Question about Dryers
Whirlpool dryer takes 2-3 cycles to dry a full load of clothes
We have a Whirlpool GEW9200L0 dryer that's probably five years old and has run great for many of those years. Recently, the dryer will run for awhile and shut off, but the timer will still show time and count down. If we cancel the cycle, the dryer will not restart. We have to wait for about 30 minutes before it will start again.
We have cleaned the vent with a special chimney sweep-looking tool and pulled the front lower panel to vacuum all the lint from inside the dryer. There is noticable air flowing out the vent and it feels warm/hot. We have also run the diagnostics on the front panel (more-less-more-less), but there are no error codes.
  • 7 more comments
  • fromtulsa Sep 30, 2009
    I changed out the high limit thermostat and cutoff, but still have the same problem. It may even take slightly longer now to dry the clothes. There were no instructions on how to hook up the wiring, so I may have a wire out of place. I looked at the picture in the service manual and tried to put them back where they were. If there's a wire connected wrong, would it work at all?
    EllaWatson25, if it is the motor, I'm not sure I'd replace it due to the cost, age, and condition of the dryer. I'll have to think about it and maybe get someone out who can test it first.
  • fromtulsa Oct 01, 2009
    One other thing, when the dryer shuts off and is still counting down, it may restart later on its own if there is still time left.
    President:
  • 1,776 Answers
I would check for a faulty high limit thermostat. This is a small round device mounted on a metal plate and attached to the internal ductwork. It's recommended that the thermal fuse be replaced at the same time and may come as a set from a parts supplier. I will attach a photo of a fuse/thermostat for reference. Remember to disconnect the dryer from power source before attempting any repair. Sorry for your trouble and I hope this helped. Best wishes.
Posted on Sep 25, 2009
  • 725 Answers
This is your motor. When it runs and then stops for 30 minutes, it's cooling down before starting up again. If you will call or email us, we'll be sure to send the right part out to you right away to get your dryer working properly again real soon. We look forward to hearing back from you real soon.
Posted on Sep 30, 2009
Dryer runs well but will not heat up and dry
You need to clean your dryer vent and make sure there are no obstructions.
Jan 02, 2010 | Whirlpool LGB6300 Gas Dryer
My admiral dryer runs but has stopped drying the clothes to where I have to run the load five or six times and when I take out the clothes they are cool instead of warm. It does this with every drying...
either your heat cycling switch,hi-limit switch,thermistor or part of your element is defective or you don't have full 240 volts to operate your dryer i.e. only 1 leg of 120 volts it will run in some cases but will heat poorly
Oct 29, 2009 | Admiral AAV7000A
There is no heat when dryer is on
you need chek :
if your apliance is gas dryer:
1-thermal fuse.
2-sensor flame.
3-ignitor.
4-gas valve.
if is electric dryer:
1-thermal fuse.
2-heater element.
Oct 05, 2009 | Dryers
My Dryer not that old, takes all day to dry a small load.
Check the following areas thoroughly to address this issue.
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
Aug 31, 2009 | Whirlpool LER5636P Electric Dryer
My dryer takes 2 to 3 cycles to dry my clothes.
Check the following areas to combat this issue. in most cases, this will be a Venting issue.
1. Venting
2. Thermostat
3. Heating element
Jun 21, 2009 | Whirlpool LER4634J Electric Dryer
Water fills the washer during spin cycle
defective timer...a model # should be under the lid...or open dryer door and on front dryer panel right hand corner..onthejob
Jan 16, 2009 | Whirlpool LTE5243D Top Load Stacked...
I have a whirlpool super capacity dryer that is very slow drying the clothes. It takes three or four cycles to dry a load of clothes. I've cleaned the lint screen.the exhaust tube and the clothes aren't...
hi .your air duct in the dryer is probably clogged . To repair. remove lint filter 2 screws on the top, remove . lay dryer on floor, front down. remove back panel . remove the air duct, clean all lint thanks the appliance doc
Oct 02, 2008 | Whirlpool Dryers
Changing gas whirlpool dryer heating ailment
Before you do that try this pull the unit out from the wall remove the venting from the back run a load and let the hot air go intop the house if it drys fine you have a plugged vent going to the outside and it will need to be cleaned out (This is the most common problem for long dry time)
Apr 13, 2008 | Whirlpool LER5636P Electric Dryer
Dryer runs but with little heat
Generally whilpool dryers heat of dont heat.. output should be around 150 .. i would check hose to make sure not clogged or just run without hose and see if that makes a difference... post if need more help
Oct 29, 2007 | Whirlpool LER4634J Electric Dryer
Dryers Logo
491 people viewed this question
Top Dryers Experts
