Question about Gateway MX8734 Motherboard - 31PA6MB0090
Mx8734 laptop, system board replacment instructions. The brown connecor which holds the keyboard in is broken. Can just the connector be purchased without the system board. If the system board needs replaced does anyone have instructions for how to replace it?
  • 2,229 Answers
If you broke the connector, you have to get a new board. The connector is fastened to it.
If you opened up the case and can see the board, you generally have to remove all the stuff--connectors, modem, hard drive, CD, etc.
When you get everything unplugged, you will have to remove the screws and then lift the board out.
Pay attention to where the screws go--they are of different sizes.
Posted on Sep 25, 2009
Can one replace a broken connector latch for the keyboard cable of Insp 5720
i am afraid you maight go for change the whole keyboard, try to frind the latch from acer service center
Jan 11, 2013 | Computers & Internet
Fix zif connector
Oh dear you have broken this and will need to send it off to be fixed.
Dec 09, 2012 | Compaq Presario Computers & Internet
I have the replacement keyboard for the gateway NV54 laptop. I need basic instructions on removing the old keyboard and unstalling the new keyboard. Can anybody help because Gateway can't help so far.
All them are pretty basically the same. Pull out power cord and battery... Remove the bezel piece top of the keyboard "the thing the power button sits in". When you remove it there should be 2 screws very tiny holding the keyboard down remove them. Under the keyboard there will be the power ribbon DO NOT JUST PULL IT OUT!! There will be like a brown/white clip that locks the ribbon to the board. The brown may be black or even blue that is the locking piece. Carefully lift the clip up and gently pull the ribbon out. If its stuck you have not unlocked it. Pull the old keyboard out and repeat the steps backwards.
Sep 23, 2011 | Gateway NV5468u Notebook
Evon610c keyboard keys broken how to replace the keyboard ? how to open the case with out damage internal parts ??
Hi
this may help you i found it somewhere online
How to Replace the hp compaq evo n610c laptop keyboard Removing the Damaged Keyboard
Enusre the laptop is fully powered off, unplugged from the wall, and the battery taken out.
Turn the laptop over. On some models icons indicating which screws are attached to the keyboard are displayed. If not, you may have to eyeball it if you can't find a breakdown for your model online.
Remove those screws with a Phillips screwdriver.
Turn the laptop back over and open it up. Check and see if the keyboard is tucked under any plastic pieces. If so, find if those plastic pieces are screwed into anything, and unfasten them as well. If not, it probably uses clamps that can easily be removed.
Remove the plastic pieces carefully with a toothpick or plastic pick if there is any in the way.
Unscrew any screws at the top (if necessary) and remove the keyboard itself from top to bottom. You'll notice that the keyboard is connected with a thin, but wide, data cable to the system board at the bottom.
Take that same pick and lift the plastic connectors that hold in this data cable in place.
Carefully remove the data cable. Now the whole keyboard should be free.
Replacing the keyboard
Take the new keyboard out of the plastic, and slip the data cable back in between the plastic connectors on the system board. Make sure it's all the way in.
Use the pick to push the plastic connectors back into place, and make sure it's holding the data cable in.
Slip the keyboard itself into place, from bottom to top. Make sure the screw holes or clamps line up at the top.
Refasten the keyboard in place at the top.
If you had to remove any plastic pieces, carefully snap them back in and replace any screws you had to remove.
Turn the laptop over and replace all of the keyboard screws.
Finally, put the battery back in and power on the laptop. If all has gone well, the keyboard should be functioning like brand new
hope this was helpful
Jun 21, 2011 | Compaq Evo N610C Notebook
Hi i have got a new keyboard and wish to change it on acer 7520
taken from http://www.batterycentury.com/acer-aspire-7520g-502g25mi-keyboard-p-152819.html
Acer Aspire 7520G-502G25Mi Keyboard Repair and ReplacementAre you considering laptop keyboard repair? You might think twice if you happen to be the lucky owner of a laptop, because replacing the keyboard rather than repairing it could be a lot less expensive. Laptop keyboard replacement on this particular model is very easy and takes just a few minutes. Here is a quick Acer Aspire 7520G-502G25Mi Keyboard repair tutorial with step-by-step instructions. Once you have purchased the new keyboard, all you need to replace the old with the new is a screwdriver and something plastic, flat and thin like a credit card or guitar pick.
Step one: Remove the two screws from the bottom of the computer that are holding down the Acer Aspire 7520G-502G25Mi Keyboard bezel. The bezel is the bar that sits right above all the function keys.
Step two: Turn the computer over, open the cover and insert the credit card or guitar pick between the bezel and the laptop screen. The bezel has pegs that sit in holes, you need to slowly pry up the bezel. It will make a bit of a popping noise as it is removed.
Step three: Now hold on to the laptop keyboard from the end closest to the screen and gently pull it away from the touch-pad end and flip it over. You will see the ribbon attached to the underside of the Acer Aspire 7520G-502G25Mi Keyboard. There is a little plastic connector holding the ribbon to the computer. To unlock it, carefully pull up on the two tabs; one located on each corner of the connector. Be very gentle when you do this as this is the one part that gets broken the most often when changing a keyboard. The ribbon cable will now be released.
Step four: Carefully pull the ribbon out of the connector and remove it along with the entire Acer laptop keyboard.
