Where do hoses connect on a Hoover Us4262-930 vacuum
I bought a Hoover vacuum model #U4262 at an auction and cannot figure out where one end of the hose fits. The one that fits into the base is obvious but cannot figure out where the other end fits.
  • 2,176 Answers
Go to find products in the lower section of this site and under vacuums go to Hoover and then under find manual click on it and go to page 12 and you will find a manual for your vacuum which you can download, it is 29 pages long but the information requested is on page 11 of the manual. If I have helped you with your request would you please rate this reply accordingly. Thank you.
Posted on Sep 25, 2009
No electrical continuity within the hose of my Hoover S3670 Vacuum Cleaner. How do I disassemble bothe wnds that house the actual connections?
Those hoses are pretty close to being a sealed unit, and was meant to be replaced and not repaired. That being said, some people do fix the problem IF they can locate the problem close to either end. Most people won't mess with an open in the middle of the hose.
Unfortunately, since they are designed to be a replaced item and not a repairable item, there is no written instruction on disassembly. So it is one of those to times when you study your hose and figure out when the break is and then decide on if it is worth attempting a repair.
Aug 10, 2011 | Hoover S3670 Bagged Canister Vacuum
How do I change the belt on the Soft and Light Hoover Model #U4266930 Hoover send the manual through email, but apparent it is gone now...missing on my favorites list . Attempted to request second...
I have same problem, somehow take top all apart, looks like allen screws holding bag container on, remove that, get to screws right underneath top shell, then get to motor pulley from above . be careful not to pull off motor pulley when wrapping other end of belt around brush underneath, or else you'd have to take top all apart again. Good luck.
Jun 13, 2011 | Hoover Soft Light Supreme U4262-930 Bagged...
I need instructions on how to change bag in a Hoover Soft & Light Supreme upright vacuum cleaner. Thank you.
Here is a link that will show you how to change bag (and more).
The model number of manual is not the same as yours but it will work for your machine.
http://www.hoover.com/pdfs/manuals/C1404.pdf
I hope this helps.
Feb 02, 2010 | Hoover Soft Light Supreme U4262-930 Bagged...
How do you connect the stair and upholstery hose to the hoover steam vac
You can download your manual at Hoover.com under Service and Support - Download Manuals. It's acutally very easy to connect: With cleaner unplugged, open the hose connection port on the top of the suction nozzle (much easier to just follow the pictures than to figure out from my description) and plug in the short hose end. Plug the solution tube into its connection port on the side of the lower unit (in front of the wheel). You'll also want to check out the instructions for cleanup.
Oct 04, 2009 | Hoover Steam Vac Dual V w/ SpinScrub...
Can't get to motor to connect belt after removing brush cover
I followed the instructions that were supplied @ the FixYa site, to remove the hood. Removing the hood was the problem. Just follow the online users manual pages 22 thru 26. you must spread the hood by the rear wheels to remove. Thank You Very Much. Delano
Jun 29, 2009 | Hoover Soft Light Supreme U4262-930 Bagged...
Where does other end of hose go
You're quite right . . . the manual doesn't show where the other end of the hose goes, which frustrated me as well. I finally found another pic of the cleaner (I think it may have been the one on the box) which revealed the answer. If you're facing the rear of the machine, there is a plastic "hose clip" on the right side of the machine (it looks like the letter "c"), and the "loose end" of the hose is snapped into place in that holder - it doesn't actually connect into an aperture (that end of the hose is just to place the little furniture brush on, if you use it). Once in place, the hose will actually kind of overlap itself and be held firmly in place against the side of the machine. Hope that helps - I too am not a fan of manuals that leave obvious questions unanswered.
Jun 15, 2009 | Hoover F5906-900 Upright Steam Vacuum
How do I change the belt in a Hoover U4262-930
You got the second hardest part done; the hardest part is what you're asking about.
To get the new belt onto the drive shaft I used a long screwdriver for leverage and wrapped the end close to the shaft and with some elbow grease, got it to "slip" on to the shaft. It took a couple of tries, but once I overcame the fear of the belt breaking (because it has to stretch big time), I managed to get it one. Of course, the other end of the belt has to be wrapped around the roller first.
I found a link for a tech manual for this model, but it didn't help much....
good luck.
Mar 22, 2009 | Hoover Soft Light Supreme U4262-930 Bagged...
No suction for u4264-930
This link at the Hoover site is a general manual for the older uprights. It shows how to replace belt etc. Mine is a "Soft & Light" and it worked for me:
Dec 23, 2008 | Hoover Soft Light Supreme U4262-930 Bagged...
HOOVER VACUUMS
go to thehooverstore - this site lists a whole bunch of hoover machines, exploded diagrams and parts lists.
Aug 11, 2007 | Hoover Soft Light Supreme U4262-930 Bagged...
Can't figger out the accessory hose connections
Visit assist.hoover.com and review the available on-line manuals. If you do not find the appropriate manual, contact The Hoover Company Consumer Response Center at 1-800-944-9200.
Jan 01, 2007 | Hoover F7431-900 SteamVac Vacuum
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
