Question about Asrock P4I45GV R5 Motherboard
My pc shuts down after few minute...... - Asrock P4I45GV R5 Motherboard
  • 104 Answers
Check that the system is not overheating by confirming that cpu fan and the chasis fan are working fine. A bad or incompartible hard ware eg memory may also cause this problem. check these also
Posted on Sep 25, 2009
  • 3,153 Answers
Your fan speeds up and slows down in response to temperature inside the computer. More so the CPU.
I would suggest getting a can of compressed air made for computers
take it outside, take of the side and blow all the gunk out of there, Really go to town around the fan (you might want to wear eye protection)
While you are in there just check that the CPU cooler itself is not loose
If it is it will have to be re-seated.
If it needs re-seating don't just take it off and put it back on as that might make things worse with your temperature problem the have to be cleaned and new thermal grease put on
I think this may be your problem before you buy a new CPU make sure you check the cooler assembly and make sure you use new thermal grease ($2-5)
DON'T remove the CPU just the fan/cooler assembly.
You must clean both the surfaces without scraping anything off. Use isopropynol alcohol and cotton bud sticks until both surfaces are clean, you can use your finger nail to scrape harder residue if you wish but nothing else.
DON'T pour the alcohol over the CPU
Now apply some new thermal grease (most computer shops have it)
Be careful about how much you put on
Here are
some basic instructions
Once you have re-assembled your cooler and re-connected it check everything is OK and power up the computer.
If everything went to plan you should now be back in business
  • 5,603 Answers
Check cooling fan and that system is NOT overclocked. It may be overheating. Make sure heatsink for processor is done right.
My pc will shut down after a couple of minutes,?
have you checked the fan on the inside of cpu? if the fan is out, the cpu will overheat and shut down after a few minutes
Feb 19, 2013 | ASUS Computers & Internet
My aspire one d257 will shut down automotically afte a few minutes
Try running it on a hard flat surface and see if it runs better. The shutting down could be due to the machine overheating due to poor airflow. Try cleaning the air vents around the case, make sure they are not dusty.
Apr 09, 2012 | Acer Aspire One D257 Netbook
Shut's down after a few minutes.
I suggest you reinstall the Operating System (Windows)
Jul 29, 2010 | Acer Aspire 5315 Notebook
The unit runs Ok for a few minutes and then shuts down.
Does it do this on just battery power or with an external power source? If on battery poer, then the battery if defective.
- Jim
Jul 20, 2010 | Garmin Nuvi 660 GPS Receiver
PC shuts down. When you turn on the pc it shuts
try to change the source, that should solve the problem. But before try reset CMOS. (if you don`t know how to do it by jumper simple remove the battery from the mainboard for 5 minutes and then plug it back on..and after that turn on your computer and press F1 for default settings)
Oct 27, 2009 | E-Machines eMachines Desktop PC
M9700 starts up but shuts down few minutes after vista loads
Sounds like it is a problem with the m9700 overheating. I have just repaired an m9700 with this exact issue and it was resolved by taking the CPU heatblock off, removing the dried/caked-on heat compound, and replacing it with my own (Arctic Silver 5).
Was 91c before, now down to 74c max on load (Measured with coretemp). Random crashing has stopped.
Sep 03, 2009 | Alienware PC Systems Alienware Aurora High...
Sony Vaio will not turn on
plz check the powersupply unit , ram
Jun 22, 2009 | Sony VAIO PCG-K23 Notebook
Asrock P4I45GV R5 Motherboard Logo
119 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Computer Links
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
