Question about Kenmore 21 cu. ft. Top Freezer Refrigerator
Our Kenmore refrigerator model 106.9700516 has water under the crispers. We think that it is from our defrost line? Could this be right or is there some other problem?
    President:
  • 744 Answers
Hello, this sounds like you have a blockage in the drain tube, remove panel back/bottom of freezer..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curtain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the fridge is because the water has been leaking into the freezer and down the vent into the fridge instead of running into the drain hole...Please feel free to comment again if you need any further assistance. Mike
Posted on Sep 25, 2009
  • 92 Answers
SOURCE: refrigerator
check behind the drawers is there a water tank for water in thew door that would be my first guess
Posted on Feb 10, 2008
  • 93 Answers
SOURCE: How do I find the drain hose/plug on a 1996 kenmore refrig.
if you open the fridge door in the top you will see a small funnel typy that goes tru your back wakk this is where it normally cloged pull it out if no screws that hold it then clean it out or blw tru hose in the back of fridge if you can get access to it thanks from gille
Posted on Mar 15, 2009
  • 260 Answers
SOURCE: Where is the defrost timer for Kenmore 106 48262893
It might be the defroster itslef mine just went bad.
Posted on Apr 09, 2009
SOURCE: When refrigerator defrosts, water drains down into
i have the exact same problem...anyone??? now my fridge won't get cold at all and the freezer is still frozen
Posted on Apr 16, 2009
lojacksdad
  • 121 Answers
SOURCE: Water collects in bottom of refrigerator and gets in bins
there is a cup in the back wall of the fridge that is the drain pull it out gently and clean it plus take a small hose and blow through the small hole if there is no cup check under the crisper to see if the drain hole is there
Posted on Apr 17, 2009
Kenmore model 253.7419240p water pooling under crisper
Do you see any ice buildup on or behind the back freezer wall?
Oct 31, 2012 | Kenmore Refrigerators
Water pooling below the crisper drawers at bottom of the fridge. Kenmore model #363.79262991
Check out these tips...they can help you figure out what is going wrong with your refrigerator
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
May 15, 2011 | Kenmore Top Freezer Refrigerator
I have water collecting at the bottom of the frig under the crisper drawers. It appears to be coming from the freezer. Do I need to defrost and if so how?
It shouldnt need to be defrosted if it is a frost free refer. It sounds like your defrost drain line is clogged and backing up. Check the drain pan underneath refer.
Oct 13, 2010 | Kenmore 64802 Top Freezer Refrigerator
Every couple of days lots of water runs out on the floor.
It sounds like the defrost drain is clogged up. On some models there is a removeable white pull out cup located in the center back wall at the top in the refrigerator section. It is connected to a tube on the back of the refrigertor.If that is blocked water will be in the bottom under the crisper drawers.
Jun 10, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
Water under the crisper bins in the refrigerator -
Replace the door seal on the freezer. When they go bad, outside air leaks into the freezer and when it kicks into automatic defrost, the ice crystals melt and run down the back of the refrigerator. The oldar models had a drain under the crispers that drained into a pan near the condensor coils. It was a heat source that evaporated the water. Some brainstorm decided they weren't necessary.
Feb 13, 2009 | Whirlpool Refrigerators
Water won't evaporate from defrost tray. Fills up and runs on floor
the problem is he defrost drain from freezer is blocked and needs cleaning out
dismantle evap cover to get at drain
Mar 07, 2008 | Kenmore 64522 Top Freezer Refrigerator
Refrigerator
is it collecting under the crisper drawer? if so the drain line for the defrost system might be clogged. find where the drain tube empties by the compressor. blow into that tube. did a bunch of water come out? if yes, prob solved. hope this helps. let me know if it doesn't.
Oct 26, 2007 | Kenmore Elite HE4 Electric Dryer
Kenmore 21 cu. ft. Top Freezer Refrigerator Logo
391 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
