Question about Ovens
Thermador scd272ts was not working so I just finished replacing touch panel, display, main power/relay board, and the connecting harness. The functions are working now, but will stop working when I close everything up tight. It appears that the touch panel curcuit board is somehow touching the sheetmetal cover that it mounts to and causing it to short out. I have tried many times to adjust this and see if there is another way to reassemble to stop this from happening. Unfortunately the drawing that shows how the oven parts go together is not very detailed, so its of no help. I have spent all this time and money on parts and now with out this final solution, I still have no oven. Please help - Thanks
  • Margo Dale Sep 25, 2009
    Where do you find the mylar sheets and the non conductive gaffa tape?
  • 615 Answers
The board is causing a short in a place that you can not see…usually these boards has a small parts that allow the board to be secured to the frame and high (not to allow it to touch)…they usually connected or placed with the screws they create a platform see if you got them with the board or not…
Make sure that you connected the green ground before you close the unit and let me know
Please let me know how this worked for you and please do not forget to grade my assistance so I am able to continue to provide you with better service. I will be working with you to conclusion of the issues.
Posted on Sep 26, 2009
    President:
  • 1,653 Answers
If you think that it is the touch panel that is causing the problem then place a thin sheet of plastic or mylar sheet behing the panel and secure it with heat resistant and non conductive gaffa tape to insulate the circuit board from the chassis.
Posted on Sep 25, 2009
The display flashes F C then starts beeping. I turned off the breaker for 5 minutes and put back on but it started again.
Communication error detected by display board(main board), Lower oven relay board not powered up, check all power connections to the oven relay boards. Check all connections from the main board to the relay boards.
Aug 22, 2015 | Thermador SC272T Electric Double Oven
Thermador 30" wall oven.
Your touch in put key is stuck, replace ,power relay board and the touch panel
Always unplug the oven first before service
May 20, 2011 | Thermador C301U Electric Single Oven
The control panel on my Thermador scd302tp will not light up. The oven works fine. The appliance company wants to replace the entire control panel. Can it be fixed for cheaper?
Hello, welcome to Fixya. To answer your question "Is there a cheaper fix?" In a word...maybe. **Turn off the breaker before attempting any service suggested here please** The first thing to look into is to check the harness which comes from the main relay board to the display head, they can become unsecured from the display or the main relay board/control and that will affect the display in a negative way, i.e. faded or no display illuminated. You may or may not be surprised how much those things vibrate under normal use with the cooling/convection fan running etc. and over time the harness becomes unsecured. Check "J1" on display head as well as "J1" on relay board of the display power harness and insure they are secure in place, wiggle them a bit to see if the display illuminates when turning the power back on. If that doesn`t yield any positive result`s you`ll need a new display head kit part # 492067, it comes w/harness and main relay board ( see image below ) and it is typically about $250 or so, but I haven`t had to purchase one in 4-5 yrs. I`ve checked repairclinic.com and their site says it is discontinued, but if it turns out you need one I may have one in my garage. ( I used to have my own appliance business, hence I still have some "new old stock". we can communicate via email if need be ) Let me know what you find and how it goes with the harness check, I`ll watch for your reply on your post here. I`ll cross my fingers for you it`s just a loose harness. Hopefully this was helpful to move you forward and shed some insight on what to look for at least. Good luck macmarkus :)
Jun 17, 2010 | Thermador SC302T Electric Double Oven
All lights in the digital control panel have gone out
Hello Jerry, welcome to Fixya.
To answer your question "Is there an easy fix or replacement part?"
In a word...maybe.
If that doesn`t yield any positive result`s you`ll need a new display head kit part # 492067, it comes w/harness and main relay board ( see image below ) and it is typically about $250 or so, but I haven`t had to purchase one in 4-5 yrs. 9d09f95.jpg I`ve checked repairclinic.com and their site says it is discontinued, but if it turns out you need one I may have one at home but I`m currently away from home and hence out of town until the 19th. ( we can communicate via email if need be )
Good luck
macmarkus :)
May 19, 2010 | Thermador SMW272 Electric Double Oven
I have a Thermador SC301 wall oven and the display has faded out. Thermador says I need to replace the whole control unit ($500 for the part!) Any cheaper fix?
I have just repaired two SC301 ovens myself, but it is alot of work. You can get the oven's LED lights reconditioned at a company called CGI industries. Look them up on the web and click on the link for thermador. Removing the led panel and oven relay board is an involved job, but easier if you do it the correct way. First, turn off the power to the oven. Then pull the oven out of the wall socket about 1 quarter of the way. Remove the top cover of the oven with a phillips screw driver. This reveals the oven relay board. Take a digital picture of the board to remember the wire positions, or alternatively write them down. You also need to remove the touch panel (two screws underneath) and gain access to the LED. Remove the LED panel and wires. ship both to CGI (boards only) and you will have them back in less than a week. Costs about $170 before shipping. Reinstall and turn power on. All is good.
Feb 08, 2010 | Thermador Ovens
Control panel disassembly
Shut the breaker off to the oven first. Frame around mircowave is a snapped on front. Removing allows access to two screws under control panal. Must actually pull entire unit out about 9 inches to access top of control area to remove access panel. Once front control panel is removed and top is opened, easy access to what you need to get to. Carefully write down color coding of wires before removing any of them. Remove old power supply board and display and reconnect. Reverse process. A bit of work but if you watch the disassembly process carefully, pretty easy.
Jul 11, 2008 | Ovens
Thermador Built-in Oven Model SMW272
usually this is because you have the connecter on the touch pad off by a pin or not seated well. sometimes all it takes is taking the front touch panel off, re seating the connectors, and putting it back together. these thermadores are very sensitive to it for some reason. if all else fails, take all of the small multi pin wire connectors off one by one and re seat them. it should take care of the problem if it wasnt there before you started. good luck!
Apr 12, 2008 | Thermador C301U Electric Single Oven
Replaced the displace board and oven is now not working
I just had a repair company replace the display, control board and wiring harness on SCD272 double oven to correct a dim display (kit part # 492071). Instructions on kit say that all three pieces must be used together for proper operation.
Mar 08, 2008 | Thermador SC272T Electric Double Oven
Ovens Logo
70 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
