Question about Maytag Neptune MDE5500AY Electric Dryer
The start pad does not work. I have to move my
The start pad does not work. I have to move my finger around the start control pad to find the sweet spot for the dryer to turn on. Do I need to call repair or is there something I can do to fix this?
    President:
  • Maytag Master
  • 1,922 Answers
Thats not a good idea if your touching the board in the blind,sounds like you either have a broken solder joint or cracked circuit board, there are all different voltages on that circuit board(DANGEROUS & Sensitive) along with micro-processor chips which are susceptable to static electricity from your fingers
Posted on Sep 25, 2009
  • 832 Answers
You must call repair since your start pad needs repair
or replacement, to get it fixed.
How to perform scroll function in laptop without mouse in Dell vostro
Your touch pad should do the trick.
They are called "Gestures". They are set to active by default. If it's not. Go to "Control panel > click "mouse" and find "touch pad". There you will find "Gestures". Activate it.
1. Put two fingers on the touch pad and try to move both fingers up or down. Learn how to scroll up and down.
2. Move those fingers side ways. This should do the "Horizontal" scroll.
There are others, like:
Put one finger stationary and rotate the other. This rotates the orientation of the object.
Try it and good luck.
May 23, 2014 | Dell Vostro 1510 Laptop
Cursor Jumping Around
****a piece of Scotch tape over a mouse's laser, might make it work perfectly******
***some optical mouse's need a mouse pad and some work
on any surface.***
i use a lot of computers that have mouse's that i have to
list it slightly and let them ride on a finger when they are
off the mouse pad.
a few weeks ago, my good mouse finally frayed its cord and i
had to start using one of my redundant mouse's that needs a
mouse pad.
i noticed immediately that it could work almost normally if
i lifted it 1/4 inch off the table.
I'm not going to deal with this like that though..
i speculated that it must be because the laser sensor is too
sensitive..( since it works better from farther away....)
i wanted to try to put a piece of scotch tape over it to
act as a diffuser to make it less sensitive, but i was too
busy. lol. so like a month later . i finally tried the tape
idea, and it works perfectly!!!. dam
if you get an optical mouse that goes crazy without a mouse
pad, you should try this
Dec 14, 2013 | SteelSeries Ikari High Performance Laser...
How to used the touch pad
Use the touch pad to move the pointer around the screen.
Run your finger over the touch pad in the direction you want the pointer to move and then click the left touch bar (this works as the left button on a mouse).
Apr 16, 2012 | Computers & Internet
How does a touchpad works?
You put your finger on the pad, and move it around. It's like your finger is the mouse.
The two buttons at the bottom are for clicking.
May 25, 2011 | Computers & Internet
Pointer on track pad moves on its own. it does not move along with finger and goes in jerky direction elsewhere.
did water get on the track pad? Try connecting an external mouse to get control over your pointer, and navigate to system preferences/track pad. See if you can play around with the settings, but if the external mouse works ok, it sounds like water may have come in contact with your track pad.
Sep 12, 2010 | Apple MacBook Pro Notebook
How to use touch pad dell latitude D610
The touch pad on a Dell Latitude D610 works much the same as with other laptops. You can move your finger around the pad to simulate the movement of a mouse, and it will cause the pointer to move across the screen. You can also tap on the touch pad (gently) to "click" on a file, folder, or other item. The touch pad on a D610 doesn't have a hardware switch like some other laptops do so that you can turn it on or off -- it's just always on.
Aug 08, 2010 | Dell Latitude D610 Notebook
Super NES Control Deck Problem (model no. sns-101)
I think you migh have a loose connection the acadapter might need to be fixed or and looked at then. To take your SNES appart you will need a 4.5mm or 3.8mm security tool to do this you can buy these tools at Lukie games.
Feb 22, 2010 | Nintendo Super NES Console
Dell touch pad stops working and starts working again in about 5 seconds. I just push my finger around the pad in circles until it starts moving again. This makes it very troublesome to play online...
its the software that is conflicting with your hardware, uninstall the new installed software, and if possible reinstall the fresh copy of OS.
Feb 14, 2010 | Dell F3534 Touchpad
Maytag Neptune MDE5500AY Electric Dryer Logo
114 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
