Question about HP PSC 1610 All-In-One InkJet Printer
1610 printer gives carriage jammed message
Carriage moves freely manually but when pressing ok button sounds like it is stuck at right end. Also getting out of paper message but there is plenty of paper. Tried reloading paper. Nothing is jammed that I can see.
dg9dotorg
  • 151 Answers
SOURCE: paper jam in carriage
There is a latch at the back of your printer that opens so you can remove paper jams from the back. You can start there and then slowly peel away the rest of the paper that jammed...
Posted on Mar 10, 2008
  • 14 Answers
SOURCE: Carriage Jam -- Paper Jam
I have serviced an officejet pro L7580 which was showing a paper jam error when powered on. our customer had had a paper jam and removed the paper . I found small peices of paper in the pick up assy gears. If you remove the rear door, you need to check the 2 small white gears on the left. turn the roller slowly by hand and clear any paper stuck between the teeth. (they may be very small).
after doing this....no more paper jam errors for me!
Posted on Aug 01, 2008
SOURCE: hp psc 1610 printer ... error message alternates between carriage jam and out of paper
i cleaned the clear file strip behind the carriage by rubbing it between my fingers and my printer started working again. before that i had paper jam and carriage jam and it wouldn't do any printing or copying.
Posted on Nov 09, 2008
vipin_yadav1
  • 80 Answers
SOURCE: How to Clear carriage jam
Dear it's the carriage jam error. so it mean that your carriage is jam not paper. so open the printer where you insert the cartridge. check whether it is jam or what . cartridge carrier is jam kindly turn off the printer and try to move the cartridge head by hand very gently and if seems to be stuck than check for anything which abort him to move freely so than might be anything like dust or else. when you get success in moving the head put some machine lubricant on the rod on which head moves and check it ok.
Posted on Dec 04, 2008
rockfixya
  • 679 Answers
SOURCE: HP c4280 says carriage jam
SolutionStep one: Perform a power reset and connect the printer directly into the electrical outlet Remove all the paper loaded in the main input tray.Make sure that the product is turned off.
Disconnect the USB cable from the back of the product.
Disconnect the power cord from the product.
Disconnect the power cord from the electrical outlet and wait 10 seconds.
Reconnect the power cord directly into the electrical outlet and check for the following.
Make sure that the power cord used is the one provided with the product.
If a computer is connected to the product, make sure that the computer is connected to a grounded (three-prong) wall outlet.
Make sure that the power cord is firmly connected to both the product and the power supply.
Reconnect the power cord to the back of the product.
Press the power button ( ) to turn on the product.
Reconnect the USB cable to the back of the product.
If the issue is resolved, proceed to Step six: Print a self-test page.
If the issue continues, proceed to the next step.
for more information please go to below link>>
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01458822&cc=us&lc=en&dlc=en
Thanks for using FixYa.
Posted on Feb 03, 2009
Why doesn't my HP OfficeJet 7500A carriage move? It is jammed
Try to turn it off, open cover and move carriage a little bit by hand; don't push too hard. For some time it'll get back to life.
Feb 02, 2013 | HP OfficeJet Office Equipment & Supplies
Message appears "Paper jam".
Paper jams can be true or false. A false paper jam occurs when the error message displays, but no jammed paper is in the product. The following solutions apply to both true and false paper jam errors.
Print a self-test report Use the following steps to print a self-test report.
  1. Load plain white paper in the input tray.
  2. Press Setup , and then press 2 . The Print Report menu displays.
  3. Press 1 to select and print a Self-Test Report
Solution one: Clear the paper jam Step one: Remove loose paper from the tray Remove any loose sheets of paper from the input tray and the output tray.
Step two: Clear the jam from the back of the All-in-One
  1. Figure 2: Remove the rear access doorc01562020.gif
  2. Gently pull any jammed paper out of the rollers inside the product.
  3. Carefully remove any scraps of paper that are still stuck in the product.
  4. Reattach the rear access door. Insert the two posts on the right side of the door into the holes on the product, and then push the door in until it snaps into place.
  5. Reconnect the power cord to the back of the product, and then press the Power button (c01602202.gif ) to turn on the product.
Step three: Clear the jam from the front of the All-in-One Follow these steps to remove the paper jam from the front of the product.
  1. Without opening the cartridge access door, check the tray for jammed paper that you cannot remove from the back.
  2. If you see jammed paper, gently pull it out.
Step four: Print a self-test report
  • If the issue persists , continue with the next solution.
