Question about 3M - FCS Projection Lamp for 1610, 150watts, 24V Multimedia Projector
I changed the bulb in the overhead but the light does not go on. The fan does. What next
Open casing - turn power on and check whether bulb at least flickers - if not perhaps you have touched the bulb itself and static has wrecked it
Posted on Jan 06, 2010
Fan works, light doesn't - replacing lamp doesn't help. Suspect electrical problem. Is it fixable and cost effective?
Diane,
Your bulb socket has probably burned out. As far as being cost effective, that would depend on whether you could find a new socket and how much someone would charge to put it in if you were not wanting to try yourself.
May 21, 2015 | 3M Model 1720 Overhead Projector 1700 BJV
Changing the interior map light
The bulbs is replaced from the back of the overhead console with 1/4 turn bulb holders.
the overhead console ( non rail version ) is held up with spring clips.
Open the rear compartment, and grab the rear corners and pull down 1 at a time. They are very hard to pull the 1st few times. Once you have the read released, there is another set of spring clips in the front, so be careful how far down you pull the rear, until the front is released.
Once you can see the back of the overhead console, you will see the 1/4 turn bulb holders for the map and interior lights.
Sep 18, 2011 | 2005 Ford F-150
How do you change the interior overhead light bulb?
Open your car bulet the go to where the overhead light holder hid remove the overhead light panel then remove the burnt bulb then replace with the new one then couple the panel back and close the bulet and here coming the overhead light working.
Jan 22, 2011 | 2002 Honda CR-V
Bought new bulb for projector buhl 2900 but still not working.Fan comes one but no light
Like many overhead projectors, the Buhl 2900 can accept TWO projector bulbs (the operating one plus a spare). Make sure you inserted your replacement bulb in the slot for the operating lamp. There is a slide lever on the front of the unit that allows you to quickly switch to the spare lamp. Turn off the projector and move the slider to switch to the other bulb slot. See if that does the trick. Good luck!
Nov 22, 2010 | Buhl 90 Series Open Head Overhead...
How to change cab interior map light
Open the rear compartment ( on the non rail overhead ) grab and pull down in each rear corner. The overhead is held on with 4 or 6 spring clips.
Once you have the overhead console down, the bulbs are installed from the rear with 1/4 turn bulb holders.
Jun 20, 2010 | 2006 Ford F-150
How do I remove the overhead console in my Ford 1-50 to change a light bulb. I ordered the bulb from the Ford house, but they want a small fortune to replace the bulb
With the overhead console ( non rail system ), open the sun glass bin, and grab each corner in the back, and pull down.
The overhead is held on with 4 or 6 spring clips, and pulls straight down.
The bulbs are 1/4 twist sockets installed from the back of the overhead console.
May 17, 2010 | 2006 Ford F-150
My overhead projector...it does not light up....the fan goes on but no light.
projector goes on then goes out. orange light on solid and flashing blue.
have had optoma look at it they said it was bulb.
Oct 23, 2009 | 3M EVW Overhead Projector Replacement Lamp...
Replace spark plugs 2004 dodge intrepid
__________________
Changing Spark Plugs
First off, on this model you don't have plug wires, you have coil packs with a boot and coil connected to the pack. The boot slides on the tops of the spark plug. The good thing about this is that you don't have to mark each wire to its location.
So to replace the plugs you need to disconnect the electrical connector to the coil pack and then unbolt the two bolts that mount the pack down, then remove the pack.
Next with a ratchet, an extension and a special spark plug socket, which has an insulator inside to protect the porcelain from getting cracked, remove the spark plugs.
Next step is to replace the plug, usually I slide off the boot from the coil pack and then remove the coil from inside the boot and slide the boot over the spark plug and start to thread the plug back in. Using this method allows to you feel if you are threading the plug in right. Then with a torque wrench you would torque the spark plug to the specs for the type of engine you have.
3.2/3.5L Engine (20 ft-lbs)
2.7L Engine (13 ft-lbs)
Next reinstall the coil pack with the two mounting bolts, it is only necessary to hand tigthen the two bolts. Then plug back in the electrical connector and continue this process on the next 5 spark plugs.
__________________
Changing Dome Light
To remove the map light bulbs you need to first remove the overhead console.
To do this you need to remove the screw at the front of the overhead console (which is more towards the front windshield).
Next you need to pry down on the rear of the overhead console and then disconnect the electrical connectors.
Then, with the overhead console pulled down, pull of the map light bulbholders and replace the bulbs.
Installation is the reverse of the removal process.
Apr 14, 2009 | 2003 Dodge Intrepid
Town & Country reading light bulbs power rating
The lamp holders in my 2002 Dodge Grand Caravan are brown. The correct lamp is a PC579.
Apr 09, 2009 | Chrysler Town and Country Cars & Trucks
Sharp carousel non functional overhead light
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Dec 31, 2008 | Sharp R-1480 Microwave Oven
91 people viewed this question
Top 3M Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a 3M Office Equipment and Supply Expert? Answer questions, earn points and help others
