Question about Troy-Bilt Chipper Shredder
Where can I get parts for my 47321? I am in need of a cover for the belt drive? This seems to be an extinct model.
  • 496 Answers
I found a website that has parts for your model. I clicked through as if I were to buy and stopped. Here is the link where I left off:
http://www.partsandservice.com/bin/ipl.cgi
The cover is $35.20
Hope this helps... Good luck!
Posted on Sep 25, 2009
Kenmore vacuum cleaner model no. 116. 5861279 belt replace
Do you need the belt or the directions for changing the belt? Sears Parts Direct has the manual for the 116.58612790 here: http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Vacuum-Parts/user-manuals/manual-downloads/Model-11658612790/0582/0640500?modelNumber=11658612790&diagramPageId=&documentId= . The direct link to the manual is http://c.searspartsdirect.com/mmh/pd_download/lis_pdf/OWNM/L0802691.pdf . See pages 14-15 of the manual.
To replace the belt, you need to remove the light cover and then the light bulb. Press in the sides of the cover and lift to remove it. the bulb needs to be pushed in and then turned couter-clockwise. Remove the cover screws. Then flip over the Power Mate and use the flat blade screwdriver to release both tabs. Turn the Power Mate back to right side up and press on the handle quick release pedal and lower the swivel. Tilt the cover forward until it snaps free. Carefully, use your screwdriver to pop the brush supports free on both sides to remove the brush. Slide off the old belt. (If needed, slide off the brush supports and washers. Clean the brush before reassembling the unit. Then replace the brush supports and washers.) Push the belt on motor drive and then onto the brush sprocket. Push the brush supports back into place on the base. (Make sure that this isn't assembled upside down.) Then line up the front of the cover with the base and tilt the cover back into place. Press firmly until you hear both sides click into place. Replace the cover screws, light bulb and bulb cover.
The belt is available here: http://www.searspartsdirect.com/Kenmore-Vacuum-Parts/742024/0020/116/Model-11658612790/0582/0640500.html . This is part number 5285; it's the direct replacement for the original 742024 belt.
I hope this helps.
Jun 16, 2016 | Kenmore Vacuums
Belt sander runs until I put pressure on it
It sounds like the sand paper itself is slipping. There should be an adjustment to tighten the pressure on the sand paper itself.
Feb 28, 2015 | Ridgid Makita 98462 9910 Belt Sander 120v...
I need a manual for a Japanese Made Electra Royal XL 6000 sewing machine = Model #11065.
I have the complete manual that came with this very same machine - Electra Royal XL 6000. I can email if you would like. Do you know where I can find bobbins for it? The brand seems extinct. Thanks.
Sep 10, 2011 | Sewing Machines
Model no. 917257660 need belt size for drive and deck
The part number for the drive belt is: 140294 the size is Length: 82 1/4", Width: 1/2", Type: Covered
The part number for the mower deck is: 140067 the size is Length: 82 1/2", Width: 1/2", Type: Covered
They are very similar belts so don't get them mixed up the springs on the clutch pulleys may not be able to compensate for the slight difference.
Good luck, if you find this helpful please vote yes. Thank You!!
May 11, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Have a craftsmand 24" snowthrower
If the motor runs well, the two most common causes of this are the drive belt is worn and/or the shear pins are broke.
If you remove the cover (usually plastic) in the middle of the snow thrower and look at the belts.
Your operator's manual will show you how to remove the cover and check/change the belts.
If you don't have a copy you can get the manual through managemyhome.com
You will need the model number off the snowblower. It is usually located on the bottom right hand corner of the frame (from the handle side)
The model number looks like 247.123456.
The belt closest to the blower assembly drives the auger/blower and the belt closest to the engine drives the transmission. It sounds like you need to inspect the blower belt.
With the engine not running, have someone depress the drive lever and check the belt.
You should only be able to depress the long side 1/2 inch or less. More than that the belt has stretched and needs to be replaced.
On some older blowers you can adjust the tension pulley, but most made in the last 15 years, you can't.
