Question about Saws
Radial saw motor just buzzes.
I was cutting with my 10-in radial saw. I shut it off for a few minutes. When I tried to turn it on, it just buzzed, and eventually blew the circuit. Freezer on same circuit seems to be working fine. What is wrong?
  • 308 Answers
It sounds like the start circuit is shot on the motor of the radial saw. It is trying to start, (the buzzing sound), but the start is not is burnt out, and therefore the run winding is drawing excessive amperage trying to start the motor (a job it is not designed to do) and eventually builds a amp draw in excess of the circuit. You will have to determine which is cheaper a new motor, or a new saw.
Hope this helps
Posted on Sep 25, 2009
When I try to startthe motor it buzzes. I continue to try to start and eventually it will start. Whatrt do I need
have the motor inspected by an authorized electrician
I suspect that the unit needs brushes or a new armature or new bearings for the armature
Oct 01, 2015 | Dewalt 1956 Mbf Radial Arm Saw
Craftmans radial arm saw model 113.198111 short down within 3 to 4 seconds and pops circuit breaker
I purchased a Master Craft radial arm saw brand new and made three cuts and it did the same thing. I took it back to the store where I bought it and they gave me another new one. Something in the motor had burnt out.. You could smell it also.
Sep 09, 2014 | Craftsman Radial Arm Saw, Power Switch,...
How do you change the blade on a craftsman 10 inch radial arm saw
put a block of wood against blade to hold it then loosen the nut that holds the blade to the motor .
Sep 02, 2014 | Craftsman Radial Arm Saw W/ Stand 10 In....
While ripping 1x4's my 10 inch craftmens saw stopped running. Pushing in on the reset button doesn't help. After 2-3 minites saw will start up again. I'm not forcing the boards and overwor
the thermal motor relay is shutting it down,,motor to hot,
insure that all the air vents or saw housing are not full of saw dust. blow it out with air from a reversed hose on a shop vac if you don't have a compressor.
hope this helps.
Jan 03, 2018 | Craftsman 10" Table Saw
Hi we have a dewalt 1730 radial arm saw. when switched on it sounds like it wants to work, makes a buzzing noise, motor appears to start to turn very slowly but will not get going, also crackling from...
Hi amelia01...
Sounds like you need to replace the start capacitor on the motor...it will cause the type of problem you are describing.
Please take time to rate me
Sep 14, 2011 | Garden
I have a craftsman radial arm saw 113.23100 which has not been used for possibly 20 years. I cannot get the motor to rotate in order to make 45% angle beveled cuts. I have turned the bevel lock knob to the...
My craftsman 10-inch radial saw (model#113.199200) just stopped working. I had it in the driveway cutting some wood without any problems. It sat for a half hour and I went to use it again and it was running half speed then before I could even turn it off it just died. There was no popping sound or smoke, nothing! It will not start. Need help, please?
Jun 27, 2010 | Skil 10" Table Saw
Dewalt 7749 radial arm saw
According to the service manual this saw has a 120VAC single phase 2.5 Hp motor with a 5/8" x 1.5"long arbor. It has a maximum vertical cutting depth of 2 and 15/16". It has a maximum cutting depth at 45 degrees of 2.125" (2 and 1/8") without the lower guards. The maximum cutting depth at 45 degrees with the lower guards in place is 1.625" (1 and 5/8"
The service manuals (approximately 24 megabytes each) are available on line at Dewalt.com After creating an account. Then you should go here:
http://www.dewaltservicenet.com/Products/DocumentView.aspx?productid=18624&typeId=1495&documentId=574
for the manuals.
Jun 25, 2008 | Dewalt DW746X 10" woodworker's table saw...
Saws Logo
172 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
