Question about Dell Inspiron 6400 Notebook
Memory stick pro not recognized any more by dell inspiron 6400
Memory stick pro stop recognizing by dell inspiron 6400 laptop.Cannot restore to earlier date as the restore points were deleted. I think it was a tune up program that deleted the restore points.
Any help appreciated
    Novelist:
  • 225 Answers
Try your memory stick to any other computer check if memory stick still working. if yes then update the BIOS of your computer by downloading the latest BIOS from the dell support site. If memory reader still not working after updating BIOS then have that part replace or if it is integrated with motherboard have your motherboard replaced.
Posted on Oct 09, 2009
  • 2,229 Answers
I suggest going into the control panel/device manager and removing all the usb devices.
Restart the computer and let it find the devices again. That might help.
Also--have you tried the stick in another computer just to make sure it works?
Posted on Sep 25, 2009
I installed two new 1 gigabyte memory sticks into a Dell Inspiron 6000, which previously only had 2 256 megabyte memory sticks installed. When I first installed the 2 gigs of new memory, the laptop turned...
Once you installed the memory, did you enter into the System BIOS Setup screen? Do this and verify that the system recognizes the newly installed 2GB RAM. This should let the system access the new memory once you boot.
Jan 01, 2011 | Dell Inspiron 6000 Notebook
Computer won't accept a compatible replacement battery for Dell Inspiron 6400
This could be due to a defective battery even though it is new. These batteries are what are called smart batteries. They have circuit boards mounted inside the battery pack that aids the computer in recognizing the battery as well as sending functional information to sensors in the laptop about battery health and performance. Try re-installing the old battery and see if it recognizes the old battery. if it does, the contact the company you purchased the battery from and let them know the problem. If the computer does not recognize the old battery anymore, there may be a problem with the charging circuit on the motherboard or the power adapter on the motherboard.
Jan 07, 2010 | Dell Inspiron 6400 Notebook
DEll Inspiron 6400 will not recognize a wireless connection or ethernet cable connection. It did work before we moved but now the computer will not detect connectivity.
Before your move did you tell your provider? as if you moved and your broadband is not activated at new address thats the problem!
Jan 05, 2010 | Dell Inspiron 6400 Notebook
I have dell inspiron 6400, Suddenly system doesn't recognize my genuine Dell 65W power suply which was working for 3 years
Please open Bios by pressing F2. If in Power settings it shows the ac type unknown ur system board needs replacement. If it is showing ac type none then the ac adapter needs to be replaced
Jul 16, 2009 | Dell Inspiron 6400 Notebook
Usb device not recognize
You mentioned that you uninstalled the unknown device from the Device manager. If you uninstall it then connected your usb flash drive you will see an error again on your device manager. This means that the driver for your usb port is not properly installed.
To install it, visit dell website, look for the model of your machine and locate the driver, download it then install from your machine.
Jun 02, 2009 | Dell Inspiron 6400 Notebook
USB device not recognized
This solution worked for me when I got the USB device not recognized message:
http://www.infobarrel.com/USB_Port_Repair
It can be quite frustrating. I've heard that older computers are more likely to have the USB device not recognized message.
May 31, 2009 | Dell Inspiron 6400 Notebook
My computer not recognized the USB Flash memory, but it recognized other device like the mouse, webcam scanner, digital camera ... Thanks for your help
if usb flash memory is working on other computer/laptop then do the following step.
Insert the usb flash memory.
Goto desktop, right-click my Computer, click Properties, click on Harware tab, click Device Manager button.
There should be yellow exclamation(!) sign showing Unknown Device
Right-click and select UnInstall.
Reboot your laptop
It should work.
May 30, 2009 | Dell Inspiron 6400 Notebook
Dell e1505 SD card reader issue
You installed the driver for your card reader for the laptop. If its not recognizing any cards you put in there then that means the reader is bad and since that is integrated onto the motherboard, replacing the motherboard would be the only option in order to fix that problem.
May 04, 2009 | Dell Inspiron E1505 Notebook
Dell Inspiron 6400 Vista CD Drive Does Not Recognize CDs
Try to use dvd cleaner disk to clean the lens, if it doesnot work, i think you have to replace your drive , this happens with Dell alot. but try to clean it, uninstall then install the driver back and check if its work.
Best Regards
Mar 14, 2009 | Dell Inspiron 6400 Notebook
Putting my Sony 512mb PRO memorystick into my Dell inspiron 6400
The Sony Memorystick Pro is smaller than the standard SD card slot on your system.
Looks like you'll need an external reader
http://www0.dealtime.com/xPO-Sony-Sony-17-IN-1-CARD-READER-USB
Jun 09, 2008 | Dell Inspiron 6400 Notebook
Dell Inspiron 6400 Notebook Logo
242 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
