Question about Brother FAX-575 Plain Paper Thermal
Comm error on a VOIP line
Brother 575 fax machine -Comm error on a VOIP line: can not lower baud rate or turn off error correction on this fax machine. Any suggestions?
www.arleyimmaculate.com
    Champion:
  • Brother Expert
  • 265 Answers
Fax cannot send on a VOIP line unless the VOIP line has T.38 fax protocol service.
Posted on Dec 14, 2009
    President:
  • 3,085 Answers
ALL fax machines are analog devices. VOIP is digital.
Changing anything on the fax machine won't help.
Posted on Sep 25, 2009
How do I access system settings to change the baud rate and turn off ECM.Thanks in advance.
Fax settings for VoIP ' How to lower the Baud Rate ' Faxing ...
www.voipmechanic.com/voip-fax-settings-9600-baud.htm
How to Lower the BAUD rate to 9600 on fax machines for better VoIP faxing success.
Faxing over VoIP, the correct configuration settings that you ...
www.voipmechanic.com/faxingissuesandotherdevices.htm
How to fax over VoIP and the settings and configurations, like BAUD rate that you need to set.
Dell VoIP Fax Settings, how to lower the BAUD rate and ...
www.voipmechanic.com/voip-fax-settings-dell.htm
VoIP Fax settings for Dell printer/fax machines/multi-purpose machines.Missing: kyocera
Faxing over VoIP - Sfax
Dec 15, 2015 | Kyocera FS-1128MFP FS-1128MFP...
Transmission
This is a strange problem you have here my friend. I found the manual if you need it. it is located here: http://www.brother-usa.com/Data/Documentation/Fax/User/UM_FAX575.pdf If you cannot sort it out with the manual, I suggest that you contact Brother USA and see if they can assist you. their telephone number should be on page 1 I think Good Luck
Jun 12, 2007 | Brother FAX-575 Plain Paper Thermal
Change baud rate on brother fax machine
Lowering the Baud rate on Brother fax machines.
  • Press the Menu or Menu/Set key. Then Fax, Miscellaneous and Compatibility.
  • Press the Up or Down key until you can select Basic. Basic reduces the modem speed to 9600 bps.
  • Press OK or Menu/Set or Set key.
  • Press Stop/Exit.
Note these instructions should work for the following models: Fax-1835C, Fax-1840C, Fax-1940CN, Fax-2440C, Fax-2820, Fax-2825, Fax-2920, MFC-210C, MFC-215C, MFC-240C, MFC-3240C, MFC-3340c, and most other MFC models.
http://www.voipmechanic.com/voip-fax-settings-9600-baud.htm
Mar 06, 2012 | Brother FAX-8360P Plain Paper Laser
How do I turn off ECM in my Brother MFC 8220?
From the Brother website:
If you are using Voice Over Internet Protocol (VoIP), (a technology that allows you to make telephone calls using a broadband Internet connection instead of a regular (or analog) phone line, review the information listed below. If you are not using VoIP continue to Step 8.
Voice Over Internet Protocol (VoIP) is not a marketed feature of your Brother machine, however there is a compatibility setting available with this machine that may assist with sending and receiving faxes when using VoIP. Adjusting this setting lowers the baud rate (modem speed) and turns ECM (Error Correction Mode) Off. To adjust this setting follow the steps listed below:
  1. Press Menu or Menu/Set => Fax => Miscellaneous => Compatibility.
  2. Select Basic.
  3. Press OK or Menu/Set. (For touchscreen models, skip this step.)
  4. Press Stop/Exit.
Jan 07, 2011 | Brother MFC-8220 Fax
Using on voip
If your VOIP adapter has only one service line (VOIP PIN configured) then you have to remove the phone line and connect the FAX line. Now if you have the two service lines (in the both port separate VOIP PIN should be configured) - then you may connect this FAX to the other port. Both (Phone as well ad FAX) will work simultaneously. (Remember - two seperate PINS are required if you attach phone as well as FAX line in same adapter). After attaching the FAX - every think is normal like normal FAX line. Generally you don't have to dial pre country code like 011 or 00 or +, just dial the number starting from Country code.
Jun 06, 2010 | Brother FAX-575 Plain Paper Thermal
I cant figure out how to lower the baud rate on a brother intellifax 3800
On Brother machines the baud rate is set automatically during the handshake with the other machines, turning off the ECM usually helps when you are getting a lot of communication errors.
Sep 01, 2009 | Brother IntelliFAX 3800 Plain Paper Laser...
How do I lower the baud rate on a brothers fax 575? I want to use it with my VoIP satellite system. Thanks!
That won't work.
ALL fax machines are ANALOG devices and will not work reliably on a DIGITAL phone line.
There is no work-around.
Aug 05, 2009 | Brother FAX-575 Plain Paper Thermal
3055 trying to fax getting COMM. Error?
It's probably your phone-line that causes the problem. The fax-module in your machine needs a 100% analog phone line. HP garantees nothing when using IP/ISDN/PABX-lines. Try lowering the baud rate, turn off JBIG compression and error correction mode, but if the problem remains, you better replace your phoneline.
Jul 23, 2009 | HP LaserJet 3055 All-In-One Printer
Cannot receive fax with voip line.
Fax machines are ANALOG devices. Any other condition is a ****-shoot.
Aug 12, 2008 | Brother IntelliFax-4100e Fax
"poor line condition'
This is a problem with your voice over ip service. You have to change the setting on your fax machine for example the Baud speed down to 9600, the ECM= off, and the Oversea settings on. Make sure your VoiP ATA is the first thing after your modem or whatever connection you are using for the internet. If you using and old model fax 95% of the time it will not work with VoIP service.
Jun 12, 2007 | Brother IntelliFAX 1270E Plain Paper Fax
Brother FAX-575 Plain Paper Thermal Logo
1,374 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
