Question about Panasonic PT-61LCX66 Television
I have a green circle just right of center on the top of the screen that is about 5 inches in diameter.How do i fix it? I also have the "Replace bulb now message, and reset timer". How do I make that go away?
    Genius:
  • Panasonic Master
  • 1,039 Answers
To remove the lamp message turn on tv. Hold down the vol - button on tv and hold the 0 button on the remote at the same time for 5 seconds. "THE LAMP TIME WAS REST TO 0" will appear on the screen. As far as the green circle you will need to replace the light engine.
Posted on Oct 04, 2009
What is the diameter of a circle
pi x radius square
ex circle with a 10" diameter
3.14 x 5 x 5
= 78.50 square inches
Feb 01, 2014 | Office Equipment & Supplies
I want to cut a circle where the outside line is 18 inches
To get a circle with a perimeter of 18 inches, you want a diameter of about 5.73 inches (just under 5 3/4 inches) or a radius of 2.86 inches (call it 2 7/8 inches). Get a compass, set its legs 2 and 7/8 inches apart, put one end at the center, and turn.
Oct 23, 2013 | Computers & Internet
Over past couple of months the tv has gotten 2 red spots in the lower right hand corner of screen about an inch in diameter, and recently a green spot in center top third of screen that is about 2 inches...
Unfortunately your light engine(also know as optic block) may need to be replaced. If your tv is out of warranty, it will probably cost around $1000 to fix. There is a slim possibility that the optics lens could have dust on it and a tech could clean it for much less than that. This is a very common problem in any dlp tv and they are all expensive to fix. I've replaced several of them at our shop, but about half of the customers won't have the tv fixed and will get a new one. Good luck!
Jul 30, 2010 | Panasonic PT-44LCX65 Television
How to get to blub on sony KDF 42we655
I have a Sony 42 inch Grand Wega KDF-E42A10. The screen has a yellow tint and a 6 inch diameter faint yellow circle around the center of the screen. How do I fix it?
Apr 27, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
I replaced the bulb 4 months ago and am getting about a 15 inch yellow hue circle in the center of my screen, did I get a bad bulb or what can I do?
no its not the lamp im sorry to tell you but you have a bad light engine if its a sony and less than 5 years old sony will replace it for free
Feb 03, 2010 | Televison & Video
Hitachi 50v500 LCD, at the center of the screen there is a lighter spot than the rest of the screen,about a 10 inch diameter circle. Is this a bulb problem.
If it is a redish oval it is not the bulb. Go to a black and white program and take a good look.
If it is the red or pink oval let me know and I will tell you what the problem is.
If this helps you rate this solution as I do this here for free.
SD TECH
Jan 09, 2010 | Hitachi 50V500 50 in. HD-Ready LCD...
My panasonic pt-61lcx has green dots on the screen)
sorry but it's the bulb.....hince why there is a class action lawsuit against them......
Feb 10, 2009 | Panasonic PT-50LC14 50" Rear Projection...
XBOX flashes color spots on screen during game play..
it may be your tv, not your 360, check connections, or fix geometric settings (if you live near a fault, or if you have your tv on top a mini fridge.)
Jan 10, 2009 | Microsoft Xbox 360 Console
Shadows on screen
Try moving a medium powered magnet (not one for picking up heavy objects and not a refrigerator holding one) over the distorted area. If that doesn't work, try a more powerful one. This worked for my Toshiba LCD. Good luck!
Jan 04, 2009 | Sylvania 6626LCT 26 in. LCD Television
Green spot
Easy fix. I had the same green spot problem with PT-52LCX65 and I removed the front panel (no screws). In the center is a panel that has two screws. Remove them and pull the cover off. There you will find the projection bulb. Do not clean the bulb but instead the base. Use a damp cloth to wipe the dust off the black disk (the base of the projection bulb housing). Apparently the dust through static electricity may cause enough magnetism to distort your picture. Hope this helps.
JK
May 23, 2007 | Panasonic PT-61LCX65 61" Rear Projection...
Panasonic PT-61LCX66 Television Logo
94 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