The belt may be frayed on the edges or glazed causing it to slip (it is shiny on the sides of the belt) It may be torn and broke completely.
Replace the belt if it is worn, stretched or frayed
The shear pins are located on the auger in the front of the machine. Your newer Craftsman has four. If you don't now about them look in your operator's manual for the location. You need all four for the snowblower to work well. Replace the missing ones.
You can get parts for you Craftsman and most MTD made models through searspartsdirect.com. With other makes you can get parts through jackssmallengines.com
If you are unfamiliar with repairing machines you can get your snow blower repaired by taking it to your local Sears.
They will have a technician troubleshoot and repair the unit.
Feel free to ask any other questions. I know Snow Blowers. Please remember to rate this answer!
Jan 13, 2011 | Craftsman Garden
I have a craftsman snowblower that runs and the auger will turn but seems that the wheels want to turn but dont. I took off the bottom plate and seen that the wheels are chain driven. When I press the...
The most common cause of this is the drive belt is worn. Sometimes the drive cable stretches (from the handle to the trans)
To check the belts and tension you remove the cover (usually plastic) in the middle of the snow thrower to look at the belts. Your operator's manual will show you how to remove the cover and check/change the belts.
If you don't have a copy you can get the manual through managemyhome.com You will need the model number off the snowblower. It is usually located on the bottom right hand corner of the frame (from the handle side) The model number looks like 247.123456.
The belt closest to the engine drives the transmission. With the engine not running, have someone depress the drive lever and check the belt.
If you are unfamiliar with repairing machines you can get your snow blower repaired by taking it to your local Sears. They will have a technician troubleshoot and repair the unit.
Dec 28, 2010 | Ariens 34 In. Zoom Series Riding Mower
Seem to have a belt slipping problem. The motor runs but the belt is not turning. Have been trying to get new belts. IMPOSSIBLE !!! I have two machines...148 15600 and 385 1233280
I assume you need belts for both machines? Searspartsdirect (SPD) are the best place for Kenmore replacement parts.
There are 2 belts on the 385 1233280 - the timing belt and the drive belt. Both are in stock at SPD and can be obtained by clicking on the following link:
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Sewing-machine-Parts/Model-3851233280/0582/1220000/00024020/00008?blt=06&prst=&shdMod=
If you hover over the exploded parts diagram you can see a larger view. The timing belt is number 7 and the drive belt is number 15. If you scoll further down the page you can add them to your shopping cart.
They also have both belts for the 148 15600. They are numbered 16 and 17 in this diagram:
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Sewing-machine-Parts/Model-14815600/0582/1220000/00033316/00008?blt=06&prst=&shdMod=
Again both are in stock, and can be ordered by scrolling down the page and adding numbers 16 and 17 to your shopping cart.
Yoiu may be able to get these from a Sears store, but you can any which you need from here.
Hope this helps. Please post back if you need further assistance.
Regards,
BElectric
Dec 16, 2010 | Vacuums
I have a chipper/shredder Model 47321. ( Troy-Bilt) I need either of two parts , A cylinder assembly # 1762606 or a cylinder weldment # 1762607. Are there after market parts available? I, also need...
I have the same model and need the same part. Were you able to find the parts? The last time I purchased parts I called Gardner Inc, out of Columbus, Ohio. Have you tried them?
Jan 18, 2010 | Troy-Bilt Chipper Shredder
Replace crankshaft position sensor
Remove the left front wheel....(drivers side). Remove all accessory belts. Remove the crankshaft shaft pulley.......remove the plastic lower timing belt cover.....and there it is! It is mounted with one bolt.
The wiring runs down the right side of the timing cover while looking at it from the drivers side of the car.
Aug 17, 2009 | 1998 Honda Civic
Troy-Bilt Chipper Shredder Logo
677 people viewed this question
Top Troy-Bilt Heavy Machinery Experts
Mike
itsman
ray gallant
Are you a Troy-Bilt Heavy Machinery Expert? Answer questions, earn points and help others
