Question about Garden
Will nt run under full throttle application - Garden
    Brigadier General:
  • 4,088 Answers
Try turning the H jet needle 1/2 turn CCW. Remove the muffler to check for plugging with carbon. Make sure the chain is being oiled.
Posted on Sep 27, 2009
Honda gx390
All the GX series engines I have dealt with have had governor rods that connected to a pivot on the throttle plate separate from the actual throttle control although this can vary from application to application since different Pressure washer makers do make some modifications to suit their specific needs and applications I have yet to run across this being changed, so I would say no, not likely.
Aug 01, 2014 | Garden
L15AX manual
Beware no repair no refund under warranty! Gvision sucks
Mar 10, 2012 | GVision L15AX-JA-452G 15" LCD Monitor
Blower no powereven on full throttle
if you run it with choke on does it make a difference ? if so your carb,fuel filter or fuel lines are problem, if choke does'nt make a difference then remove your muffler and check your screen for being plugged
Aug 29, 2011 | Echo Gas Blower 204 MPH765 CFM Blower...
Trying to install Printmaster 15 for Windows 7. Is that possible?
Apparently no, it does support only Windows 98 / NT 4 / Me / XP. However, here is a thing you can try if a program cannot be run under Windows 7 because of compatibility issues, which is the case with Print Master Platinum 15. You right click on the executable file that will install the application and click Properties. Select Compatibility tab and check Windows XP SP3. If it installs do the same for the EXE file that will run the application. You can find more about this Compatibility issue on Microsoft website: http://windows.microsoft.com/en-AU/windows-vista/Make-older-programs-run-in-this-version-of-Windows
Dec 12, 2010 | Broderbund PrintMaster Platinum 15 Full...
I recently had a HD crash and have replaced it with another HD using the same Windows XP OS. While trying to reload programs that were on the old HD to the replacement, some of the programs get this error...
I always receive a "C:\WINDOWS\SYSTEM32\AUTOEXEC.NT" error message.
“C:\WINDOWS\SYSTEM32\AUTOEXEC.NT. The system file is not suitable for running MS-
DOS and Microsoft Windows applications. Choose ‘Close’ to terminate the application.”
This error message is not caused by the installation CD-ROM, but rather by the
“Autoexec.nt” system file. Windows is unable to find this file when launching the
installation CD-ROM, the file most likely having been deleted by another application.
To resolve this problem, proceed as follows:
1. Go to “C:\Windows\repair” and find the file “Autoexec.nt”.
2.Copy this file to “C:\Windows\system32”.
3.Right-click the file “Autoexec.nt” that you have just copied, and select
“Properties”.
4.Tick the “Read-only” box and then click “OK”.
Aug 06, 2009 | Microsoft Windows XP Professional SP2 Full...
Husky 455 dies out at full throttle or under load
Your carb may be the issue but your ignition coil could be the culprit. Once they start going bad, they can act up intermittently or give various symptoms from day to day. The fact that your saw dies at full load or under load, probably means that when your saw gets hot or requires more spark, your coil is not able to provide it. Your carb is easy enough to clean out, you can take it all apart and clean all screens, etc....
I just replaced my coil due to the exact same symptoms and now my saw runs great. $60 off ebay and you can put it on in 15 minutes yourself. Check your carb first though
Apr 13, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
1974 60hp johnson outboard won't run on full throttle under load , max 10%. New fuel and filters ect. The motor is old but has very low hours.
Carbs probably need to be cleaned and re-built. Common problem in outboards that havent been run in a while
Apr 12, 2009 | Boating
2001 V Tech engine runs full throttle in neutral or in gear
Look under the hood. Look for the throttle body .The accelerator cable is attached to it. The cable housing anchor is broken and not letting it return to idle speed.. Use a portion of a clothes hanger to
secure the cable housing to the throttle body.
Apr 04, 2009 | 2001 Mercury Sable
When i am trying to use c++ on my system it is giving me message the NTVDM cpu has encountered an illegal operation
Here is an explanation of what NTVDM is: The NT Virtual DOS Machine (a.k.a WOW, or Windows on Windows), is a Win16 subsystem that runs under Windows NT, which allows 16-bit applications to run as if they were being executed on a DOS machine, with that machine's multitasking and segmented memory model. Because the system is multitasked 16-bit DOS and Windows applications cannot crash NT. However, 16-bit apps within a Win16 subsystem run the exact same way as they do on a DOS/Win 3.x machine; therefore, 16-bit apps within the subsystem can crash one another, or the subsystem. To prevent this, you can launch multiple WOW subsystems as long as your program does not communicate using shared memory. Windows NT will not allow NTVDM to execute instructions that try to directly manipulate hardware or memory locations. As a result, some DOS and Windows 3.x applications (such as games) may not run under Windows NT.
Feb 02, 2009 | Computers & Internet
Garden Logo
79 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
