Question about Canon Pixma MP450 All-In-One InkJet Printer
My Canon Pixma MP450 printer will no longer feed paper, is making a squeaking noise when trying to feed paper and shows a paper jam even without paper.
SOURCE: 'paper jam' error on canon pixma ip4300
Hi guys, I eventually found a solution to the problem for my printer. With the top cover open, I pushed a sheet of 120 micron thickness A4 clear plastic binding cover through the exit tray as far as it would go to rest against the bottom row of rollers. I switched the printer off then back on again and as the rollers lifted momentarily, I pushed the sheet of plastic as far up through the machine as I could before the rollers went down again - it went in a fair distance. The printer then ejected the plastic sheet. I then put the plastic sheet into the paper tray and tried to print a blank document page. The plastic fed through cleanly and my printer has been working since without any error messages. I hope this works for you.
Posted on Mar 04, 2008
SOURCE: says paper jam but there is none. pixma mp450
Take any paper out of the paper feeder and get a plastic ruler the softer the better lift the top of the printer up so you can see where the print cartridges are now push the ruler down through the paper feed roller be careful because you could break the rollers go from left to right right to left twice and check for any debris once you have done this unplug the printer for about 20 seconds then plug back in and let it reset then try copying or printing a doc and see how you go!
Posted on Mar 11, 2009
  • 12 Answers
SOURCE: paper jam problem in pixma mp145. E3 error.
MP160 PIXMA paper feed jam E3 error. I completely solved this on my Canon MP160 printer but it is a common problem and the fix may work for others such as MP130 MP140 MP145 MP150 MP170 or MP180. With the problem I had, the printer would make the usual motor whirring noises but would not feed the paper. The usual c-clunk sound that indicated the feed roller has been engaged was not there. The screen warning said to remove jammed paper and the printer showed an E3 error.
The problem was caused by the ink cartridge carrier becoming stcky on its track and not fully returning to the rest position on the right side (as viewed from the front). The fix involved taking the printer apart and lubricating the cartridge carrier track and the ramps that lift the cradle that rises to cover the printheads. Unfortunately you have to dismantle the printer and separate the scanner unit to get to the lubrication points. Its not a quick fix.
When you have the printer apart you will see a prominent white lever held by a coiled spring just behind the rest position of the ink cartridge carrier. The lever is actuated by the ink cartridge carrier when it moves to the right. If the lever is not actuated, the motor drive will never engage the large grey feed roller and the paper in the hopper cannot be fed into the printer. Make sure to also put some lube onto the lever at the point where it is struck by the ink cartridge carrier.
Posted on Jun 13, 2009
SOURCE: My MP470 Pixma won't feed paper, it pulls right
Based on instructions from your website I pushed a letter sized piece of thin cardboard backwards through the paper feed rollers then shook the printer while holding it upside down. A Q tip fell out, problem solved.
Posted on Jul 30, 2009
SOURCE: Paper wont feed into printer no paper jam
In the comments section Blumm suggests pushing a piece of cardboard (like the back of a legal pad) through the feeder as far as you can. Turn the printer off and then on again with it in there. Pull the cardboard out and check for any foreign objects that have been pushed through.
It worked for many people including myself - I got a piece of plastic and it works wonderfully again!
Posted on Jul 31, 2010
Paper dosnt feed in printer pixma mp210 photo. HELP
Either paper jammed, stuck by foreign object or DRIVE ASSY faulty.
May 25, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
PRINTER SAY PAPER JAM BUT NO JAM
please check paper feed sensor it is broker or displace
Aug 28, 2009 | Canon Pixma MP450 All-In-One InkJet...
Paper jam in Canon PIXMA iP90
one of your feed gears has poped out of placeor one of the teeth is broken,check the paper path with a flashlight you will probably see one loose.
Good luck
Aug 28, 2009 | Canon PIXMA iP90 InkJet Printer
Canon error code 6000 in mx308
please help me. i have canon print mx308. the have paper jams. paper has the full out from print. how i can finish the problems?
Jul 25, 2009 | Canon Pixma MP450 All-In-One InkJet...
Persistent paper jam error
How old is your model? This could be dirty rollers. See how I fixed that problem on this site: http://annoyances-resolved.blogspot.com/2009/09/paper-jam-buy-new-laser-printer.html
Let me know if this helped. OK?
May 30, 2009 | Canon Pixma MP450 All-In-One InkJet...
Says paper jam but there is none. pixma mp450
Feb 21, 2009 | Canon Pixma MP450 All-In-One InkJet...
Paper jam paper jam error message continues even no jam, have to feed by hand sever times before paper will feed into printer.
try this
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Dec 23, 2008 | Canon Pixma MP450 All-In-One InkJet...
Printer paper reloading
So the feeder woek sometimes, If you have a warranty, bring it back, if not , the printer might have something stuck in his mechanism or a bit of spread ink, open it and check for any weird thing, you can do some cleaning but the mechanism need some greassy spot so do not be too clean
then try a recommanded paper for the printer like 80g for example and no more than 30 new pages to begin.
You can test the printer when open, you just need to push a few switch or button to make it run also you will be able to see where the noise come from.
Dec 18, 2008 | Canon Pixma MP450 All-In-One InkJet...
Cannon Pixma 450 Paper jam
  1. Turn the printer off and open the access cover.
  2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
  3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
  4. Watch the paper as it feeds through and try to determine where the jam is occurring.
  5. Check to see if all the rollers are turning.
    If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
    If not, there is probably a feed motor or a gear problem and the printer may require service.
  6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
  7. Turn the printer off.
  8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
  9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
May 27, 2008 | Canon Pixma MP450 All-In-One InkJet...
Hi, my canon pixma mp450 is not feeding the paper thru properly.
We had the same problem so we opened the screws up at the back, gave it a shake and suddenly a asweet wrapper appeared. We then put the screws back in and it started printing again! Good Luck!
Jan 16, 2008 | Canon Pixma MP450 All-In-One InkJet...
Canon Pixma MP450 All-In-One InkJet Printer Logo
57 people viewed this question
old marine
old marine
