Dryers Logo
Posted on Sep 25, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sqeaky dryer - Dryers
Anonymous
Level 2:
  • Expert 193 Answers
  • Posted on Sep 25, 2009
Anonymous
Expert
Level 2:
Answers
193
Questions
0
Helped
75313
Points
384
Most dryers have a fiber bearing located at the rear of the unit on the pivot post.It should be replaced,donot oil
Curtis Sewell
Level 3:
  • Dryers Master 7,482 Answers
Curtis Sewell
Dryers Master
Level 3:
Answers
7482
Questions
Helped
1942910
Points
24946
Sounds like the drum rollers are dry...lube or replace
Where is the belt located?? This maytag legacy elec dryer is 4 yrs old. over the last few mths it has made louder sqeaky noises but now all of a sudden it stopped tumbling!! It still heats up like it's...
it is inside the dryer, you will need to disassemble the dryer here is a website that may help:
http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
diagram of belt routing:
http://www.applianceaid.com/images/belt-config.JPG
Good Luck Tim
My kelvinator dryer began to squeak loudly and now it will not run. When I push the start button, there is a sound, but the dryer would not work.
sounds like the barrel has jammed try turning it by hand to see if its jammed if so then it will need to be serviced by a lic tech if the barrel is free turning then i would say it has broken its belt the sqeaky noise would be its bearings wearing out putting the barrel out of alyghnment this too will need replacing
merry christmas
Dec 22, 2010 • Dryers
Dryer is making a very loud sqeakie noise
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker's Testimonial " This should give me an ida of what to look for once I open er up " -
I have frigidaire dryer model #FER341AC0. It is squeaking. Im unsure how to take it apart to look at it.
start at the back its probably a sqeaky belt take back panel off and u should be able to access it if not u might have to dig a lil deeper no big deal
Very sqeaky and noisy when operating
There might be two problems:
Either the problem with the assembly of the rotor drum and bearings or bushes went wrong.
Or there is some garbage stucked so once open the cover and clean it and then check.
Aug 13, 2009 • GE Dryers
1helpful
Drum making intermittent sqeaky noise for 3-4 minutes then stops
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
ytg
1helpful
What is the noise coming from my dryer?
Good Afternoon,
If the shipper has insurance they should replace the dryer. No?
Sqeaky Neptune Dryer
Probably a slipping belt.  Either overloaded or the belt is drying out.
Top Dryers Experts
john h
