Question about HP LaserJet 4700 Printer
HP 4700 Color printer. User sent document to manual feed tray. Now it is stuck defaulting to manual feed tray for everyone. I checked the setting and manual feed is set to OFF. I rebooted, still defaulting to manual. Compared it's menu map to another 4700 and settings are the same????
  • 27 Answers
SOURCE: How set Printer to Autoselect Tray
This will most likely be the in the menu on the printer. Refer to the users manual and how to access those setting.
Posted on Jan 29, 2007
SOURCE: Ricoh CL3100N
I've noticed that sometimes in "Page setup" (assuming it is a MS word document you are printing), there are two columns under the "Paper" tab. the left column is the paper source for the first page and the second column is for all following pages. Ensure both columns are set to auto tray select or tray1/2.
My understanding for the second page to ask for paper is either:
1/ what is mentioned above,
2/ the second page is not an A4 size document (mixed size pages).
hope this helps.
Posted on Jul 21, 2008
the_fire
  • 432 Answers
SOURCE: HP Laserjet 5000dn
if you using office go to page setup and select the tray(s) that you want to use for the first page and other pages ( both must be the same ) unless you only want the first page as letter head and the rest on plain paper or something along those lines ?
Also if you go into the properties of the printer and go to advanced and then click on the printing defaults button and see if the options in there are the same or different to whats in printing preferences.
If they are set to tray 1 then it will default to tray 1
Posted on Apr 13, 2009
SOURCE: Keeps telling me to load tray 1.
dragon is a moron... cram cheese into the cyan ink cartridge.
Posted on Jul 08, 2009
  • 4 Answers
SOURCE: HP Laserjet 4700 Always Defaults to Tray 1
Your tray 1 might be open (even just partially) or your manual feed setting might be on. You can find this setting under > Configure device / Printing / Manual Feed
Posted on Sep 18, 2009
Tray which printer prints from.
Just had this problem and stumbled upon how to fix it. Check the guides in your tray 2. Our back guide was slightly off of the proper spot for letter size paper. This was causing the printer to think the tray had a custom size of paper in it. Your document is probably trying to print on letter size paper and when it doesn't think the paper is in there it switches to tray 1.
Apr 08, 2010 | HP LaserJet 4700 Printer
Printer will not kick out document automatically, attention lite keeps flashing. tray 2 selected but always defaults back to tray 1
Sounds like you have a mismatch in the paper you are trying to print on and the paper that is loaded in the printer. HP printers look to feed paper from tray 1 anytime the computer settings don't match the paper loaded in tray 2. Tray 1 is the multi purpose tray and prety much any size paper can be loaded in tray 1. Double check your document settings and double check the paper size loaded in the paper tray 2 and make sure they match. Also try printing a different document to see if the error persists. If it does this on everything you try to print you should also double check teh rear guide in the paper tray. There is a rear guide in paper tray 2. If it slides back too far it will make the printer think that paper longer than 8 1/2 x 11 is loaded. Push the paper all the way forward in the tray and push the rear guide until it is snug with the tail end of the paper stack.
Nov 01, 2009 | HP LaserJet 4700 Printer
HP color laserjet 4600 dn printer How do I set
From the control panel of the printer, do the following:
1. arrow down once to highlight the 2nd item: "paper handling".
2. press the check button (turquoise color) to select this option.
3. arrow down 2x's until you highlight the "tray 2 size".
4. hit the check button to select this item.
5. You should see a size that is "letter" and there should be a ' * ' asterisk which means that is the default setting. If you see other paper sizes as well, then arrow up or arrow down to highlight the preferred size, and then press the check button to insert the asterisk ' * ' which will set that as the default.
6. you change the paper type as well as paper size for the other trays in the same fashion. Most HP printers will select paper according to the SIZE as well as the TYPE. The printer can "sense" the paper size in the paper cassette tray by the stops that hold the paper. Therefore the printer will choose that paper based upon the SIZE and what you define as its type.
Sep 24, 2009 | HP LaserJet 4600dn Color Printer
Jun 25, 2009 | HP LaserJet 4700 Printer
HP 1700cp - Can only print with Rear Manual Feed and Not Tray 1
does the printer pickup the paper from tray 1?
if not check the roller, it may time for replacement.
2- make sure the computer program is set at autofeed as default.
or tray 1 as default.
May 22, 2009 | HP Color Inkjet cp1700ps Printer
HP Laserjet 5000dn
Apr 13, 2009 | HP LaserJet 5000dn Printer
HP Color laserjet 4700 is printing in landscape
check paper settings in paper handling to set
at plain paper/ letter. or reset factory defaults.
check paper size on tray if app, set to standard or
letter ,not custom
do cold reset . must reinstall network info afterwards.
Jan 20, 2009 | HP LaserJet color laser printer
The Paper light keeps flashing when theres paper in the printer
A few things could be happening here.
1. Clear the print queue, and if there are jobs that won't delete, reboot the computer.
2. Now clear the jobs on the printer (cancel job button) until the status light turns green.
3. Put a piece of paper in the manual feed tray on the front.
4. Print a test page.
If the test page prints to the paper in the manual feed tray, then it is set as the default tray. Go into the printer settings and change it to "auto" or tray 1. If the test page prints to tray 1, but the original document you tried to print (when it got stuck) still won't print, cancel the job. Now, again, put paper in the manual feed tray. Try to print the document again and if it pulls from there, go into page setup of your document and change the setting from "manual" to "auto" or tray 1. Clear the job again (if it's stuck) and you should be able to print again. Hope this helps. This is one of the most common solutions - it happens a lot, especially with documents that are emailed from other people and once they get stuck in the queue, nothing will print (except the test pages directly from the printer, like you describe).
Jun 25, 2008 | Brother HL 5250DN Laser Printer
Keep getting "11 load letter in tray 1" message
Are the print jobs being sent to printer all the same page size?
Are they all print jobs sent letter page size and your printers cassettes are set for A4 or something?
Your printer is asking for letter size paper, because any paper it has is not set to letter  and document that it is trying to print has been sent as that size.
Check what options you have on print driver on pc as far as Tray defaults, paper type and size settings
Check printer settings via its keypad as to tray defaults, paper size set for each tray and paper type, some printers have paper size switchs on their trays too.
Oct 26, 2007 | IBM Network Printer 12 Laser
Jan 26, 2007 | HP LaserJet 4250n Printer
HP LaserJet 4700 Printer Logo
Seeker5211
Seeker5211
