Question about HP 1040 Plain Paper Inkjet Fax
Hp 1050 fax
Retreive messages form another location
  • barryjoel May 15, 2009
    I can not retrieve my messages from a remote location using my cell phone but I can with a land line
My fax is hp 1040, the fax ring like it is going to receive but nothing happens and when I send it doen't go through. I have two phone line and when I connect it to the other it will send.
Posted on Mar 13, 2008
    Renaissance:
    An user who is expert in 3 categories / brands.
  • HP Master
  • 1,362 Answers
Fax machine not copying?
If you have an HP 1040 or 1050 fax machine be sure tot checkout this article about the recall HP did on this machine due to a potential fire hazard. You need to contact HP before you have problems with the unit.
http://www.ccl-la.com/blog/index.php/recall-on-hp-1040-and-1050-fax-machines/
BuddyMc
Mar 01, 2012 | HP 1040 Plain Paper Inkjet Fax
Keep getting 3 beeps and then a confirmation that says send error
HP started a recall on the 1040 fax and 1050 fax due to a potential overheating and fire hazard. Additional information can be found here:
Thought you may need to know.
BuddyMc
Oct 28, 2011 | HP 1050 Plain Paper Inkjet Fax
My hp 1040 will not pick up fax after the fifth ring answering machine picks after forth ring can't tell the between phone call or a fax used to before changed date on answering machine fax quite working
Set rings to answer
You can select the number of rings that will occur before the fax answers an incoming call. If you are using your machine as both a telephone and a fax machine, we suggest you set the ring count to at least 4 to give you time to answer.
TIP: HP 1050 Fax: The Toll Saver function for the Digital Message Center interacts with Rings to Answer. See Toll Saver on page 40. If you have the HP 1050 Fax and have Toll Saver turned on, set the Rings to Answer to 2.
1. Press Menu repeatedly until BASIC FAX displays and press Start/Enter.
Rings to Answer will display.
2. Press Start/Enter.
3. Enter the number of rings you want (2-7) and press Start/Enter.
The HP Fax rings the set number of times and then answers. It then produces a different sounding ring to alert you to which type of call is incoming.
• The additional ring may occur once for a fax call
• The additional ring occurs 5 times for a voice call. After the 5 additional rings, the answering machine will answer.
Dec 08, 2010 | HP 1040 Plain Paper Inkjet Fax
I need to reset my fax phone hp fax 1050
1050 HP PHONE DOES NOT CONNECT TO THE RECEIVER PHONE. CANNOT SEND OUT.
Nov 27, 2010 | HP 1050 Plain Paper Inkjet Fax
I get a paper jam message. When i remove paper and reinsert a new paper, message appears again and again. I like my hp 1050 fax/copier because it has speakerphone capacity. It seems the newer models just...
If it is registering a paper jam, than more than likely there is some sort of obstruction in the paper path that is obscuring one of the sensors. My recommendation, manually feed a piece of thick card stock through the paper path and try to force any debris out. Also, you can try blowing a can of air through the path, this act should hopefully free any debris or dirt that is blocking the jam sensor.
-David.
Nov 02, 2010 | HP 1050 Plain Paper Inkjet Fax
When faxing document on the hp 1050 fax machine does the document you r faxing go face up of face down?
Your manual can be found here: "http://h10025.www1.hp.com/ewfrf/wc/manualCategory?product=424230&lc=en&cc=us&dlc=en&lang=en&cc=us"
The simple answer is face down.
Dec 19, 2009 | HP 1050 Plain Paper Inkjet Fax
Do not have a manual for hp 1050 fax I need one
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?product=424230&cc=us&lc=en&dlc=en&product=424230
Nov 01, 2009 | HP 1050 Plain Paper Inkjet Fax
Hello. My HP 1050 Fax Machine ran out of ink. do you know what ink it takes
HP FAX 1050 Ink Cartridge (C6614A) Try Staples or Office Depot.
Oct 01, 2009 | HP 1050 Plain Paper Inkjet Fax
We get a communications error when receiving a fax from the HP 1050 fax
You need to update the firmware
You can get from the link below
HP firmware
On the software download page, select your Windows version.
Locate and select the firmware update.
Follow the directions to download and install the update
Oct 28, 2008 | Office Equipment & Supplies
HP 1040 Plain Paper Inkjet Fax Logo
95 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