Solution two: Make sure that the carriage can move freely Follow these steps to make sure that the carriage can move freely. Step one: Check the paper path
  1. Check for any paper or object that might be stopping the carriage. Figure 4: Example of paper stuck in cartridge access areac01950807.gif
  2. Remove any paper or objects you find.
  3. Reach inside the product, and then manually move the carriage.
    • If the carriage is stuck on the right side , move the carriage to the left side of the product.
    • If the carriage is stuck on the left side , move the carriage to the right side of the product.
    • If the carriage is stuck in the middle , move the carriage to the right.
  4. Remove any paper or obstructions found.
  5. Make sure that the carriage can move freely across the width of the product by gently pushing the carriage to the left, and then to the righ
Step two: Print a self-test report
  • If the self-test report does not print , continue with the next solution.
Solution three: Clean the rollers and the rear access door Dust, paper fiber, and other debris might accumulate on the paper feed rollers and cause paper jams and paper feed issues. Follow these steps to clean the paper feed rollers inside the product. Step one: Clean the rollers
  1. Press the Power button (c01602202.gif ) to turn off the product.
  2. Disconnect the power cord from the back of the product.
  3. Press in the tab on the left side of the rear access door, and then pull the door away from the product to remove it. Figure 6: Remove the rear access doorc01562020.gif
  4. Lightly dampen a clean, lint-free cloth with bottled or distilled water, and then squeeze any excess liquid from the cloth.
  5. Press the cloth against the rollers and rotate them upwards with your fingers. Apply a moderate amount of pressure to remove any dust or dirt buildup. Figure 7: Rotate the paper feed rollersc00212278.jpg
  6. Make sure that the paper feed rollers on the rear access door are clean, free of paper bits, and rotate freely.
  7. Clean the surface and the rollers of the rear access door the same way you cleaned the large rollers inside the product.
  8. Replace the rear access door. Insert the two posts on the right of the door into the holes on the product, and then push the door in until it snaps into place.
Solution four: Service the product
Aug 08, 2011 | HP PSC 1610 All-In-One InkJet Printer
Get paper jam message, paper is marked at the begining of the sheet but not jammed. When select copy button ,there is no paper jam problem, only when print command is used to print a document
Please follow this instructions to resolve your issue.
Solution # 1 Power cycle the printer
  1. Turn off the printer
  2. Unplug the power cable at the back of the printer
  3. Wait for at least 1min.
  4. Plug the power cable again
  5. Print test page using the printer itself (press and hold the OK and HELP buttons on the front panel of the printer, until it will prints a test page, then release the buttons.)
If you still having that error message, please proceed to the next step.
Solution #2 Clear any jams on the printer itself
  1. Turn off the printer.
  2. Please make sure that you will not take out any jammed papers in front of the printer, it can cause a mechanical damage on the printer.
  3. At the back of the printer, take out the access door.
  4. Clear any jammed papers, please make sure to clear the rollers.
Solution #3 Please make sure that the carriage will moves freely
  2. Open the cartridge access door
  3. Disconnect the power cable at the back of the printer.
  4. Check for any paper or other object that might restrict the carriage movement.
  5. Reach inside the product through the cartridge access door, and then manually move the carriage.
  6. Remove any paper or objects you find that restrict the movement of the carriage.
  7. Make sure the carriage can move freely across the width of the product. Firmly push the carriage to the left, and then to the right.
  8. Close the cartridge access door.
  9. Reconnect the power cable to the rear of the product.
  10. Press the power button to turn on the printer.
  11. Print test page using the printer itself (press and hold the OK and HELP buttons on the front panel of the printer, until it will prints a test page, then release the buttons.)
If your still having issues with it you need to contact HP to have your printer replace, if your printer is still in warranty you don't need to pay for anything, but if the printer is out of warranty charges may apply. 1800-474-6836
Good luck :)
Feb 17, 2011 | HP Photosmart C5180 All-In-One InkJet...
I just changed the (2) ink cartridges in my HP PCS 1610 All-in-One HP printer and now get an error message "CARRIAGE JAM - OPEN DOOR. CLEAR CARRIAGE JAM, AND THEN PRESS OK." I don't see any jam...
Have you tried moving the carriage to see if it really is jammed? Maybe you haven't put the levers down properly on your new cartridges....remove them, see if the carriage slides, then refit them and check the carriage again. You wont visually 'see' a carriage jam,; you have to try moving it. By the way, if it doesn't move, DONT force it to try and overcome the jam try and reason out why it doesn't move.
Hope this helps!
nicam49
Jan 18, 2011 | HP PSC 1610v All-in-One Printer
My hp laserjet 2430 keeps showing paper jam on tray 2 but no paper jam there. I have to press the ok button always to proceed. what could be the problem
Step one: Remove any loose paper Remove any loose sheets of paper from the input tray and the output tray.
