Question about Bosch Garden
Saw will not run at full throttle - Bosch Garden
    President:
  • 2,220 Answers
Duplicate post - close/delete
Posted on Sep 25, 2009
Why does it run at full throttle with no control?
check the linkage between carburetor and handle
Dec 17, 2015 | Garden
Rough idle, bogs when I give it throttle then dies
Brad:
Go back to the carburetor adjustment screws and snug them down gently. Do not use force on those screws or you'll damage the needle valve seats. Turn both screws out one and a quarter turns out and start the saw. The motor should stay running.... if not adjust the screws until it stays running. Turn one screw in until you hear the motor start to stall, then turn that screw out just a little bit. turn the other screw in until the saw starts to stall, then turn that screw out a little bit. Now if the saw bogs at full throttle, turn one screw out one quarter turn. See if the saw runs at full throttle... if not turn that same screw in to where it was and try the other screw the same way. If you're good, you can adjust the screw while the saw is running to get the best full throttle run. This is not an exact science, and it takes time and many adjustments to get the saw to idle and run at full throttle. Good luck... and have patience.
Oct 03, 2015 | Garden
Saw starts up fine...won't full throttle....dies
try cleaning air filter and replace spark plug
Jan 23, 2015 | Echo CS400 18" Chain Saw
Choke trigger on the handle will not lock to start the chainsaw
more information please..
To lock the choke on:-
1. depress dead mans trigget on top of back handle
2. squeeze throttle trigger fully in.
3. slide on switch fully down to 'full choke' position. 'it should stay there'.
4. Pull saw over until it fires once.
5. click 'on' switch up one position to 'half choke'
6. pull saw over again, saw should start running and be revving high.
7. 'blip' throttle, saw should stop revving and run on tick over.
Dec 31, 2012 | Stihl MS181 14" Chainsaw
42cc 18 inch craftsman chainsaw model 358-351910-18. Saw runs great at idle or while not cutting wood, when starting to cut wood just after the entire bar gets into the wood engine bogs down and chain...
Generally this is a fuel / air ratio problem. Usually it can be solved by a carb adjustment. On the carb there are usually two screws, one marked low or L , the other marked high or H. Low is your adjustment for idle mixture, high is for mixture at full throttle. The saw should Always be adjusted to run well during the cut. Make adjustments a little at a time, then try The saw. Continue small adjustments untill the saw is performing well at full throttle while Cutting.
Aug 09, 2011 | Poulan Pro Chain Saw 46cc 20"
Saw won't run at full throttle. Can't find toolto
sorry theres no adjustment on most of the 2&4 cycle engines especially if its a california carb you can try to clean or rebuild the carb or buy a new one
Apr 02, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
How to adjust a mcculloch 610 chainsaw carberator
there are two screws on the card of youy chainsaw one is the slow running jet the other is the full throttle jet start up saw run it till its hot adjust slow running jet first till saw ticks over ok then adjust fast running jet till you have full throttle,, start with both screw turned in to one and a half turns then adjust from there
Mar 28, 2010 | Makita DCS6401 20 20",64cc Chainsaw 2...
Trigger on poulan 3314 does not control speed. Saw runs at constant speed, somewhere above fast idle.
Open the cover over the air cleaner so that you can observe the action of the throttle cable and carburetor lever. Operate the throttle--normal action is lever wide open at full throttle and lever resting on idle stop screw when throttle released. If action is restricted, disassemble the handle where the throttle trigger is located and clean out the sawdust. Recheck throttle action. The throttle cable shouldn't require lubrication. Clean the air filter and check the operation of the engine. Hope this helps!
Jan 27, 2010 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
What makes a chain saw run full blast?
i suggest the throttle lincage is disconected
or the spring is broken
Jul 20, 2009 | Garden
Husky 455 dies out at full throttle or under load
Your carb may be the issue but your ignition coil could be the culprit. Once they start going bad, they can act up intermittently or give various symptoms from day to day. The fact that your saw dies at full load or under load, probably means that when your saw gets hot or requires more spark, your coil is not able to provide it. Your carb is easy enough to clean out, you can take it all apart and clean all screens, etc....
I just replaced my coil due to the exact same symptoms and now my saw runs great. $60 off ebay and you can put it on in 15 minutes yourself. Check your carb first though
Apr 13, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
Garden Logo
Top Bosch Garden Experts
roeb
George Merkley
George Merkley
Are you a Bosch Garden Expert? Answer questions, earn points and help others
