Question about Canon LASER SHOT LBP-5000 Printer
LBP5000 yellow flashing light top left
Can you tell me what the yellow flashing light means under the trianle warning sign and how to fix it so the it prints again?
4 Suggested Answers
SOURCE: error 6a00
I found numerous suggestions on FIXYA for other Canon printer models with the same 6A00 error message. The isuggestions mainly zero in on the purge station where the printer head parks and possible cause being bits of jammed paper at the two pieces of sponge material. There were several reports of cleaning the two sponges at the purge station and the problem going away after. I checked my printer but did not finad any jammed bits of paper. But I found the purge station was a bit up and could be pressed down - probably a bit sticky due to the soaked sponges and not returning to its original position. After that I didn't get the error message anymore. The two sponges on my printer purge station were black and possibly soaked with ink and I am thinking of cleaning these the next time.
ur flashing lights also seem to be a cnsequence of this....
hope it helps.... good luck
have a nice day
Posted on Jul 08, 2009
  • 217 Answers
SOURCE: lbp5000 two sides print
LBP5000 doesn't have a duplexer for automatic double sided printing, so it's maual duplex.
You have to print on one side, then put the paper in the paper tray again. Take note of the pictogram that shows a printed page with the corner turned over, this indicates wich way you put the paper in (for the print you are about to make, not what is already on the paper)
Posted on Feb 10, 2010
pineworks
  • 4041 Answers
SOURCE: Canon S400 lite binks 6 times won't print.
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal
Posted on Feb 13, 2010
My van is Toyota Hiace Dx & when i start my vehical in the Dashboard i can see a yellow color oil can, i want to know wht discribes that sign
The yellow symbol with a line under it means only to warn you if the engine oil level is low when its running. If its RED sign then this is your low engine oil pressure warning light.
Jul 28, 2010 | Toyota Corolla Cars & Trucks
Yellow warning
It's a blur-warning. It tells that there's a risk of camera-shake and blurry pictures. Support the camera on something sturdy, when you see this warning. Using flash will also turn off the warning.
Jun 22, 2010 | Fuji FinePix S2000hd Digital Camera
What do the warning lights on the 2004 VW Passat dashboard mean as they are a few flashing and I don't know what they mean?
Depending on which light is flashing will determine whats wrong, normally thee are three lights that flash one is yellow check engine light, when it flashes it means a misfire and catastrophic catalytic converter failure. Red oil light means your low on oil and if it does not have a gage you may have damaged the engine and then there is several others like air bag warning light this would be caused by a defective clock spring, or a malfunction in the computer system. Your best bet is call your local dealer and describe to them your problem and tell them what lights are flashing they can determine weather you should drive it or have it towed in for repairs. Remember FLASHING RED OR Yellow light means imminent failure of expensive engine parts.
Jan 15, 2010 | 2004 Volkswagen Passat
What does the orange warning sign on the dashboard means?
There are several waring lights on your dash so lets see if i can guess: does it look like this ( ! ) with some squiggly lines under it? If it is that's your tire pressure warning light tell you that one or more of your tires is low on air. after you correct you tire pressure you'll find a tire pressure reset switch just inside you glove box push it for a few seconds and your warning light should get cleared.
Jul 08, 2009 | 2006 Scion tC
Warning light on dash
that would be the "Speed sensitive power steering" warning light.
need to have your power steering checked. First thing to do before taking your car somewhere is to check your power steering fluid level.
May 02, 2009 | 2005 Suzuki Swift
I need a diagram of dash board lights e,g the oil, the battery and the other light, the yellow warning light with a picture of an engine with a fan on top and on the front. What does it mean when that...
that light means you have a problem with the emission system of the car ity could be anything from a loose gas cap to a failed sensor . As long as the light isnt flashing then you can drive the car untill you get it checked out. If the light is FLASHING then DONT DRIVE THE CAR.
Apr 12, 2009 | 1999 Honda Civic
SEAT TOLEDO WARNING LIGHTS
Could be the motor-management-warning light, but I guess it's the break-warning light. There might be too little breaking-fluid left in the lines ... A boardcomputer-readout should clarify this.
Otherwise, try parking on an ascending road with the nose pointing up, hit the hand-break and wait like 2 minutes; the light should come on. You might wanna retry it with the car's nose pointing downwards as well ... If so, definitely the breaking-fluid, otherwise probably not ;)
In any case - flashing warning light are never ok, so when you see it again and you're sure it's not just the ABS/ESP warning light, go and have your boardcomputer read-out, since it should contain useful errorcodes ..
Feb 07, 2009 | Volkswagen Passat Cars & Trucks
Ps3 when turning on green light yellow light flashes red then turns off
this is known as yellow light of death u could call sony for a repair which cost 150$ or fix it yourselve with a video on youtube.
Warning first option means u lose your data
Warning second option requires a skilled craftsman
Dec 08, 2008 | Sony Playstation 3 (PS3) Console
TCM Error
Hi, The little car indicates somthing is wrong but its not serious. Usually low water in the screen wash. If not then its a warning that some aspect of the service is due soon. Check the status from the IDrive (bottom left) and select diagnose...
Dec 03, 2008 | 2004 BMW 7 Series
Warning lights
hi
the handbrake light means your handbreaks on you switch might need to be replaced
the battery light means the battery is low on charge either a new battery or alternotor need to know more to answer that one
the curled up wire light could be the engine light
i would say maybe a wire has burnt out of you computer in the car has broken i would get it looked at before driving.
Jul 25, 2008 | 1984 Nissan Pulsar
Canon LASER SHOT LBP-5000 Printer Logo
236 people viewed this question
old marine
old marine
