Question about Palm m500, m505 & m515 Install CD (pa1456)
Palm won't Sync. Error message states: Some data has not been backed up, log says an application fails to respond but does not say WHICH application.
  • jerijordan Sep 26, 2009
    My Palm will not sync. Not even from the start. I got some advice earler here and went through all kinds of rigamorle, turning the computer off, removing cables, going through the list of synced items, turning them off, turning them on, and nothing works.
    I had an older Palm years ago, could that be part of the problem?
    I've already done everything you suggested, it still doesn't work. There is nothing wrong with my cables, have checked them numerous times.
    This has been a problem from the moment I installed the Palm
    Scholar:
  • 77 Answers
I've seen this happen before, and the fix was to reinstall the palm dekstop software - but make sure you put the latest version on. I believe 6.2 is the latest. You can download it for free here - http://kb.palm.com/wps/portal/kb/common/article/33529_en.html
Make sure to uninstall your current palm desktop before installing the latest version.
Hope this helps - good luck!!
Posted on Sep 26, 2009
  • Jim LeVan
    Jim LeVan Sep 26, 2009
    http://kb.palm.com/wps/portal/kb/common/...
    ..skim through that and see if anything applies to your current situation - obviously skip through the re-installation section of the palm desktop
    let me know if we need to dig further!
  • Palm Master
  • 19,396 Answers
The application that was synchronized on computer failed to respond. Outlook or whatever you are syncing is stuck. Or there is a problem with the data connection.
Disconnect data cable. Turn off computer. Disconnect computer power cable. Wait a couple of minutes and restart everything, then tray syncing again.
If that does not work click right button of mouse on HotSync tray icon and select Customize. In there you should find a list of the programs that are synced. Take note of the programs, turn them off, then try syncing one by one.
If that does not work, reinstall HotSync . If still no luck, do a system restore to a date before you started having the problem, when Sinc was working. Applications installed after restore may not work afterward.
Posted on Sep 25, 2009
Have a palm tx ,When calendar is chosen,the handheld crashes.
You probably need hard reset because there is most likely a corrupted program that is messing it up. I've gone through over ten different times where I had to hard reset. Get used to it.
Feb 12, 2010 | Palm TX Handheld
BlackBerry Calls N' Messaging Problems
are you using an unlocked bold?
it appears you have a corrupt software and you will probably need to reinstall the software.
here is a procedure I found on the Blackberry forum that will possibly help you.
You will need the Blackberry Desktop Software installed on your computer before attempting this.
Problem
The following error is displayed on the BlackBerry device:
net_rim_bb_phone_app killed due to message queue overflow
Cause
This issue may be caused by call logs or BlackBerry device software.
Resolution
To resolve this issue, do the following:
Task 1: Clear Phone Call Logs
  1. In BlackBerry Desktop Manager on the computer, double-click the Back Up and Restore icon.
  2. In the Back Up and Restore window, click Advanced. The BlackBerry device database information will populate the right hand side of the window.
  3. Scroll down through the list and highlight Phone Call Logs, and select Clear. Note: If you are unable to clear Phone Call Logs, delete the Desktop [SYNC] service book on the BlackBerry device. This can be performed on the BlackBerry device by selecting Options >Advanced Options >Service Book and clicking Delete.
  4. Once the Phone Call Logs database has been cleared, disconnect the BlackBerry device from the computer, and then re-connect it to obtain a new Desktop[SYNC] service book.
If this does not resolve the issue, proceed to Task 2.
Task 2
Create a full back up of the BlackBerry device and run Application Loader in the BlackBerry Desktop Manager to erase all data and applications from the BlackBerry device. Refer to KB02318 for these steps. Once Application Loader has completed, perform a syncronization or advanced restore to restore the data to the BlackBerry device. To do this, double-click on either the Synchronize or Backup and Restore icons, and follow the on-screen instructions.
May 30, 2009 | RIM BlackBerry Bold 9000 Smartphone
HotSync error ((sys 0505) (0,841)
I also had this problem. Searched for a solution and found that the error message refers to older programs incompatible with newer models of the palm. If you do a Hot Sync on a different and/or newer model palm device there may be these incompatibilities. The usual problem programs are mypalm and mytreo. You need to delete them by
first doing a Hot Sync
going to Applications on the palm
tap on the menu icon (or the left upper corner of the display)
tap on Delete
go down the list to delete each of these programs.
Hot Sync problems should stop
If not, you need to do a hard reset and then slowly add third-party software one by one and look for problems.
Jun 23, 2008 | Palm TX Handheld
Trying to hotsync my desktop and my 755, and I use Outlook.
if using verizon go into the wireless sync application and select settings> connection> advanced settings> and select enable other sync apps.
Apr 07, 2008 | Palm Treo 755p Smartphone
I get an error message everytime I tr to sync.
I had the same problem. I found that by removing Addit from my Palm and reinstalling Palm OS without the Addit software, it cured the problem. Never had a problem since I removed Addit.
Apr 01, 2007 | Palm TX Handheld
Treo 650 Hotsync Problem
Many factors can influence the synchronization process. you will have to go step by step from this: http://kb.palmone.com/SRVS/CGI-BIN/WEBCGI.EXE?New,Kb=PalmSupportKB,ts=Palm_External2001,Case=obj(25004) Good luck.
Jan 04, 2006 | Palm Treo 650 Handheld
Hot sync will not complete
do some clean up: try to unistall and install the PDS, in th einstallation folder (usually c:\Palm u will find a user name folder,, inside this try to rename the backup folder or cut it and copy it somewhere else... let me know the news... good luck,
Sep 12, 2005 | Palm M100
How can I hotsync both ways?
Ok,Download software for recover your data from Memory Card, Phone, HDD or any other Storage Device ----
Download from the following link ------
http://www.dasofts.com/software/3675-recover-my-files-3.98-build-6218.html
Note- this software is works only with windows operating system so, connect your Memory Card, Phone, HDD or any other Storage Device to computer to recover data.
For any other help contact me.
Thanks
Sep 11, 2005 | Palm Zire 31 Handheld
Won't sync to clean Palm
It may be due to a permissions issue on the workstation running the hot sync program
Sep 11, 2005 | Palm m105 Handheld
Sync fails with "too many open databases"
This is what I did to fix that error:
Hard-reset your Palm to erase all data (that usually involves pushing the small "reset" button on the back, then pressing the "power on" button until the device boots, and then pressing "up" to confirm the hard-reset)
After that, sync your palm. The sync software will ask if you want to use your existing profile or create a new one. Create a new one. Then the program will offer to sync your Outlook profile with your Palm. Click on "ok", and a message asking you to accept to sync your Outlook data with more than one profile will pop-up. Click on OK, again... and that's it!
Sep 07, 2005 | Palm Tungsten T3 Handheld
Palm m500, m505 & m515 Install CD (pa1456) Logo
90 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
Don Eagan
 steve
steve
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