CAUTION: Do not remove jammed paper at this stage. Trying to clear jammed paper from the front of the product can damage the print mechanism. Step two: Clear the paper jam from the rear of the All-in-One Follow these steps to clear the paper jam from the rear of the product.
CAUTION: Never pull jammed paper from the front of the product. If you can pull it from the rear of the product or the tray, always try the rear first. Pulling paper from inside the front cover can cause mechanical damage to the product.
  • Press the Power button (c01602202.gif ) to turn on the product.
  • Disconnect the power cord from the rear of the product.
    Remove the rear access door. Press in the release tab on the rear access door, and then pull the door away from the product. Figure 2: Remove the rear access doorc00909313.gif
  • Gently remove any jammed paper or bits of torn paper from the rollers inside the product. Use both hands to pull any whole sheets of paper to avoid tearing them.
    CAUTION: Use a flashlight to thoroughly check the rollers and wheels for torn pieces of paper that might remain inside the product. If any torn pieces of paper remain inside the product, more jams are likely to occur.
  • Check the rollers on the rear access door. If rollers are missing or do not turn freely, buy a replacement rear access door. Click here to order a replacement part from HP .
  • Open the cartridge door.
    Without turning off the product, disconnect the power cord from the back of the product.
    CAUTION: You must disconnect the power cord to move parts by hand without the risk of an electrical shock.
  • Disconnect the power cord from the wall outlet.
  • Look inside the product to see where the carriage is stuck, and then check for any torn paper or objects that might be restricting the carriage.
    NOTE: You might need a flashlight to illuminate areas for proper viewing.
  • Reach inside the product, and then manually move the carriage.
    • If the carriage is stuck on the right side of the product , move the carriage to the left side of the product.
    • If the carriage is stuck on the left side of the product , move the carriage to the right side of the product.
    • If the carriage is stuck in the middle of the product , move the carriage to the right side of the product.
  • Remove all traces of paper or obstructions found.
  • Make sure the carriage can move freely across the width of the product. Firmly push the carriage to the left side of the product, and then to the right side.Close the cartridge door.Reconnect the power cord to the back of the product.Reconnect the power cord to the wall outlet.Press the Power button (c01602202.gif ) to turn on the product.
  • Nov 11, 2010 | HP LaserJet 2430dtn Printer
    HP PSC 1610 printer gives error message: Carriage Jam, clear carriage. I open the door and there isn't a Jam. I tried the solution (clean cartridge, turn off/on couldn't reset) posted by nanotech 9 Aug...
    If you are getting a 'carriage jam' error as soon as you turn on your printer with no tasks in progress, then check for any piece of paper stuck in the carriage. Remove the paper carefully. If the paper tears, part of it might remain inside the paper path and damage the product.
    Follow the steps for fix HP Printer Carriage Jam
    • Turn off the printer and open it to see where the paper is stuck.
    • Manually move the carriage toward the opposite side.
    • Check the paper path and remove any piece of paper or any other object that is stuck in the path.
    • Reconnect the power cord and turn on the printer.
    Aug 21, 2010 | HP PSC 1610 All-In-One InkJet Printer
    HP 1610 Carriage Jam
    Remove the ink jet, make sure you removed any pckg. material and the contacts cover on it.
    Nov 10, 2017 | HP PSC 1610 All-In-One InkJet Printer
    Epson R320 "General Error" message - unable to clear
    If you are getting a 'carriage jam' error as soon as you turn on your Epson printer with no tasks in progress, then check for any piece of paper stuck in the carriage. Remove the paper carefully. If the paper tears, part of it might remain inside the paper path and damage the product.
    Fix 'Carriage Jam' : Open Door, clear carriage jam,
    and then press OK to continue' error message
    http://www.fixya.com/support/t5192341-epson_photo_1400_paper_feed_ink
    Feb 22, 2009 | Epson Stylus Photo R320 InkJet Printer
    How to Clear carriage jam on HP PSC 1610 Printer? No obvious paper jam visible.
    Dec 04, 2008 | HP Office Equipment & Supplies
    Epson R320 carriage jammed
    The ink cartridge is probably not inserted correctly.  Unplug the printer and manually move the carriage to a location where you can take the ink cartridge out.
    Remove it and reinsert it, making sure that it is fully located, before applying the power.
    Make sure that there is nothing blocking the carriage movement, such as some remnant of paper.
    Oct 21, 2008 | Epson Stylus Photo R220 InkJet Printer
    HP PSC 1610 All-In-One InkJet Printer Logo
    52 people viewed this question
    mukhtar21 shaikh
    mukhtar21 shaikh