Final step: To insert the new Acer Aspire 7520G-502G25Mi Keyboard, place the board face down so you have easy access to the ribbon. Make sure the keyboard is lined up so when you flip it back over the keys are in the correct position. Keep the ribbon straight at all times; twisting it could damage it. Place the ribbon in the connector; it only goes in one way. Once in place, push down on the connector tabs to lock it. Now flip the keyboard over and slide it down toward the touch pad and take the bezel and line the pegs up with the holes and push it in place. Then turn the computer over and replace the two screws you removed from the bottom. You can now power on your computer and see if the Acer Aspire 7520G-502G25Mi Keyboard works. If it is not working, more than likely the ribbon was not inserted properly.
May 16, 2011 | Computers & Internet
I dont know why is my key board is didn't work can you show me how to unlock my key board
restart your computer. on boot it will say press del for bios. do that. in case it enters the bios menu then keyboard is fine. probably some virus in windows. if not then your keyboard is damaged.
Mar 03, 2011 | Compaq Presario CQ60-220US PC Laptop
HP LAPTOP G-60 630US KEYBOARD PART # 496771-001 HOW DO I TAKE THE OLD ONE OUT
Do it carefully..at your own risk..
HP 496771-001 Keyboard Repair and Replacement
Are you considering laptop keyboard repair? You might think twice if you happen to be the lucky owner of a laptop, because replacing the keyboard rather than repairing it could be a lot less expensive. Laptop keyboard replacement on this particular model is very easy and takes just a few minutes. Here is a quick HP 496771-001 Keyboard repair tutorial with step-by-step instructions.
Step one: Remove the two screws from the bottom of the computer that are holding down the HP 496771-001 Keyboard bezel. The bezel is the bar that sits right above all the function keys.
Step three: Now hold on to the laptop keyboard from the end closest to the screen and gently pull it away from the touch-pad end and flip it over. You will see the ribbon attached to the underside of the HP 496771-001 Keyboard. There is a little plastic connector holding the ribbon to the computer. To unlock it, carefully pull up on the two tabs; one located on each corner of the connector. Be very gentle when you do this as this is the one part that gets broken the most often when changing a keyboard. The ribbon cable will now be released.
Step four: Carefully pull the ribbon out of the connector and remove it along with the entire HP laptop keyboard.
Final step: To insert the new HP 496771-001 Keyboard, place the board face down so you have easy access to the ribbon. Make sure the keyboard is lined up so when you flip it back over the keys are in the correct position. Keep the ribbon straight at all times; twisting it could damage it. Place the ribbon in the connector; it only goes in one way. Once in place, push down on the connector tabs to lock it. Now flip the keyboard over and slide it down toward the touch pad and take the bezel and line the pegs up with the holes and push it in place. Then turn the computer over and replace the two screws you removed from the bottom. You can now power on your computer and see if the HP 496771-001 Keyboard works. If it is not working, more than likely the ribbon was not inserted properly.
Regards,
Ron
Feb 12, 2011 | HP Computers & Internet
How do i take the keyboard off to see the motherboard on my gateway mx8734
hi willsim , are you mean you have open your gateway laptop to see your motherboard?
you don't want to take off keyboard and all, just turn your laptop in back side you will find sticker and about brand r product name remove it so that u can screw to open your lap top ,in some laptop u can see no of screw visibly, remove it so that u can see *********** board , but its hardly recommended to not open your laptop by yourself , cause if you remove the stickers mean your warranty may be lost. if any more assistance feel free to ask
Dec 30, 2010 | Gateway MX8734 Motherboard - 31PA6MB0090
Keyboard removal
U NEED BRITE LIGHTING LOOK WHERE KEY BOARD IS ATTACHED, LONG SMALL WHITE STRIP WITH BROWN ENDS.
PULL OUT/UP IT SHOULD FREE UP THE KEYBOARD CONNECTOR RIBON
Apr 01, 2010 | Alienware PC Systems M7700 Notebook
How to remove Insperon 1725 keyboard
Keyboard Dell? Inspiron? 1525/1526 Service Manual NOTICE: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on the back of the computer). NOTICE: To help prevent damage to the system board, you must remove the battery from the battery bay before you begin working inside the computer. Removing the Keyboard Remove the two screws at the top of the keyboard. NOTICE: The key caps on the keyboard are fragile, easily dislodged, and time-consuming to replace. Be careful when removing and handling the keyboard. Lift the keyboard and hold it up and slightly forward to access to the keyboard connector. To disconnect the keyboard cable from the keyboard connector on the system board, rotate the keyboard connector latch toward the front of the computer. Slide the keyboard cable out of the keyboard connector. 1 screws (2) 2 keyboard 3 keyboard tabs (5) 4 keyboard cable 5 keyboard connector latch Replacing the Keyboard Slide the keyboard cable into the keyboard connector. Rotate the keyboard connector latch to secure the cable. Align the tabs along the bottom of the keyboard and slide them under the palm rest. Press on the right edge near the top to snap the keyboard into place. Replace the two screws on the top of the keyboard. Or else if this is not clear you can also visit Support.dell.com Thanks Deepak
Oct 30, 2009 | Dell Inspiron 1526 Laptop
Gateway MX8734 Motherboard - 31PA6MB0090 Logo
145 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
