Question about Insignia IS-LCDTV32 32 in. Television
I can not get the cable at my apartment to work without a cable box. When i go to the menu it does not show cable just the others. Why wont the tv detect the cable
Screen stays blue and wont show the picture
TV may be on the wrong input and that will give you a blue screen. When you turn the TV on and the screen starts lighting up it should show on the screen what input the tv is on. If it is not on correct input change input with the TV remote or buttons on the tv. If it is on the correct input try a power cycle on the cable box, just unplug the cable box power cord for a few seconds and then plug it back in. If neither of these solve the problem describe how the cable box is connected to the tv.
Mar 16, 2014 | Mitsubishi WS-55513 55" Rear Projection...
The tv worked fine. The tv is on but it is not showing any picture it wont even show me the menu. what do i do?
Try reconnecting the wire from the cable box, or satallite, to the tv, if not try giving it a good wack
May 06, 2012 | Hitachi 50VG825 TV
Unable to view TV programming on TV, able to utilize set for viewing DVD/VCR movies. Cable company says their Cable Card is 'OK' and the TV needs updates (assume software) in order to work correctly with...
U get a channel numder and menu screen do show up?Not the tv,it the incomming broadcasting signal cable plug in or the cable box itself have problems.Tries unplug,replug the tv and the cable box back in like about an hour later.The tv will reset itself to the factory setting and the cable box should upgraded it softwares.Should work now.If have the same problems,tell the cable company change the cable box or check the incomming broadcasting cable wire with another tv,see the incomming broadcasting signal cable wire,with a new cable box,see if it work.
Oct 21, 2010 | Toshiba 46HM95 46" HDTV
I have a JVC tv model AV 27495. I hooked it to the cable with the cable cord. I can only get cable 2 channel. I can't access any channels. What do I need to hook into the cable? Do I need a box since...
Yes, with the Direct TV box it did all the tuning and your TV had only to be on one channel, normally ch 3 or ch 4. Now that it is not there any more your TV tuner must do the work. You now will have to tell the TV to search for channels. Use your remote and TV menu to do this. You will be able when the search is complete to see some of the cable channels but other premium cable channels you won't be able to see without a cable box.
Sep 12, 2010 | JVC Televison & Video
Hookup wrong? I can't get the menu to come up for the VR375
New HD tv. Have digital cable box connected to tv., cable box connected to DVD recorder, but can't get setup menu to come up on tv screen. I had a similar problem. I have a HD tv connected to a digital cable box. I hooked up the DVD recorder with the wires it came with, but it would not play or give me the menu. However it was correctly hooked up. So the next day I connected a HDMI wire from the DVD recorder to the tv and everything works now.
May 24, 2009 | Samsung DVD-VR375 DVD Recorder/VCR
Cable channels wont program above 27 w my basic cable
Hi classmom2,
I will be happy to help.
You have probably tried this but I will go over it anyway. If it dosn't work we will try something else.
From the video menu on the tv, select the tuning band of CABLE not AIR. Then do a Auto-Channel Search.
From what I gather you have basic cable without a cable box correct?
Let me know what you find and we will go from there.
Lone99star
Jan 24, 2009 | Sharp LC-26D7U 26 in. HDTV LCD Television
How to remove LG LST-4100A
To remove the LST-4100A commercial control interface from the television you need to follow the commands below.
1. Power on television.
2. Press and hold "MENU" for 10-15 seconds.
3. Quickly press "2-6-6-3" and then press "ENTER"
If you have done everything properly, it will bring up a small menu in the top left hand corner of the television. Kind of a hidden menu.
4. Arrow down to the menu option that says "D Box" and turn the option to "OFF".
Now turn off television and completely disconnect the LST-4100A. In fact, throw it away. In the trash is where it belongs.
Your television will now operate like a normal television purchased from a big box store. You should run an automatic programming setup for grins upon completing.
Enjoy your new NON-commercial lcd television.
Dec 22, 2008 | LG LST-4200A DTV Receiver
No color on my T.V., before when the T.V. would warm up it eventually came back. Now there is no color except when you press the Menu button the Menu showes color. What is the problem and what can we do to...
Sounds like the signal board may have a problemn OR If the signal to the set is low it could lose color burst. If you are using a cable box .. try removing it and hook the cable direct to the TV and see if any change. If the set works ok without the cable box that box may be the problem.
Nov 22, 2007 | Panasonic PT-61G54 61" Rear Projection...
Insignia IS-LCDTV32 32 in. Television Logo
16 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
