Question about NetGear WGR614 Wireless Router
Can not get conected to wire less router on virgin
  • 1,272 Answers
HI, follow the steps below to configure settings:
Please follow the steps on a computer connected to the router so as to check the network key:
1. Open the browser(Internet Explorer or Mozilla Firefox).
2. Access the router usually http://192.168.1.1 else try http://www.routerlogin.com
3. Login to the router with the Username as admin and password as password (unless you have changed it).
4. Click on Wireless Settings'(under Setup) from the left menu.
5. Check if 'WEP (Wired Equivalent Privacy)' or 'WPA-PSK (Wi-Fi Protected Access Pre-Shared Key)' is selected under 'Security Options'.
6. If WPA-PSK is selected, copy the code entered in the passphrase.
7. If WEP is selected, copy the code entered in the key that has been checked.
This is the code required for connecting the wireless computer to the routers' wireless network.
Now if your computer has windows XP then perform the steps below:
1. Right click on My Computer icon and go to Manage.
2. Go to Services then go to Service and Applications.
3. Double click on Wireless Zero Configuration.
4. Change the Start Up Type to Automatic and click on Apply
5. Click on Start and press OK to close the window.
6. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
7. Right-click on the wireless Network Connection icon and select 'Properties'.
8. Go to the 'Wireless Networks' tab .
9. Check the option 'Use Windows to Configure this Wireless Connection' and click 'OK'.
Now please perform the following instructions to connect to the wireless network:
1. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
2. Right-click on the wireless Network Connection icon and select 'Properties'.
3. Click on the 'wireless network' tab.
4. Under Preferred networks if you see any name in the list then highlight the name and click remove. Click OK.
5. Right-click on the wireless Network Connection icon and select 'View Available Networks'.
6. Look for the SSID (aka Network Name) of the Wireless router or access point.
4. Highlight thee SSID from the list that you want to connect to.
5. Type the security Key here and click on the 'Connect' button.
6. You should have successfully established a wireless network connection.
For Windows Vista on wireless computer perform the steps below:
1. Click START, Click Control Panel then click classic view in left hand side menu.
2. In the main screen, open up NETWORK AND SHARING CENTER.
3. In the left hand side menu open up MANAGE WIRELESS NETWORKS.
4. If you see any name in the list, please select the name and click remove.
5. Once the list is empty, click on ADD, select the first option, ADD A NETWORK THAT IS IN RANGE OF THE COMPUTER.
6. Click on your network name SSID and click on connect. If you have a password setup on the router enter the security key.
7. This should setup the wireless network.
I hope the steps above will help resolve the issue. If you need any further help please email us back so that we can continue to work on a solution.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Posted on Sep 26, 2009
I am trying to conect my laptop to the sky wireless in my house. the connection was successful but I cannot access the internet. Please help.
Do power cycle with you router
Connect to router by wire and see if it is working, in case no, Call sky, some issue from their end
In case working, issue is with wireless..
Connect to internet by wire
Open the router ip on web
Change the frequency to 6 (it worked for virgin)
Mar 04, 2011 | Computers & Internet
Trying to conect laptop to virgin media with netgear wireless adaptor the signal is strong but could not conect windows say to contact provider provider gave me number to enter 192.168.0.1 now i am lost
The router is not connected to the internet via Virgin media.
Your computer is connected only to the router wirelessly, that is why it says contact your internet supplier on how to connect the router successfully!
Jan 12, 2011 | NetGear WGR614 Wireless Router
Connecting to virgin cable modem
Hey, connect a network (straight through cable) from the blue socket on the modem to the WAN socket on your router (This socket will be split away from the other 4 on the router), then turn on your router 1st then modem.
Good Luck.
Nov 13, 2009 | Computers & Internet
Virgin broadband to laptop
Try setting a static IP on your computer with the DNS provided by the modem- to set this up contact Virgin and have them help you setup a static IP(or if you know how to set static IP on the computer use the same IP information you getting from the DHCP).
May 13, 2008 | Belkin (F5D9230-4) Wireless Router...
Cant get internet conection through router
can you login to your router?
you may need to change the connection settings your router uses: what username, password, etc. to use when connecting to the internet.
Mar 29, 2008 | Buffalo Technology WHR-G54S Wireless...
NetGear WGR614 Wireless Router Logo
52 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
