Question about GE 24 in. Profile PDW7880G Built-in Dishwasher
My GE PDW7880G doesn't clean items in the top rack. The dishes on the bottom seem fine. I do make sure to push the top rack all the way back so it engages.
Removed the sprayer. the part that spins under the top rack and check that the holes arent clogged.
Posted on Feb 23, 2010
Why doesn't the top rack of my dishwasher clean dishes?
the water tube may be clogged at the sprayer on the top of the basin. probably have to disassemble and clean
Apr 14, 2016 | GE Dishwashers
Kenmore 3380957 rev a won't get dishes clean
Make sure that that upper arm is free to turn. Check it while you have dished installed, because sometimes, dishes on the lower rack may stick up too high and hit it. Otherwise, check the back of the water-supply tube attached to that upper rack.... Is it lining up with the water feed port or hole at the backof the dishwasher? Is there a gasket that is either ripped or missing? And check that wash arm carefully.... Might it be split or bent? Are the holes on the bottom clear? (Those holes are usually angled to push the arm around; if they are clogged, the arm won't rotate.)
Mar 15, 2012 | Kenmore Dishwashers
I have a Frigidaire dishwasher, PLD4460. Only 4 years old. The dishes on the top rack are not coming clean anymore. Something as simple as left small bits of broccoli do not even get rinsed out of the...
Hi
If the top rack of the dishwasher doesn't get clean, check your appliance to see if you can fix the problem.
First check the spray Arms to make sure the holes in the spray arms are free and clear of debris. Your dishwasher should have several spray arms, including one at the bottom of the tub, one under the top rack, and possibly a third spray arm on the top of the tub. Sometimes food and mineral deposits can block holes in the spray arms, preventing water from spraying effectively. If this occurs, warm some white vinegar and pour it into a spray bottle. Spray the holes with the vinegar and dislodge debris with a toothpick or large safety pin.
Then check to see if your dishwasher has clogged filters. Filters generally cover the drain valve area to catch debris as the water drains from the dishwasher. Many dishwashers have maintenance-free filters, but your dishwasher may have filters that need cleaning. Read your owner's manual before you perform any filter maintenance to avoid damaging your dishwasher.
Check your water temperature to make sure it's hot enough. Water that is under 120 degrees Fahrenheit may not be hot enough to clean dishes effectively. Turn your kitchen hot water tap on and wait until the water warms up completely. Fill a cup and measure the water temperature with a kitchen thermometer. If the water is less than 120 degrees Fahrenheit, turn your water heater up to 120 degrees.
Load the top rack properly. Place cups and bowls upside down in the rack and don't nest dishes because this can prevent water from reaching dishes. Don't overload the top rack. Instead, position each item so the dirty areas of the dishes will receive full contact with water spraying up from the main spray arm located beneath the top rack. Prevent items from hanging below the top rack, which could prevent the spray arm from rotating.
Also check this link for more helpful info:-
http://www.ehow.com/info_7977311_top-dishwasher-not-getting-clean.html
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Aug 15, 2011 | Dishwashers
Top wond (rack) doesn't clean. Dishes are very dirty at the end of the cycle. However, the bottom rack is fine......please respond asap if possible. Thanking you in advance. Connie
Connie,, make sure in loading the dishwasher you have room for the soap and water to make it to the top rack, (older models) on newer models you have a sprayer just under the rack make sure the sprayers are working fully,, to clean them you can use a hard brush and vinegar,, let stand for 5 minutes and rinse off, also, you can run vinegar ( white) through your machine,, to help clean the jets,, use in place of the soap , then run a couple of times empty to remove and let over odor
May 17, 2011 | Dishwashers
My dishes on the top rack are not coming out clean. We checked the spray things and they are not clogged. The top rack items are gritty and stale type water.
Make sure there is nothing obstructing the upper spray arm(dishes). Also, make sure the upper basket connects to the water inlet hole in the back of the tub, when it is pushed in all the way
Sep 21, 2010 | KitchenAid Dishwashers
Our GE Potscrubber 640 isn't cleaning the top rack items. They are neither cleaned nor rinsed. Does it have something to do with the "Rinse Dispenser" knob on the door? It's always been fully screwed in.
likely not .....the problem may be how you stack the dishes ....try doing a load with nothing on the bottom rack ....if the top rack items come clean then you may be stoping the water from reaching the top rack with the dishes on the bottom rack ....it's important to keep the center of the bottom rack free this is where the water comes from (on most models). to clean your upper rack .....have a close look at the inside of the machine to try and figure out where the water comes from ...it helps a lot to understand this ....good luck
Jul 25, 2009 | Dishwashers
TOP RACK DOESN'T RINSE
I would suggest you buy some CLR and run it through a full heavy cycle with the washer empty. Be sure to put it in all dispenser areas and sprinkle about 1/4 cup into the washer before starting.
Feb 16, 2009 | GE 24 in. Profile PDW7800 Built-in...
Top rack remains dirty
spin the top rotary arm to make sure it spins freely also take it off to see if its blocked (run it under tap) check all other filters too and when you load dishes make sure they do not obstuct top rotary arm if none of this works then it's time for an engineer im affraid good luck
Jan 26, 2008 | KitchenAid 24 in. KUDK02CR Built-in...
GE 24 in. Profile PDW7880G Built-in Dishwasher Logo
187 people viewed this question
Top GE Dishwashers Experts
Mike
Garth Jackson
jdthefixer
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
