Question about Marantz SR4001
No channel and no sound
We have a panasonic plasma connected to marantz sr4001 receiver. Out of nowhere the system would no allow pictures or sound for cable channels. It will show sound and pictures when playing dvd's. Also the PCM indicator is blinking... is it a problem with the TV or the receiver? And how do we fix it?
2 Suggested Answers
  • 151 Answers
SOURCE: no sound/data from dvd or
You may have to tell the amp which type of input the dvd and tv are pluged into eg phono,optical or coax,you should find this in the amp set up menu.
hope this helps.
CABLE GUY.
Posted on Jun 30, 2008
My Panasonic plasma Tv does not have sound. How do I fixed that
Sound no picture on 50 inch samsung plasma ps51d450a2m - HDTV ...
www.tomsguide.com/.../58009-4-sound-picture-inch-samsung-plasma-ps...
Jul 1, 2015 - 4 posts - ‎3 authors
There is sound and no picture on plasma tv, remote works at times but ... My pioneer elilte has this mode, and it is pretty easy to completely turn ... When I connect my Laptop to my TV thru HDMI cable I ...
Feb 22, 2015
Problems with blu ray player and plasma tv - HDTV ...
Nov 16, 2014
I do not have audio out on my tv how do i connect so ...
Dec 18, 2013
All channels on my tv have sound except channel 3 ...
Jun 29, 2010
More results from www.tomsguide.com
No picture or sound in my Panasonic TH-P42UT30A plasma ...
Dec 07, 2015 | Panasonic Viera Th-50px60u 50" Plasma...
How do I connect CD player to marantz NR1504 with phono leads
Connect the cd audio out to the line in or cd in on the marantz
Nov 25, 2014 | Marantz NR1504 5.1-channel Home Theater...
How to reset marantz sr4001 from protect mode?
Protect mode comes into play when there is a problem with the speakers or amplifier First check all the speakers for opens or shorts If they are fine you don't reset it you repair the receiver.
Aug 07, 2014 | Marantz Audio Players & Recorders
How do you connect an ipod/ipad to the Marantz sr4001
Anything that has a headphone output can be adapted to feed an RCA cable pair for standard stereo to any audio device with a standard RCA input. Get a cable like the one described here:
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10218&cs_id=1021804&p_id=665&seq=1&format=2
and connect it into any available analog input EXCEPT "Phono". Turn the MP3 player volume up.
Feb 24, 2011 | Marantz SR4001
Power button light keeps flashing and sound gos my marantz sr4001b
Register and download the manual for free at retrevo.com
http://www.retrevo.com/s/Marantz-SR4001-Receivers-review-manual/id/511ag801/t/1-2/
Page 48: See the note at the lower right.
After "PROTECT" appears on the unit's display, the standby indicator may start flashing. if it does, there is a problem in the unit or the connection. If this problem reoccurs even when power is activated from the remote control unit, call for servicing.
Generally speaking, an amp protects itself from heat, shorts and overloads by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections as a root cause for intermittent shutdown.
Feb 21, 2011 | Marantz SR4001
My Marantz sr 4001 receiver has no output. Is
There is no fuses for the speakers. Check setup. If the receiver has 7.1 channel input try to connect a source there so you can check output (amp) section and the speakers.
Jul 18, 2010 | Marantz SR4001
How to connect Panasonic BD60 Blu-ray disc player to 2 components
If there are red and white RCA jacks on the back of the BR player and on the receiver you should be able to get sound. The same as your VHS.
Dec 29, 2009 | Panasonic DMP-BD60K Blu-ray/DVD Player
No sound/data from dvd or tv to receiver( marantz sr4001).. tuner works as does aux where i run my mp3 from. have just rehooked up main and center channels after repair. nothing else has changed ..just no...
hope this helps.
CABLE GUY.
Jun 30, 2008 | Marantz Audio Players & Recorders
No sound on some channels
Had same problem on Viera 3D Plasma TH-P54VT20A
Select Sound from setup menu and ensure SPDIF Selection is set to PCM (not Auto)
Feb 28, 2008 | ViewSonic NextVision N2010 20 in. LCD...
Marantz SR4001 Logo
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
