Question about Kenmore Washing Machines
My Kenmore 80 series wont do anything. It made a loud noise in the middle of washing clothes, cut off and wont turn on or drain the water or anything. I got all the water out but it still wont do anything.
    President:
  • 1,937 Answers
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
The following is the Whirlpool installation, operation and maintenance manual for direct drive washers with a troubleshooting section.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
From your description, it sounds like a power problem.
The first thing to check is if you have power to the machine. Beyond that I'd work through the Whirlpool troubleshooting.
Posted on Sep 25, 2009
Kenmore 90 plus series washer won't spin, barely agitates, will drain - but makes loud noise
It sounds like the transmission is done. Can't pinpoint what it is exactly, but I would start there.
Aug 21, 2012 | Kenmore Washing Machines
Kenmore 80 series
you may need to take some clothes out, since it might consider the situation an overload..try that first and see if it helps
Mar 10, 2008 | Washing Machines
We have a Kenmore 80 series top load washer model 110.28803890. When the timer moves to spin it makes a load clicking noise and does nothing.
Timers are not supposed to make loud clicks. If it is, it's going bad. The same problem happened with my parent's Estate washer. It its on it's third timer!
May 24, 2012 | Kenmore Washing Machines
Washer suddenly stopped agitating and emitted a loud buzzing/grinding noise.Was able to get the water to drain but it won't do anything else except make the noise. I should probably mention that I had a...
A heavy load like a comforter and rugs should never be done in this type washer because it breaks the drive coupling. themobilian_537.jpgthemobilian_538.jpg
The good news is it is really easy to fix. I have a couple of videos here:
themobilian_539.jpgthemobilian_540.jpgthemobilian_541.jpgthemobilian_542.jpgthemobilian_543.jpgthemobilian_544.jpgthemobilian_545.jpgthemobilian_8.gif I have a manual and more HERE
Dec 25, 2010 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 Series Mod:110.23832100 top load that with heavy clothes (towells robes) won't drain and leaves excessive water after spin cycle. Everything appears to function otherwise, no odd noises. No...
When you are putting the heavy clothes (towels robes) the sleeves of the towels will come out easily and get stuck in between the drain out valve so it will not sent the water out properly please avoid heavy clothes(towels robes) try to give a normal load
Dec 23, 2009 | Kenmore 15864/15862 Top Load Washer
My kenmore 80 top load series wont rinse top load wont rinse
drain pump is trying to drain. maybe have something in pump
Jun 22, 2009 | Washing Machines
Kenmore 80 Series draining problem
Check the following before replacing the timer.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
Jun 01, 2009 | Kenmore Washing Machines
Kenmore washer 80 series 110 model not spinning.
unless your washer is over 20 years old, then it wont have a belt. the temperature of the water wont have anything to do with it spinning or not.
need to know if it agitates or drains and just wont spin.
if it agitates but no spin or drain, then you have a bad lid switch.
if it wont agitate or spin, but will drain, then you have a broken drive coupling.
Jan 08, 2009 | Kenmore 24032\24036 Top Load Washer
Loud noise
Very loud squeaking sound, at the start of each cycle.
Jan 09, 2008 | Kenmore 16639 Built-in Dishwasher
Washing Machines Logo
115 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
