Question about Electric Superwinch LP8500 Series Utility & Off Road Winch LP 8500 12 Volt DC Electr
Wiring up super winch
Hi does any no how to wire up a lp8500 super winch.i am baffeled what colour goes where? could do with wiring diagram cheers
I am wiring a Superwinch 4500 to my Yamaha Rhino.
Problem the two red wires go to the key switch.
Do they just splice into the 12 wire ?
Posted on Sep 21, 2010
How do i rewire a warn 12v 8000lb winch
There are lots of links on the internet to wiring diagrams; just make sure they match the winch you have
warn 8000 lb winch wiring diagram Google Search
Feb 01, 2015 | Cars & Trucks
What is the wiring diagram for winch remote
Ramsey website shows Badger wiring diagram for solenoid hookup etc but not plug. Shouldn't take a good DIY mech or auto electrician too long to work out which wire goes where especially if they loosen the socket it plugs into which should reveal which wires go to where on the solenoid block. Basically that's all they do, there's a supply side, a ground wire and all the hand control does is switch the supply to the solenoid for forward and reverse. From memory there's only 4 wires? Supply to hand control,1 wire to one sol, 1 wire to other sol, 1 ground wire. Supply could be red, ground is usually black, fwd / rev will be 2 other colours. Look at the socket to see match up?
Jul 20, 2014 | 115101: Ramsey Badger Series Winches
I need a winch wiring diagram
The third wire should be the extra ground wire and is usually grounded to the metal body of the device.
Jan 08, 2014 | chicago electric power tools 1500 Lb....
How to wire the superwinchS4000 to my quad
Here is a sample of how to wire a winch. I have built my own box with relays to swap the power for reverse etc I'm not sure if you have to buy an extra kit where someone has done the work for you or not. It looks neater when purchased. Click here
Nov 26, 2013 | Electric Superwinch LP8500 Series Utility...
Wire diagram for 9' ATV Rocker Winch Handle Bar Mount Remote Control Thu to the winch
Here's the owner's manual - it includes wiring & installation information:
http://mediacdn.shopatron.com/media/mfg/4377/media_document/4398/10991.pdf
If you're looking for information that is not provided in the manual, you should contact Superwinch directly:
In the USA:
Superwinch, Inc.
Winch Drive
Putnam, CT 06260
U.S.A.
Tel: (860) 928-7787
Fax: (860) 963-0811
e-mail: info@superwinch.com
Elsewhere:
Superwinch, Inc.
Unit D, Union Mine Road
Pitts Cleave Ind Est
Tavistock, Devon
PL19 OPW England
Tel: 44 (0) 1822 619222
Fax: 44 (0) 1822 615204
e-mail: sales@superwinch.net
I hope this helps & good luck!
Jan 13, 2012 | Superwinch 1120210 Atv Lt2000 Series Winch
I havea LP8500 superwinch. I unhooked the cover wires RED,WHITE and Black and I can remember how they go back onto the solenoids. can you help me. thanks mark
This may help (or maybe not):
The Black wire is the ground wire, and the other two are considered Hot wires, and their
order does not matter - they carry 240 Volts AC.
So, once you identify which terminal on the solenoid is ground, connect Black to it, then just hook up the remaining two Hot wires in any order.
Jul 04, 2011 | Electric Superwinch LP8500 Series Utility...
When I try and use the winch all I get is a clicking sound from the control box. The winch motor will not engage in or out. When the winch clutch is placed in the out position I can free spool the cable...
It sounds like you have broken a pinion tooth. Remove the screw from the end housings and open to inspect the drive gears. Parts can be purchased from Superwinch for these or off e-Bay.
Jan 16, 2011 | Electric Superwinch LP8500 Series Utility...
My winch won't work anymore...there is a clicking noise and winch wont turn....I check the connection and its good.
Take your voltmeter and verify your voltage at the switch. If it is 11.5 or better, try reversing the motor. Reverse direction requires less ampreage to run and should work fine, then try forward or wind.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
Nov 04, 2010 | Electric Superwinch LP8500 Series Utility...
Electric Superwinch LP8500 Series Utility & Off Road Winch LP 8500 12 Volt DC Electr Logo
2,630 people viewed this question
Top Electrical Supplies Experts
ashburton
Steve
epangan29
Are you an Electrical Supply Expert? Answer questions, earn points and help others
