Question about Gateway GM5472 PC Desktop
How to add memory to my pc gm5472 - Gateway GM5472 PC Desktop
  • 2,229 Answers
You need to open the case and see how many sticks of memory are in the slots. Your machine should come with 2GB. (probably 2 1-GB sticks)
If you are running a 32-bit system, it's useless to increase the memory above 3 GB, as the system will not see it. For a 64 bit system, you can add a lot more.
Posted on Sep 25, 2009
    Problem Solver:
  • 16 Answers
Go to the shop buy more. When you get back home open the side of the computer and replace with the new or add if you have enough slots.
Posted on Sep 26, 2009
    Problem Solver:
  • 6 Answers
RAM? You just open up your case and on the motherboard you will see two RAM sticks. Using an anti-static band take them out and put more back in.
If you mean your hard drive then just open up the case and unplug the HDD, replacing it with another one.
Gateway 5472 won't power up
You must register some sounds and usual noise from the case. If you consider that power supply works, try to unplug all unnesessary parts, and remain with CPU+Graphics+Memory. You are now closer to eliminate the current problem.
PC Servis Kompjutera Kod FONTANE Popravka Odrzavanje Laptop Racunara
Apr 13, 2014 | Gateway GM5472 PC Desktop
My GM5472 (AMD Chip) has been running very hot over the past few weeks - over 100 degrees C! I've cleaned the fans out and now have a fan leaning against the box, which keeps the temp down. Question is -...
-try adding additional fan in the casing -in adding fan make sure that you have a blower fan and a exhaust fan where in air can get in and out inside the case.
-add thermal paste/grease between the processor and the heat sink. it is often used to aid the processor's thermal or heat transfer via heat sink. -you can also add blower fan in the chipset of the motherboard -you can also add heatspreader in the memory. -check the power supply if you are getting enough power -having too much power may result in over heating and may damage the devices -having less power may result slow system and bad performance.
Apr 27, 2011 | Gateway GM5472 PC Desktop
My computer Gateway model GM5472 was running a windows update and all of a sudden went blue screen then shut down. Would not come back on when turned power but on you just here some beeps. what should I...
Beeps signal a hardware failure. Disconnect all disks and remove all other boards and try to start the desktop like that - if you can't go into the BIOS then there is a problem with either the memory (try another one) , the processor (try another one) or the mainboard - in that case you will have to replace it.
Feb 11, 2011 | Gateway GM5472 PC Desktop
Hi My gateway gm5472, won't start. I can hear the fans begine to whirl but that is all it wll do?
Hello there,
we have many steps we can try to fix this problem but i also need to know if you get any type of screen at all ?
Starter steps
reset the power to the PC
check the connections
make sure you have the power button turned on To the Display
i get the feeling if you can hear the Fans start to turn on that this problem could be with the Display.
thank you don't forget to Rate
Jan 25, 2011 | Gateway GM5472 PC Desktop
Can you use a pci only graphics card in a gateway GM5472 model desktop
Yes, but the video performances will be extremely limited.
Nov 15, 2010 | Gateway GM5472 PC Desktop
Does my gateway pc desktop model GM5472 come with a wireless card?
No it only comes with a wired lan (ethernet) car built in. If you want to you can easily add a wireless card to this unit. You have several options such as one of those USB wifi devices to a proper plug in card.
Apr 25, 2010 | Gateway GM5472 PC Desktop
No S video on GM5472
try pressing the FN + F5, or FN + F7, or FN + F10
Mar 30, 2010 | Gateway GM5472 PC Desktop
S video does not work on my computer GM5472. NVIDIA control panel does not solve the problem. This includes using the forced turn on option. Please assist me in turning this on. THANK YOU
Have you tried different s-video cables they do not have as long of life expectancy as other video cables and actually go bad usually starting with black and white and eventually ending up with no video at all
I need to diable the onboard video card before installing a PCI-E 2.0 graphic card. From what I have read, it's possible this is done automatically, through BIOS, or by a jumper setting. I never received...
It is an option in the BIOS under "Advanced Bios Features". Set Initial Display to PCI Express VGA card. Your options may be slightly different due to different BIOS.
Jan 30, 2010 | Gateway GM5472 PC Desktop
Gateway GM5472 PC Desktop Logo
127 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
