Question about Maxtor OneTouch 4 500GB External USB 2.0 Hard Drive
My computer does not read the external hard drive when i connect it. I have tried different cables and different computers.At best, it just says new hard drive installed but cant find hard drive anywhere. Its a maxtor one touch 4 500gb. Any suggestions?
  • 6,831 Answers
Hello
My apologies if this message finds you long after posting this problem , but I am currently working through a backlog of problems that never got answered and hopefully this info can still be of use if not now possibly in future.
Please download Disc Digger HERE. This is a free tool you can use that works very well and there is no installation required, just run the program once you downloaded it.
Once you have connected the memory disk / hdd to the computer , run the program.
On the program , select the dig deep option for accidentally deleted files or dig deeper for a formatted drive. Then select the disk you want to do the recovery on and run the program.
The data will be displayed and you can recover it from there. This will only work if the card has not been used since the data was lost. Save the files to a location on the computer hard drive and not back to the disk it is recovering from as this will overwrite the other pictures that still needs to be recovered.
Some of the properties of the files may become lost in the recovery but the pictures should be fine.
You will also only be able to recover certain file types using this method.
Feel free to ask if you need more assistance.
Kind Regards
Andrea
Posted on Sep 30, 2010
Imicro IMBS35G-BK external drive stopped working. computer will not read it.
Try a different cable. If that doesn't work buy a new enclosure and install the drive.
Apr 03, 2014 | Imicro IMBS35G-BK 3.5 inch USB2.0-SATA&IDE...
Why won't the computer read the hard drive
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
Note that W.D. has a "Customer Loyalty" program -- you can buy a new W.D. device, through the W.D. web-site, at a significant discount.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge" guarantee.
Dec 17, 2010 | Beyond Micro Mobile / 250GB / 7200 / 8MB /...
My WD external hard drive will no longer work with my MacBook computer. When i plug it in it says that it cannot read the external hard drive. The computer says that i should restart the external hard...
* the USB cable
* the power-adapter
Dec 14, 2010 | Western Digital Passport WDXML800UE...
Computer wont read portable hard drive
* the USB cable
* the power-adapter
Nov 09, 2010 | Western Digital WD Passport 250GB Portable...
We bought some time ago an WD External Harddisk and now the Adapter doesn`t work anymore! What can I do?
Try connecting it to a different computer.
Any external storage device has three major parts:
* USB cable
* disk-drive
* USB-to-disk-drive adapter
Disconnect the disk-drive from that adapter, and connect the disk-drive as a "slave" disk-drive in a desktop computer, and see if you can read the files, which implies that the adapter is the part that has failed.
If you cannot read from the disk-drive, check its WARRANTY status. W.D. will replace it, if the warranty is still valid.
Otherwise, W.D. has a "Customer Loyalty" program: find the serial-number of your unit, access their web-site, and purchase another W.D. external storage unit, at a significant discount, by citing the serial-number.
Or, if the adapter is OK, then replace the disk-drive by a new one, and close-up the casing, to create a "revived" external storage device for your use.
Oct 23, 2010 | Western Digital Elements powered by WD 320...
My wd3200me was working now not
If it still does not work, either:
* the USB-to-disk-drive adapter has failed
* the disk-drive has failed
If the former, open the case, and remove the disk-drive,
and temporarily connect this "internal" disk-drive as a "slave" disk-drive into any desktop computer, and copy all the files. Or, remove the disk-drive, buy a new "empty" external-adapter, and install your disk-drive into the new case.
If all else fails, search online for "Data Recovery Services".
These type of companies are expensive, but they can "recover" files from almost any hard-drive that has "failed".
Jan 02, 2010 | Western Digital Elements powered by WD 320...
I have a hard drive with all my pictures on it and my computer not reading the hard drive when it plug in how can i send it in to get it fix it a smartdisk 160gb
Always try the simple first- connect the drive to a different computer, then if that does not work, try a new cable to the old computer then to the different computer. If still No Go, many local big box retail stores like Best Buy have a computer repair desk. Be prepared for $$ charge, however.
Dec 09, 2009 | SmartDisk 160GB FIRELITE PORTABLE FIREWIRE...
Usb 2.0 portable drive has (5pin mini) will only work with usb cable that came with canon camera. other brand new usb 2.0 cable won't work. Tried this with 2 different drives and also with mac and PC
Suggestions:
(best to worst)
1. Use a "Y" USB cable with that drive.
2. Use a shorter USB cable.
3. Use the new cables with the canon
4. Use a 2.0 hub
The drive should have come with a "split" USB cable (USB "Y" cable). The drive requires a "data" and a "power" connection to your computer.
Get one at Radio Shack, Best Buy, Office Depot/Max... ($10)... or Dollar store ($1.09)
Oct 02, 2009 | Toshiba 200GB USB 2.0 Portable External...
Mhy maxtor external hard drive is not being recognized by my computer. What do I need to do?
Does it work when connected to a different computer?
If not, is it still under warranty?
If not, disassemble the case, and you'll find an "internal" MAXTOR disk-drive inside the case; try connecting that drive as a "slave" disk-drive inside your computer. If it is not recognized, then it is "dead" and you should take a hammer to it, so that any of your personal data on it will become impossible for any "identity-thief" to read, and then buy a new, larger, external drive.
Sep 13, 2009 | Maxtor Hard Drive
My computer stopped reading my external hard drive
body { background: #FFFFFF; margin: 0px; padding: 4px; font-family: arial, verdana, sans-serif; font-size: 10pt; } p { margin:0px; padding:0px; } .spwrap { background: transparent url(../wysiwyg_rte/misspell.gif) repeat-x scroll center bottom; } Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
Nov 13, 2008 | Seagate Free Agent Go Small 12 GB USB...
Maxtor OneTouch 4 500GB External USB 2.0 Hard Drive Logo
208 people viewed this question
Top Maxtor Computers & Internet Experts
Computer Links
Rick Arnold
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
