Question about Haier Refrigerators
HC125FVS WON'T COOL. Clicks on then off immediately. Repair or toss out?
    President:
  • 1,124 Answers
If it is the compressor - and if the unit is not so new - then it would be advisable to toss it..
It might be worth your wile to get the components tested though.. It might not be the compressor.. It could be a capacitor or something else that might not be to much money to fix..
Have a great day ;o)
Posted on Sep 25, 2009
I've replaced every board on the samsung plasma and still clicks
What do you mean by clicks? Plasma televisions are hot cathode ray, there is thermal expansion that takes place due to heat.
Nov 04, 2016 | Samsung Televison & Video
Model code HLR4667WX/XAA won't turn on just clicks
Sounds like you have defective capacitors in the power supply board, cheap and easy fix for those with electronics repair skills
Jul 23, 2012 | Samsung LN-S4041D 40 in. LCD HDTV
Fridge makes a clicking noise everything in freezer melted and fridge won't cool. Model number ED5VHEXVQ03. I replaced the starting relay but not the resistor. Problem is the same still clicks...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 31, 2011 | Refrigerators
Dryer won't start immediately after finishing one load. needs cool off time. and now, won't start at all! what should i do?
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 24, 2011 | Dryers
I have a Haier HC125FVS Wine Cooler that has stopped cooling. The compressor hums but will not start. Is the starter #6R8MC a two piece part? I have unpluged the black part with that number, but there is...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
heatman101
Feb 25, 2011 | Haier HC125FVS Wine Cooler Beverage Cooler
The unit is not cooling
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Aug 14, 2010 | Haier HC125FVS Wine Cooler Beverage Cooler
Is clicking on and off but does not cool or run
Sounds like an "overload and relay" on the compressor. This is the equivalent to a starter on a car. When they go bad, the compressor just does a "buzzzzz.. click" about every 5 to ten minutes. In the worst case, you may have a bad compressor, but this is less common. Hope this helps!
Dec 06, 2009 | Haier HC125FVS Wine Cooler Beverage Cooler
There is a tiny hole in the inside back and the freon gas leaked, is this repairable?
Hi:
It should be repairable. You would need a Heating/ Air Conditioning repair shop to silver solder the hole closed, and possibly sweat on a valve to evacuate and refill the system. I would call around and ask if the shops do this sort of thing. I had a similar repair done on a window air conditioner, and it saved me money!
Nov 17, 2009 | Haier HC125FVS Wine Cooler Beverage Cooler
I HAVE A HOLE IN THE REFRIG.LINE OF A HAIER MO.HC125FVS
Hi, unfortunate, sorry to hear that, but it could be repaired, you should immediately dried up water/ice around punctured area, prevent water/ moisture entering punctured area (evaporator. lines), it's one of the worst thing, that could happened to any refrigeration system, it will be costly to repaired, if water get into your evaporator lines, compressor oil have to be replaced, evaporator will need to be flush out, repair puncture, change filter drier, it's better to replace compressor, vacuum system for about 2hrs. then recharge. it's better to use welding/ soldering, to repair punctured line, epoxy repair kit can be used to repair punctured (evaporator) lines . you will have to call a mechanic, if very little water entered punctured( evaporator) lines, then flushing of evaporator, (internal cleaning of lines (tube) changing of filter drier, with overnight vacuuming will do the job. take note, job like this, cannot be guaranteed. check cost for repairs, sometimes it's better to purchase a new one, and save yourself some headaches.next time never use sharp instruments in your freezer, it happened to me sometimes, it's what you get your hands on, what's available at the moment, good luck.
Aug 15, 2009 | Haier HC125FVS Wine Cooler Beverage Cooler
Refrigerators Logo
Top Haier Refrigerators Experts
John Tripp
John Tripp
doggzzz
Level 1 Expert
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
