Question about Dell 1600n All-In-One Laser Printer
1600n dell printer shows paper jam. But there is
1600n dell printer shows document jam. But there is none. Machine was checked by tech.
  • 30 Answers
Check the sensors in paper tray
Posted on Sep 25, 2009
Frequent paper jams on a Dell 1600n AIO, sometimes doesn't grab the paper from the tray (not really a jam, just need to open and close tray), sometimes gets caught halfway through the path -- need to open...
This could be caused from the papers you use at times(weight). Call on a Dell representative to check it out for you if you bought it from a Dell shop.
Thanks
Aug 19, 2009 | Dell 1600n All-In-One Laser Printer
Dell1600n showing a document jam, have tried everything eg switching it off but cant find a solution. it prints fine and copies fine as well just isnt taking anything from the ADF. So I cant send a fax...
check the gears in the adf maybe you have one that is misaligned ,run a piece of paper following the paper path check the flag sensor make sure none of them is jammed close or misaligned.
Good luck
Jul 09, 2009 | Dell 5310n Laser Printer
1600n grinding and jamming
hi....take it to a tech to check about the system control chip... the control chip would have gone bad... and they will replace u with a new chip..or else Try manually moving the head carriage back and forth a few times!
Also check, if there isn't some piece of paper lodged inside, if yes try to remove it carefully!..
these are the possible solutions u can try out...
thank u
rate me
Jun 11, 2009 | Dell 1600n All-In-One Laser Printer
Paper jam 2 - checked every area - cut equipment off and back on - still paper jam 2 - need service person asap.
there are 4 or 5 sensors through paper road:
1)paper input sensor near input roller
2)margin sensor between input roller and cartridge unit
3)transfer bell sensor between cartridge and fuser unit
4)fusing sensor before fusing
5)out put tray sensor
check all sensors if you can find out and check any paper jam there and check sensor stander at normal position, also check each sensor click ok(the micro switch ok) .
there is any sensor out of work should be showing paper jam.
Jan 23, 2009 | Dell 1600n All-In-One Laser Printer
Dell 1600N warming up message
Hi Unplug the printer power cable from the wall and disconnect it from the printer as well. Turn the printer power switch on for 15 seconds. This will reset the printer. Turn the printer power switch off and plug the cable back in on both ends. Then turn power on. The Document Jam error should be eliminated.
Please keep in mind you must check for any small pieces of paper or look for a real paper jam prior to completing the steps above.
I hope that helps.
Sep 16, 2008 | Dell 1600n All-In-One Laser Printer
Dell Printer 1600n
Check your manual feed tray. The printer may have a print job in memory that's pointing there.
Aug 13, 2008 | Dell 1600n All-In-One Laser Printer
Paper jam, Is this the fuser?
I have had the same problem. Changing the fuser is easy (about $85, and must be ordered through Dell) remove the 4 screws from the back, and you'll see the fuser. 2 screws, and 2 wires, and it slides right out.
Jul 16, 2008 | Dell 1600n All-In-One Laser Printer
Document Jam in Dell 1600n
The Automatic Document Feed (ADF) has a white rubber pad that wears out. You can find it by opening the ADF cover and removing the roller bar. Under that is the white rubber pad. Pinch the sides together and the assembley comes out. Contact Dell for the replacement. You may also refer to the Dell 1600n Owners Manual for instructions.
Jun 14, 2008 | Dell 1600n All-In-One Laser Printer
Rear output slot
What do you mean? Do you actually want the paper to deliver out the back? Do you need the part that goes to the back so the paper delivers properly? Explain...
Call Dell Services. They will be able to help you purchase any part you need.
Mar 11, 2008 | Dell 1600n All-In-One Laser Printer
Dell 1600n All-In-One Laser Printer Logo
270 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
