Question about Garden
Gasoline leak coming out the air filter - Garden
  • 3 Answers
SOURCE: gas leaking out hose going to air cleaner
sounds like needle valve in the carb is not shutting the gas off this happins some times when carb engines sit for long periods of time. turning the gas in to a laquer like substance. solution take carb off and clean the needle valve and the needle seat make sure all orfisis and jets are clear of dabrie. good luck david baxley.
Posted on Apr 17, 2009
  • 17 Answers
SOURCE: oil coming out of the air filter
Could be the valve seals have hardened and are leaking
Posted on Jun 17, 2009
  • 302 Answers
SOURCE: gasoline leaks thru the air filter when you open
I think the float in the carb is sticking. Tap on the carb a few times and then try it. You may have to rebuild the carb.
Posted on Oct 26, 2009
  • 4088 Answers
SOURCE: gasoline leaking into air filter on Briggs &
The float/needle-valve/seat need to be looked at in the carburetor base. The float is not shutting off fuel flow when bowl is at design fuel level. Look for dirt/varnish or anything that interferes with float free movement or preventing the needle valve to close with the seat--usually, just cleaning these parts with spray carburetor cleaner and wiping with a clean cloth will restore operation. Try not to bend anything on the float assembly. Hope this helps!
Posted on Jun 07, 2010
  • 252 Answers
SOURCE: Have an Echo backpack blower
hi there
pauly 46 here sounds like tank breather and carby problems ?
have you checked that the muffler and ex port are not blocked ?
have you checked that the tank breather is working, and that the fuel pump diaphram is ok - no holes or damaged / stiff , and also that the metering diaphram and needle valve are ok and are not sticking open, or the lever setting is too high or the diaphram is just too stiff and holding the needle open
either way check tank breather and carby diaphrams , and needle valve and lever and the muffler and ex port for blockage
i assume compression and spark and timming and induction system are all ok
if its still hard to start and everything checks out as good might have a air leak
only way to know is to pressure and vac test crankcases
might pay to let your local shop do this because you need some special tools
but cover the basics 1st
cheers pauly46 hope it helps
Posted on May 14, 2011
Etq tg3000 portable generator is leaking gas from carburetor into air filter. Any suggestions
PDF]Manual - Northern Tool + Equipment
www.northerntool.com/images/.../166020.pd...
Northern Tool + EquipmentThe ETQ air-cooled gasoline generators are widely used when electrical power is scarce. Our generators provide a portable mobile solution in supplying power for field ... 5.5 Hours. Fuel Type. Premix 50 cups of Gasoline to one cup of 2 stroke oil ......Leaking carburetor, clogged fuel pipes, sticking valves, or other damage, ...
[PDF]Owner's Manual Model TG4000
Dec 08, 2015 | Electrical Supplies
My car smells really strong of gasoline when I start my ford escape?
You may have a leaky injector or fuel filter. If it comes stronger when you just start your car, it could be because the injector is leaking overnight and builds up on the engine, which is then promptly burned and brought in through the air vents.
Jan 14, 2013 | 2007 Ford Escape
How do i clean throttle plates on 2004 gmc envoy?
Throttle body has nothing to do with the gasoline, it only regulates incoming air. In order to find the gas leak you will need to remove the air resonator assembly that goes from the air filter to the throttle body. Then you can get a look at the fuel rail and injector hook-ups.
Jan 12, 2013 | 2004 GMC Envoy
2002 rm 125 oil drain plug size
Anyone who uses gasoline to clean an air filter - needs to re-think that. Gas totally ruins the seams and shortens the life of foam air filters. Gasoline is far too harsh a solvent to clean an air filter. Use something a bit "softer" like Kerosene or even Diesel. These will help your air filter last much longer. Where, sure, gasoline will clean the filter, and many people have been using it for years to clean foam air filters, but, really, gas is horrible for cleaning air filters in the long run. Not to mention how dangerous it is.
If you want to save money, and NOT have to buy air filters as often, do NOT use gasoline to clean it. Use Kerosene or gentler solvents. Any good mechanic will tell you the same.
Jan 07, 2012 | Suzuki RM 125 Motorcycles
1995 vf750 magna. I have gas pouring out of the breather. Can anyone help?
Sounds like Carb float stuck lightly tap on bottom of carb and wait a minute to see if it stops...
Jul 13, 2011 | 1995 Honda VF 750 C Magna
My truck starts fine but dies after about 2-3 min when I let off the acclerator and come to a stop. It runs a little rough when I accelerate, I've changed the plugs,wires, air filter, & distributor cap...
yes please replace the fuel filter,the fuel filter replace every 40,000 kilometers according to the factory specifacation.then buy a repair kit of the carburator to clean and replace gasket to prevent leaking of gasoline
Mar 17, 2011 | 1990 GMC Sierra
I have 2000 mitsubishi mirage. Code P0170 FUEL TRIM MULFUNTION (BANK 1). What does that mean?
That code typically comes on due to an air leak, clogged fuel injectors, clogged fuel filter, or even a bad mass air sensor. I have answered other questions from people with similar problems, and some have had luck simply using a fuel injector cleaner with a full tank of premium gasoline. I've had good luck with STP Complete Fuel System Cleaner, available at most auto parts stores. I would also recommend you replace your air filter.
If your light had turned off, there really isn't much any mechanic can do, though you can ask for them to check for any air leaks in your intake system. But if your light comes on again and stays on, the problem probably is with your mass air sensor, and would probably need to be replaced.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Mar 11, 2011 | 1997 Mitsubishi Mirage
My 93 mercedes will not start sometimes, it turns over but will not start
hi,good day,your model have two engine gasoline and diesel engine,,for diesel engine check your pre-filter and main filter,fuel and air leak,check your engine shut-off,if not corrected,send (check) your injection pump and nozzle in calibration center,,,for gasoline,sop,,you have to check fuel pressure,,fuel filter,fuel pump,fuel pump relay,,coil,spark plug,cable,transistors box,ty
Dec 14, 2009 | 1993 Mercedes-Benz 190
Oil coming out of the air filter
Jun 16, 2009 | 1983 Yamaha XZ 550
Garden Logo
122 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
