the back edge of the hopper opening. 4.) To adjust alignment, use a small wrench to turn the black calibration screw at the lower end of the control wire leading from the micrometer rate setting barrel.
Posted on May 05, 2017
SOURCE: lost manual
I have a Scotts speedy green 3000. Got it $5 used. I just called Scotts, and they are sending me a manual. But, they told me how to calibrate it. First, you need to know if you have the same "version" as I do. Apparently they made the same model more than one way. I'm told I have a newer one. The way the Scotts rep differentiated was by the wheels. I have all black wheels with orange hubcaps. Older models have orange wheels. If you have the model I have, then do this to calibrate the spreader:
1. On the black slide that comes up when the handle is pulled to open the spreader and releasing product you will find a curved line about 1/2 and inch from the top.
2. Set the spreader to a setting of 2 on the handle.
3. When you pull the lever as if you were releasing product, the indented black line should line up with the curved part of the green hopper at the top of the opening.
4. If it does not align, then you need to adjust the cable that run from the handle down to the hopper door. This is done using pliers of wrench by turning the square nut at the bottom of the cable. It's trial and error at this point.
Mine was off by 30%.
Good luck
Posted on Aug 02, 2010
woobie dog
  • 1273 Answers
SOURCE: lost agitater for my Scotts Spreader
I replaced mine with a clip-in cotter key, the kind they use for farm implements to keep a pin in place. I bought a stainless steel one at Lowe's for ~$1. Works at least as good as what I had.
Best regards, --W/D--
Posted on Aug 08, 2009
SOURCE: I have a Scotts Accugreen 3000 Drop Spreader. How
I found drop-rate tables at http://www.vigoro.com/ProductCategories/WeedInsectControl/SummerFertilizer/ProductDetails/Spreader+Settings.htm and http://www.bayeradvanced.com/media/productlabel/502840A_label.pdf. I don't know how accurate they are, but they are consistent with one another so I'm using them :)
Posted on Mar 21, 2010
  • 6 Answers
SOURCE: How do you calibrate a Scotts Speedy Green 2000
Simple. Assume they are shipped to store properly calibrated. (Probable).
Go to store, set a unit on 8 (Mid-range).
Use a small straight-edge ruler to measure the travel from cosed to open.
Go home, set yours the same, using the attqachment of the wire to the slide mechanism. (If you can't figure this out, you should just buy a new one.)
Posted on May 02, 2010
  • 63 Answers
SOURCE: What is the setting for spreading 4 lbs per 100 sg
6 or 7
Posted on Jul 25, 2010
I have an older rotary scotts pro turf spreader and dont know what setting to put it on for fertilizer because the settings are letters not numbers how do i know what setting to put it on?
try this:
After doing a search I found this:
From Lesco website
For 18-24-12 %50 PPSCU
Product Application Rate:
*LBS PER 1000 SQFT 4
Coverage:
* 12000
Craftsman 3
Craftsman Drop 7
Cyclone 4.25
Earthway 14.25
Lely 4.5
LESCO HD-1 7
LESCO R-94 7.5
LESCO Rotary (80# & 100#) 15
Ortho 3
Precision 6
Red devil 6
Republic 3
Scott's Accu Green 7.25
Scott's Easy Green 26.25
Scott's R7- X F.5
Scott's R8-A J.5
Scott's Speedy Green 1000 6
Scott's Speedy Green 2000 7
Scott's Speedy Green 3000 6
Spyker 4.5
True Temper 1500 \ 5000 5.5
Vicon 28
_________________________
I was married by a judge. I should have asked for a jury.
-- Groucho Marx
Oct 20, 2010 | Scotts Company Garden
Have Scotts Edgeguard DLX. The fertilizer is from Intermountain Farmsers- The option for the Scotts brand is Scotts Speady Green. They give three options the 1000,2000 and 3000. Which option is teh...
I realize this is an older question but in case anyone has a similar question The Scotts Edgeguard DLX equivalent would be the Speedy Green 3000 suggested setting.
Oct 11, 2010 | Scotts Company Scotts Lawns Edgeguard...
Speedy Green Parts
Replacement parts for your model can be found at amazon, click here and take a look: Amazon com scotts lawn parts. I hope this was helpful. Cheers
Mar 18, 2010 | Scotts Lawn 73740 SPDY GREEN 3000 B/C S 3...
Need spreader settings for Scotts Speedy Green 3000
I found this:
Coverage:
* 12000
Craftsman 3
Craftsman Drop 7
Cyclone 4.25
Earthway 14.25
Lely 4.5
LESCO HD-1 7
LESCO R-94 7.5
Ortho 3
Precision 6
Red devil 6
Republic 3
Scott's R7- X F.5
Scott's R8-A J.5
Spyker 4.5
Vicon 28
Jul 21, 2009 | Scotts Company Garden
Scotts 3000 spreader needs calibration?
I found the manual that came with the spreader.. recalibrated it and it works fine.
Apr 28, 2009 | Scotts Company Scotts& Accugreeen 3000...
Lost manual
Good luck
Apr 19, 2009 | Scotts Lawn 73740 SPDY GREEN 3000 B/C S 3...
Scotts Lawn 73740 SPDY GREEN 3000 B/C S 3 EA 13610498 Logo
6,065 people viewed this question
Top Scotts Lawn Garden Experts
lnbn1975
Steve
Level 1 Expert
Nick Olsen
Are you a Scotts Lawn Garden Expert? Answer questions, earn points and help others
