My Rudd achiever 90+ furnace won't start. Have had a tech here twice from the installing contractor to correct this. Each time its spider eggs blocking a tube connecting a sensor according to them. Any ideas beyond their suggestion of spraying pesticide inside the air intake and the furnace itself. Is there a service manual available on line somewhere???
  • 20 Answers
Hmm, spiders in the pressure switch tube, not impossible however they usually go for the gas orifice, and yes I'm serious. If the problem is in the pressure switch tubing it is usually condensation, which is normally present in the vent system. If the tube loops down and back up then this makes a water trap, which will not allow the pressure switch to sense the pressure from the vent motor. Otherwise there could be an issue with the venting, also any dips or sags will cause a water trap. did he use a manometer to determine this issue? if the venting, the heat exchanger and the connecting tube are fine, then it could be a defective pressure switch. It's simply a proccess of elimination, by inspection, not parts replacement. The pressure switch is nothing more than a diaphragm membrane which is pulled or pushed by the pressure difference created by the vent motor, a calibrated spring determines how much force is needed to move the diaphragm and close an electric switch. Not sure if that will solve the issue, but it should give you somewhere to start.
Posted on Sep 26, 2009
Was this job done properly, and if not, then how really bad it is? I would rather hire the same person again, but not if the previous job is completely wrong ?
Some times new specs come into force. some things that were ok five years ago will not pass to day. can you get a gas inspector to check it over ? then go with his advice. It appears you have two Quotes , So why not get one from the person who installed it if you would rather him do the installation .
Mar 03, 2016 | Ruud RGTM10ERBJS 100K BTU 95%...
What is the AFUE of my Rudd Achiever 90 Plus with model number UGRA-07EMAES
Per Rudd's website and also as the name implies, the min rating is 90. The 90+ can be as high as 93 but is stated as "plus" to cover the many possible installation scenarios which will impact overall efficiency of the unit.
Sep 11, 2014 | Heating & Cooling
Ruud achiever 90 plus furnace will not start with door on.
I would try to check your return air first, making sure there is no blockage and that your air filters are clean. It almost sounds like when you take the cover off, you are pulling enough air into the system for it to run, but as soon as you close it off, it's not getting enough air flow, therefore, tripping a limit switch inside the furnace. Most furnaces will also have the codes for the flashing lights and what they mean on the inside of the door covers.
Feb 02, 2010 | LG LW1200ER Air Conditioner
I have a Rudd ultra series 16.0 and I cant get the air to blow hot..I have heat on and "hold at 90" but it wont heat..ac is less than 1 yr old
I am curious if the unit is short cycling. If it is, take the face off of your thermostat and turn the anticipator to .4 and when you can have a tech take an amp draw on your furnace. If it is a new furnace and old thermostat, it may not have been checked with the new install
Jan 05, 2010 | Heating & Cooling
HOW MANY BTU IS A RUDD ACHIEVER 90 PLUS FURNACE MODEL RCBA-6089GG24X1?
This is the Model number of your coil which is a 5-ton. Your heater Model number will be behind the front panel of the heater.
Jan 04, 2010 | Heating & Cooling
Need info for RUDD upflow oil furnaces
Contact your nearest Ruud DISTRIBUTOR, usually The Noland Company, and ask them if they could go into the historical documents and print out or send you the files for the wiring, spec's and parts breakdown. From the model number, that unit is rated for 3 tons of a/c. You can find a 3 ton coil that will fit in the space and get a straight cool condenser of 3 tons cooling and swap thermostats so it brings on the furnace and fan in heat and the condenser and fan in cooling. Or just add a simple White - Rogers model 444 for the cooling. Ron
May 06, 2009 | Ruud UBHC Air Conditioner
Ruud achiever 90 plus won`t start at times
sounds like you have a heat pump heat pumps dont work below 30* temps you should have some type of backup heat
Feb 05, 2009 | Ruud UBHC Air Conditioner
Check the data information on the unit there should be a troubleshooting guide that tells you what the two lights blinking once means. hope this helps.good luck. normally found with schematic
Heating & Cooling Logo
335 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
