Question about Mtd 22" Yard Machine Push Mower
Rope broke and the winding spring came out, how do we rewind the spring?
    Scholar:
  • 138 Answers
There is not enough room to describe the procedure, especially if you are unfamiliar with it, my suggestion would be to take it to a repair shop, it will save time, money and a lot of frustration
Posted on Sep 26, 2009
The rope broke when I tried to start the chainsaw. How do I replace it?
Your rewind spring is now sprung. Remove recoil assy ( the part your rope slides into). Remove all old rope remnants and rewind the spring. Install new rope, tie it off and slowly release spring rewinding the rope.
Mar 14, 2014 | Stihl 017 018 Ms170 Ms180 Chainsaw Starter...
DO I NEED SPECIAL TOOL TO REFIT COIL SPRING WHICH CAME OUT WHEN FITTING STARTER PULL CORD
There are special tools made for this job, however not needed for most jobs (makes easier). Clean the spring and lube slightly with silicone spray or light oil. Catch the end of the spring that would be the outer end onto slot or pin and slowly spiral the coil into place holding down coils as you turn(dont try to coil the spring then drop it in, take your time as you wind and maybe ask a freind to lend a third hand if your fingers get tired, once you start you cant stop). The inner part of the coil has a bent hook that will catch on the inner portion of the pull rewind. Lood at how the rewind catches this hook by turning the rewind in the direction that it turns when you pull the rope. When you pull the rope it winds the spring. If you put the spring in backwards the rewind spring will not catch. Once you got the spring in place, turn the rewind in the direction that it turns when you pull the rope until it stops, then release one turn and insert rope thru guide and into spool to tie knot. Slowly let rewing pull in new rope. Good luck
Aug 23, 2011 | Electrical Supplies
How to change the pull cord?
Hi b calm,
I will try to help you out. Because you don't specify the brand and model I will try to give you the Weed Eater brand that is manufactured by Poulan because it is the best known in my area and I hope it is well known in your area, but it is pretty well the same procedure for other brands.
To disassemble starter, detach starter housing from engine. Remove rope handle and allow rope to wind into starter. Unscrew pulley retainer or pulley retainer screw and remove rope pulley. Wear appropriate safety eyewear and gloves before detaching rewind spring from housing as spring may uncoil uncontrolled. Try to prevent spring from unwinding if possible, I use a flat piece of metal stiff enough not to bend, about 1" wide or less and try to put it between the spring and pulley, if I have the room to do it and prevent spring from uncoiling as it is quite a job to put it back in. (good luck with that one).
To assemble starter, lubricate center post of housing and spring side with light grease. Install rewind spring so coil windings are counterclockwise from outer end. Install proper size and length of rope. Assemble starter while passing rope through housing rope outlet and attach rope handle to rope. To place tension on starter rope, pull rope out of housing. Engage rope in notch on pulley and turn pulley counterclockwise to place tension on rewind spring. Hold pulley and disengage rope from pulley notch. Release pulley and allow rope to wind on pulley. Check starter operation . Rope handle should be held against housing by spring tension, but it must be possible to rotate pulley at least an additional 1/4 turn when rope is pulled out fully.
I hope this is helpful to even if a little bit. Regards and good luck.
Mar 07, 2011 | Ryobi Garden
Starter rope won't retract
You have to wind the spring as tight as you can before you put the rope on. Then allow the spring to unwind, pulling the rope onto the spool. Be very careful when you take it apart. Good luck...Lee
May 29, 2010 | Craftsman 22" Rear Bag Rear Propelled High...
Starter cord will not rewind after being replaced. The string will rewind in the housing before it is attached to the motor but not after being attached. How do you pre wind the springs?
What I do is the following:
Remove the old rope ( what is left of it)
Wind the starter rope pulley about 8 or 9 complete revolutions after I am confident that the spring has engaged the starter pulley
Hold the pulley in place ( align the rope hole in the pulley with hole in the starter housing
Insert the rope and tie a knot, pull the rope back tight against the pulley
Pull the rope all the way out and hold slight tension on the rope and release the tension on the pulley but still holding the starter housing
Starter spring should pull rope into housing... good luck
Sep 08, 2009 | Garden
The rope broke on my lawn mower and I am trying to rewind the spring, but was advised to buy a complete starter assembly, I need to know how much one is and where can I get one. I bought my lawn mower from...
If your rope broke, there was no reason to take the spring out. The rope can be replaced just by taking the rewind housing off, turning pulley to get rest of old rope out, wind the pulley (and spring) the direction the rope would be pull it when starting. Then , when it's wound tight, back off to align the holes in pulley and cover. Hold it there, stick about an 8' piece of rope from the outside through the pulley and tie a knot. Hold the rope and let the spring pull the rope back into the starter. an tie handle back. Take your housing, and spring to a shop. They can re-install the spring and put on a rope a heck of a lot cheaper that buying that whole assembly.
Jun 16, 2009 | Mtd 22" Yard Machine Push Mower
Starter cord broke went to replace cord and spring came out. how do you rewind and reinstall spring and cord. have lots of tools
Best thing to do is replace the starter rope, if you don't, you're asking for trouble. Get the right length of rope, don't use a longer rope than recommended or you could wrap the spring too tight when you start the motor. I always replace the spring too. It's cheaper than trying to wind up the old one and get it back in. Good luck.
Jun 13, 2009 | Garden
Mtd 22" Yard Machine Push Mower Logo
91 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
